Showing results for tags 'Application deployment'.
    • application deployment ×
Found 13 results
  1. Good morning, I am experiencing an issue with my wireless clients. I'm able to get some information. However, I am unable to get any software deployed to them. For example: - I get the green check, I am getting policy requests, heartbeat DDR, hardware scan, etc. I have the following app...
  2. We have a scenario in our organisation where we want to map a huge lot of environment variables for specific machines. Each and every variables are unique to each machine. There are around 6000 variables which needs to be mapped to 6000 machines. Is there any way we can handle it through SCCM ?
  3. Hi. Long time lurker, first time poster here. I have been having a problem with our new ConfigMgr environment for the past few days and i'm starting to run out of ideas. We successfully deployed a new Windows 7 image to all of our client pc's and now we have to deploy quite a few different a...
  4. Hello, I'm pretty new to SCCM, and have made some progress in capturing a reference image in a vm, and creating a task sequence to install applications (Office 2010, Sophos antivirus, Reqourdit integration plugin) to a few of our new PCs which I'm testing. Everything seems to be working well except...
  5. Hello All, I have deployed office 2013 application using sccm 2012 and made available to devices so that application will reside in software center. i had deployed this application on 27 of march 2015.and i have tested it successfully by installing some of user's workstation. Now i check...
  6. i am having inconsistent application installation during PXE deployment and the logs are not helping me out so i was hoping someone else might have an idea. i can image one laptop and get a few missing applications one time and re-image and get a few different applications missing. for each ap...
  7. Hi All, I have a couple of fairly advanced questions: here is my scenario: A user's device has multiple App-V Applications targeted to it (e.g. 15), SCCM will choose a random order to download and install these applications, however one of them fails at the download stage (whether due to...
  8. Quick question concerning application supersedence that I can't find the answer to. If I setup supersedence on an app will that relationship only affect machines that the app has been deployed to or will machines with the superseded app see that the version they have has been superseded and upgrade...
  9. I sometimes have a problem where the summary for an application deployment shows errors: ...but "View Status" shows this: Running a summarization does not help. Also, this is not a new deployment but one that is weeks old. I have been trying to find a report that would identify the s...
  10. Hi There. I have a scenario that I want to get some clarification. I think I know how it will work but wonder if I'm understanding it correctly. I have clients across a WAN that I want to deploy an application to but the bandwidth is limited and I can't put local DPs there. I want to prestage...
  11. We have successfully built or agent deployment system for OSX and packaged up our first few apps (Office 2011, SCEP, Firefox, etc) but have run into a problem where after the initial install the client never seems to detect the existence of an application (or lack thereof) unless a brand new deploym...
  12. Hi, I've been lurking here for quite some time and this site has helped me incredibly since i've started using SCCM. I've now came across an issue that there are not topics for (that i can find) so i'm enlisting the help of you fine people! I've got Adobe Acrobat Std X as an application, and...
  13. Hi All, I'm trying to know the list of log files for SCCM Software Distribution. In most cases we find "No status" in the report. I know that Execmgr.log is the log file which "Records Advertisements that run" on client machine. Let me tell you about the infrastructure. We have a pri...
