Showing results for tags 'Distribution Point'.
    • distribution point ×
  1. Hello We recently moved our sccm on prem server to the azure cloud , since this move we are having issues with building devices. Basically we transferred the pxe from the main server as it is in the cloud to our on prem distribution point so we can now pxe boot and get the screen to kick of th...
  2. Hi all, I've just setup a lab environment at home, I'm currently limited to 8GB RAM on my desktop. I've got one VHD with Server 2008 R2 with the ADDS and DNS roles, it's got SQL Server 2008 R2 running on it as well as SCCM 2012 RC. Performance is fine and works quite nicely However, my ques...
  3. Hi all, In all our company uses 8 distribution point and the majority are 2008 R2 domain controllers. About two days ago I have done an inplace upgrade on one server to 2012 R2. The upgrade went mostly without a hitch except for the SCCM DP. The error that I was getting was "access denie...
  4. Hi! Yesterday I tried to create a distribution point on a Windows 7 Enterprise SP1 x86 machine because on SCCM 2007 we have about 110 small locations with a BDP. So we need this feature in 2012, too. I clicked through the wizard to add a new site system but on the Windows 7 machine nothing happens....
  5. Dear Admin, My Apologize - I feel to raise this Question separately to make myself clarity on asking question and getting answer, As per the previous post, Phase I : Upgrade from SCCM 2012 SP2 to SCCM CB V1606 At Present, the Environment is having as below and mentioned with To...
  6. We are having a very difficult time locating any posts, forum topics, or ms bulletins in regards to the attached distmgr.log file. If anybody of you knowledgeable helpful users on the forum can assist in ANY way, please feel free to offer any suggestions. We currently are unable to distribute any ne...
  7. I need help with Software Updates on SCCM 2012. Client machine has "Downloading (0% complete)" in the Software Center for every update. There are about thirty updates that apply to this client machine. What I have done: Created an Update List Created a Deployment Package with the Updates. Downl...
  8. As title says I am having some issues with my Azure cloud distribution point. First some info about my Azure cloud setup: It is set up with 2 certificates with common name of my FQDN to my Windows Azure. Exported them to the sccm-site server. Configmgr group have read and enroll rights. 1 certific...
  9. Hello everyone, I am setting up IBCM and am looking at the DP cert requirements. In the TechNet documentation and walk throughs, this cert is often configured for auto enrollment from ADCS with private key marked exportable. There's no mention of Subject Alternative Names... but my spidey sense...
  10. Hi, In my environment I have 3 locations for Operation System Deployments. Each one has its own DP and boundaries group. We have a very slow OSD process in one of them (3-4 for one deployment, other DPs take less than an hour) The only difference betwen the slow DP and the others DPs is that i...
  11. Hi, We are currently running SCCM 1606, and have a mix of Win7 and Win10 images. The probleme is the updated WIM file is not being updated on the DP, there is no error message, it shows up updated time stamp, however the image is not updated and keeps the same size. I'm thinking to delete the...
  12. Hi everyone, Currently, our company has 2 sites(Site A, site B)in different locations, and we already setup 1 SCCM 2012 R2 server in site A which as a primary server to deploy software, OS, patches to all PCs in 2 site. So my boss wanna build one more server to reduce its resource requirements and...
  13. I have a single primary 1606 site, I went to configure the Site System Prerequisites on a new DP I was rolling out on Windows Server 2012 R2, I reviewed the following TechNet article https://technet.microsoft.com/en-us/library/mt752493.aspx, which was last updated 2016/07/22 there is a note that cl...
  14. Hi everyone, I am facing a strange issue. After distribution of 3 applications (not packages) failed on a DP, i decide to remove those from the DP by doing this trought the DP propertiets (content tab) Now i am trying to distribute again those application to the DP, but never distributed. The DP...
  15. Hi All I am stuck with a problem in SCCM 2012. It is unable to distribute newly packaged content. The DP just says "starting to process content" and doesnt change. I have removed the DP from the server and re-added it. Reinstalled IIS Recreated the package(s) Installed update http://support.m...
  16. Our environment contains a CAS site and 3 Site servers. Currently each site server has 1 DP and 1 MP. Because of a firewall and various security limitations, we are setting up a new DP, MP and update point that reports to one of the existing site servers. We use SCCM for OS Deployments. We Us...
  17. My task sequence fails with - "this task sequence cannot run because the program files for 00100002 cannot be located on a distribution point" (00100002 is config manager client). Does anyone have any idea why? I notice that my client package says 0 programs and has DEPLOY greyed out, so cant be d...
  18. Hi i have struggling with some of my distribution points, when i look at the \Monitoring\Overview\Distribution Status\Distribution Point Configuration Status it reports as my DP all green and fine. but i had some of our engineers complaining applications were not downloading. When i looked int...
  19. Hey Guys / Niall - I recently started in a new position to help implement and advise on SCCM 2012 (1511) as well as the setup of all features including converting them from using imaging to OSD, Application deployment, Software Updates, etc - at least all the basics except for Forefront. Quite...
  20. Hi Everyone, I have a strange issue that I'd like some help on please. I've used the build and capture task sequence to capture a wim image. I add this wim to my Operating System Images and then run through the Scheduled Updates wizard. This all looks to work fine and I can see in my image's...
  21. I have an SCCM 2012 R2 distribution point that was accidentally reinstalled (the DP role removed, then re-added - no content was deleted) the packages and content library are all still on the DP, is there any way to get the reinstalled DP to recognize and associate with the now old content? it seems...
  22. Hi! I have various computers in the correct bounderary (correct IP og AD), but connectingen to a DP outside that bounderary.... someone has an idea how to tackel this one ?
  23. I have a 2012 R2 SP1 primary site that is servicing the main campus of the University I work at. All the site servers are located in the main campus data center. We also have a remote campus about 15 miles away from the main campus which utilizes the the servers in the main campus data center. Fo...
  24. Hi Everyone Strange problem we seem to be getting - wonder if anyone else has found the same issue... Standard task sequence for deploying Windows 7 x86 and some standard software, used on 7 remote sites each using a local distribution point One site seems to keep failing, on installing a cu...
  25. Hi All, Has anyone ever written a script or report to pull out packages and applications which are not distributed to any DPs? We are wanting to do some cleaning up of our source folder... Thanks John
