Showing results for tags 'Build capture task sequence'.
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
    • Windows 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Official Forum Supporters
    • Windows News
    • Suggestion box
    • Jobs
  • MDT, SMS, SCCM
    • How do I ?
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Windows Server General
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
Website URL
Location
Interests
Found 1 result
  1. Hello First of all thank you very much for all the guides and the help you provide here !!!! Now based on the guide found at http://www.windows-noob.com/forums/index.php?/topic/4468-using-sccm-2012-rc-in-a-lab-part-7-build-and-capture-windows-7-x64/, I made a small mistake and missed the "and that you DO enter an Administrator Password" when creating the task sequence. As the OS is not part of a domain or is another user configured ... I'm locked out .... So I modified the settings accordingly but I cannot get the client computer to see that modification. Topology is : one main server (in a datacenter) with a dedicated SQL instance and one disribution point in another physical building where I reside with my test computer. I tried by - Right click the task sequence and Deploy (to the same Collection) - I selected all references one by one and Update Distribution point (Bootimage package, OS installation package and CM client upgrade package) When I do 'Distribute Content' and select 'Add Distribution points', only the server in the datacenter is selectable. not my WDS on the client site (which means it is already valid for the task sequence right?) I'm pretty sure it's my distribution point that's missing the new info but I dont know how and where I can push the new version of the task sequence. Thanks for your help Steve
