Think of an application that needs restart of the machine after install to work correctly. it’s not a good idea to force reboot the machine during the package deployment . To address this ,we present a message to the USER. Currently , we add msg.exe command at the end of the install.cmd to display this message.
In CM 2012 , we will not have install.cmd…So there are 2 question that need to be addressed
Where do we add this message commandIf it’s added to the application object then when the application object is used in the OSD task sequence then the package install will have problem,
in CM 2007 (our environment), We addressed this by creating 2 separate programs ( One with message , other without message) . The program without the message is added to the TS.
Please advice.
Many Thanks,
Surya
