Showing results for tags '80070241'.
We've got several laptops that we've had to re-image due to a virus, where the hard drive had been encrypted by bit locker. These are all Lenovo laptops, a few different models, and they all use the TPM chip. We couldn't un-encrypt the drive before we re-imaged, but we did use diskpart to remove all partitions and clean the disk. We even tried using a new disk right out of the package. We also turned off the TPM through BIOS. During the imaging, it gets to applying the OS image, 1-4 squares, then errors out with an 80070241 error. Upon checking the SMSTS logs, I get a different error each time I try. Here is one of the erros: Failed to save environment to (80070057) TSManager 11/30/2011 7:16:58 PM 1328 (0x0530) Failed to save the current environment block. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance. The parameter is incorrect. (Error: 80070057; Source: Windows)Failed to persist execution state. Error 0x(80070057) TSManager 11/30/2011 7:16:58 PM 1328 (0x0530) Failed to save execution state and environment to local hard disk I tried to get some other errors I had seen in the past, but couldn't reproduce them. I'm hoping someone here has seen this problem and can give me some ideas on what to try. I will try to get more logs, but now some of them are coming up without any errors in them.
- 1 reply
- Bit Locker
- 80070057
(and 1 more)
Tagged with:
