Showing results for tags '64 bit'.
Hi, all. SCCM 2012 SP1 with CU5. I'm seeing weirdness when setting up device collections that attempt to include systems based on both 32 bit and 64 bit applications being installed. I'm trying to combine "Installed Applications.Display Name" (SMS_G_System_ADD_REMOVE_PROGRAMS.DisplayName) with "Installed Applications (64).Display Name" (SMS_G_System_ADD_REMOVE_PROGRAMS_64.DisplayName), but the result isn't what I'm expecting - the collection actually shrinks, instead of growing, which I would think is impossible, since it's an OR. Example using Java: Criteria "Installed Applications.Display Name" like '%java 8' I get 34 members in the collection If I then change the criteria to "Installed Applications.Display Name" like '%java 8%' OR "Installed Applications(64).Display Name" like '%java 8%' Update membership, and the collection drops to 26 members. Some of the dropped ones are systems that I know for a fact have 32-bit Java 8 installed. All of the dropped systems are running a 32 bit version of Windows. I would expect that this would get *any* systems, regardless of OS architecture, with 32-bit Java 8 (since these match the statement before the OR) plus any systems with 64-bit Java 8 (since they match the statement after the OR). What appears to actually be happening is that once the statement to check the 64 bit app list is added, all systems that are running a 32 bit OS are removed from the collection, even though they do match the first criterion. Is this intended behavior? Do I need to massage the query statement? To this point, I've just been using the auto-generated query statement that setting up via the GUI comes back with. Or is this just not possible, and I'd need to create two (32 bit via query, 64 via query + include other collection) or three (32, 64, both via inclusion) separate collections?
- 4 replies
- collection
- query
(and 3 more)
Tagged with:
I am attempting to capture an x64 image of Windows 7 using SCCM and an image capture disk. I am getting an error that indicates that the user account that I am using to capture and write the image to a directory on the SCCM server does not have proper permissions to to write images to the directory in question. I have checked the NT permissions for the account that I am using and it does in fact have full permissions (this is a Domain Admin acocunt) Here are the steps I am following to failure - insert the disk - enter unc path to directory .wim file is to be written to - enter some other info (version, notes, etc...) - start the image capture process - watch machine reboot - watch the death of my SCCM x64 dream as I see the 0x800704cf one more time All indications that I have fond searching Google are that the account doens't have permission but it does. Any help or even useful ideas would be most appreciated.
- 12 replies
- SCCM
- permissions
(and 6 more)
Tagged with:
