Showing results for tags 'CU3 problems'.
Hello everyone, I have a single primary site server running Windows 2012 Server and SCCM 2012 SP1. We recently started imaging Windows 8.1 so I upgraded to CU3 in order to have Windows 8.1 support. I rolled the CU3 client to small test group for both the x64 and the x86 clients and it installed successfully. I only have about 350 total computers with multiple offsite locations connected via T-1 so after I verified all was good to go I deployed the CU3 upgrade to the x64 and x86 computers respectively. Since then I have had nothing but problems. I'm not sure if the CU3 .msp file somehow got corrupted during the push but 90% of my computers will not check in to the server. When I remote to a workstation or server and try to do a machine policy retrieval, I get the error message that the selected cycle cannot start. When I do a CTRL - ALT - DELETE, many times I see both processes "ccmsetup" and "ccmrepair" running. If I End Task on both of those processes and I run the .msp file manually, the CU3 update appears to install and the client becomes active again. Since the clients are communicating with the server, I can't push the client again. Any ideas on what went wrong and how to fix it are greatly appreciated. I've been fighting with this for a few days now and I don't believe there is an easy solution. Thanks in advance.
- 3 replies
- SP1 CU3
- CU3 Install
(and 3 more)
Tagged with:
