Showing results for tags 'Maintenance Mode Reminder'.
HI Guys I have bee studing the code from this guys here, I want to implement a similar reminder email, Can anyone help to make sence of it? I dont know where to start. h**p://syscenterstuff.blogspot.com/2010/02/maintenance-mode-reminder-emails.html 1) A SQL Linked Server connection to Active Directory - this allows us to lookup the email address of the AD user who put the machine into maintenance mode. In our company we make use of a centralised server details page (with MM integration). If this page is used to put the machine into maintenance mode, another "service" account is used, but the username is stored in the comments section as follows: DOMAIN\USER: Comments 2) SQL Mail will need to be setup. 3) There is another portion to this - a Web Service which receives the request to extend the maintenance mode. You may choose to omit this portion but it's nice functionality to have. This is in C#. SQL Code: DECLARE @now datetime; DECLARE @LocalGMTOffset int; DECLARE @MMWindowAlertThresholdPerc int; DECLARE @startPos int; DECLARE @endPos int; DECLARE @userName varchar(200); DECLARE @sql nvarchar(4000); DECLARE @AD varchar(200); DECLARE @WebServer varchar(200); DECLARE @actionAccount varchar(200); SET @LocalGMTOffset = +2 SET @MMWindowAlertThresholdPerc = 75; SET @NOW = dateadd(hour,(@LocalGMTOffset * -1),getdate()); SET @AD = 'http://' + @WebServer + '/mm/Default.aspx?bmid='+ @BmeId + '&extend=1&DisplayName='+@DisplayName+'" class="button">1 hour</a> <a href="http://' + @WebServer + '/mm/Default.aspx?bmid='+ @BmeId + '&extend=2&DisplayName='+@DisplayName+'" class="button">2 hours</a> <a href="http://' + @WebServer + '/mm/Default.aspx?bmid='+ @BmeId + '&extend=4&DisplayName='+@DisplayName+'" class="button">4 hours</a> <a href="http://' + @WebServer + '/mm/Default.aspx?bmid='+ @BmeId + '&extend=8&DisplayName='+@DisplayName+'" class="button">8 hours</a> Other options: <a href="http://' + @WebServer + '/mm/Default.aspx?bmid='+ @BmeId + '&extend=0&DisplayName='+@DisplayName+'" class="button">Take out of maintenance mode</a> </BODY> </HTML>' EXEC msdb.dbo.sp_send_dbmail @recipients=@mail, @subject = @subjectVal, @body = @bodyVal, @body_format = 'HTML'; SET @startPos = @startPos + 1 END --MUST REMOVE THIS WHEN LIVE - this is left here for testing purposes so it'll always send --delete from [monitor].[dbo].[tb_MMWindows] --------------------------- C# Web Service Code: using System; using System.Configuration; using System.Data; using System.Linq; using System.Web; using System.Web.Security; using System.Web.UI; using System.Web.UI.HtmlControls; using System.Web.UI.WebControls; using System.Web.UI.WebControls.WebParts; using System.Xml.Linq; using Microsoft.EnterpriseManagement; using Microsoft.EnterpriseManagement.Configuration; using Microsoft.EnterpriseManagement.Monitoring; using System.Collections.ObjectModel; using System.Collections.Generic; public partial class _Default : System.Web.UI.Page { protected void Page_Load(object sender, EventArgs e) { int gmtOffset = 2; string bmid = Request.QueryString["bmid"]; int extendHours = System.Convert.ToInt32(Request.QueryString["extend"]); string pcDisplayName = Request.QueryString["displayname"]; if (bmid != null && pcDisplayName != null) { ManagementGroup mg = new ManagementGroup("RMS1"); string mcCriteria = "Name = 'Microsoft.Windows.Computer'"; string query = "Id = '" + bmid + "'"; MonitoringClassCriteria criteria = new MonitoringClassCriteria(mcCriteria); MonitoringClass monClass = mg.GetMonitoringClasses(criteria)[0]; MonitoringObjectCriteria objCriteria = new MonitoringObjectCriteria(query, monClass); List<monitoringobject> monObjects = new List<monitoringobject>(mg.GetMonitoringObjects(objCriteria)); if (monObjects.Count == 0) { litOutput.Text = "Could not find an object with that display name. System Center has been notified."; } foreach (MonitoringObject monObject in monObjects) { if (extendHours == 0) { DateTime scheduledEndTime = DateTime.UtcNow; try { monObject.StopMaintenanceMode(scheduledEndTime, Microsoft.EnterpriseManagement.Common.TraversalDepth.Recursive); litOutput.Text = pcDisplayName + " has successfully been taken out of maintenance mode."; } catch(Exception Ex) { litOutput.Text = "Encountered an error stopping maintenance mode. System Center has been notified. " + Ex.Message; } } else { if (!monObject.InMaintenanceMode) { try { DateTime startTime = DateTime.UtcNow; DateTime scheduledEndTime = DateTime.UtcNow.AddHours(extendHours); string comments = extendHours + " hour maintenance mode window requested"; monObject.ScheduleMaintenanceMode(startTime, scheduledEndTime, 0, comments, Microsoft.EnterpriseManagement.Common.TraversalDepth.Recursive); litOutput.Text = pcDisplayName + " has already been taken out of maintenance mode. Starting a new maintenance mode window for " + extendHours + " hours." + " Scheduled end time is: " + scheduledEndTime.AddHours(gmtOffset).ToString(); } catch(Exception Ex) { litOutput.Text = "Encountered an error placing machine into maintenance mode. System Center has been notified. " + Ex.Message; } } else { try { MaintenanceWindow myWindow = monObject.GetMaintenanceWindow(); DateTime scheduledEndTime = myWindow.ScheduledEndTime.ToUniversalTime().AddHours((extendHours + gmtOffset)); string updatedComments = myWindow.Comments + " || " + extendHours + " hour extension requested"; monObject.UpdateMaintenanceMode(scheduledEndTime, 0, updatedComments, Microsoft.EnterpriseManagement.Common.TraversalDepth.Recursive); litOutput.Text = pcDisplayName + " has had its maintenance mode extended by the requested " + extendHours + " hours" + " New scheduled end time is: " + scheduledEndTime.AddHours(gmtOffset).ToString(); } catch(Exception Ex) { litOutput.Text = "Encountered an error extending maintenance mode. System Center has been notified. " + Ex.Message; } } } } } } } </monitoringobject></monitoringobject> And that's it... this works nicely once it's setup. It may take you a while to get all the components right - if you need help give me a shout.
