We have a new server with all new devices which was imported using a file (start from fresh cos the old world was way off in accuracy).
I'm trying to do OSD deployments but they are failing (basically thinks it has no job to do) when I check for devices with that mac address I now have two entries one is imported manually and the other "heartbeat discovery".
Why don't the two records merge into one? And how can I reverse this process so I can do my deployments?
Also the heartbeat discovery entry has the client type as "Computer" and client as "yes" where as the manual entry one does not. Should I be removing the manual entry one and keeping the heartbeat discovery one?
I removed the manually entered entry and it works fine but should I be removing the manual one or the HB discovered one? What is best practice?
Regards
Peter
