Hi All,
I have few configuration items and a configuration baseline which are imported from GPO export from security compliance manager. CB is working fine on test domain.
Exported CB to a different domain and it imported properly but while checking compliance it gives error.
All the checks fails with error on script running which shows current value as "Rule Validation Failure: ..."
These were auto generated scripts to check the CI.
example "Rule Validation Failure: "Do not display Server Manager automatically at logon"; Expected Value: "Enabled";"
Am i missing something over here..
