Showing results for tags 'Now Micro Right Click Tools'.
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
    • Windows 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Official Forum Supporters
    • Windows News
    • Suggestion box
    • Jobs
  • MDT, SMS, SCCM
    • How do I ?
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Windows Server General
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
Website URL
Location
Interests
Found 1 result
  1. I work for a university that has a standard DNS suffix that matches the domain name across most of the University. My department, however, is unique and our workstations are actually assigned a different DNS suffix that does not match the domain name. So a computer may be named CompName.DomainName.edu but it will resolve as CompName.AltDNSSuffix.edu. Central IT has given out department's IT delegated access to our department's device collection in Configuration Manager 2012 and sent us to training. One of the suggestions of our trainer was to utilize Now Micro Right Click Tools. These tools work for every department in the university but mine. Any time I try to use them, I get told that the workstation is offline. I believe the reason for this is my department's unique DNS Suffix. The actual error I get is "CompName.DomainName.edu is not online." The problem is that CompName.DomainName.edu does not resolve, only CompName.AltDNSSuffix.edu will resolve. I do not have control over the DNS or DHCP so I am looking for a solution that does not involve changes to their configuration. Now Micro Right Click tools is really just a cool collection of Powershell scripts so I believe I can correct this if I can get the script which queries and assigns the computer name to a variable to assign only the first part of the computer name, not the FQDN to the variable. Meaning the variable $CompName becomes "CompName" and not "CompName.DomainName.edu". I am not that skilled with Powershell or scripting in general and would appreciate any assistance. I believe the script I will paste at the bottom of this post is the one that needs to be altered. Thanks! Ryan <# Functions that do all the work Author: Ryan Ephgrave Now Micro Right Click Tools #> $ErrorActionPreference = "SilentlyContinue" $Script:JobTimer = @{} $Script:SkippedJobs = @() $Script:TimedOutComps = New-Object System.Collections.Arraylist $Script:UnsuccessfulCount = 0 $Script:NumSuccessful = 0 $Script:SuccessfulArray = New-Object System.Collections.Arraylist $Script:UnsuccessfulArray = New-Object System.Collections.Arraylist Function WOL { Param ( $CompName, $MAC, $IP, $SubnetMask, $Port, $PacketsToSend ) $UDPclient = New-Object System.Net.Sockets.UdpClient filter Convert-IPToDecimal{([iPAddress][string]([iPAddress]$_)).Address} filter Convert-DecimalToIP{([system.Net.IPAddress]$_).IPAddressToString} $PacketSentCount = 0 $SentPacket = $false $IPArray = $IP.Split(",") $MaskArray = $SubnetMask.Split(",") foreach ($instance in $IPArray){ if ($instance.contains(".")){ foreach ($MaskInstance in $MaskArray){ if ($MaskInstance.contains(".")){ $Error.Clear() $strEditedMac = $MAC | Out-String $strEditedMac = $strEditedMac.replace(":","") $strEditedMac = $strEditedMac.Substring(0,12) [uInt32]$ip = $instance | Convert-IPToDecimal [uInt32]$subnet = $MaskInstance | Convert-IPToDecimal [uInt32]$broadcast = $ip -band $subnet $broadcastAddr = $broadcast -bor -bnot $subnet | Convert-DecimalToIP $BroadcastAddress = [Net.IPAddress]::Parse($BroadcastAddr) $MakingPacket=0,2,4,6,8,10 | % {[Convert]::ToByte($strEditedMac.substring($_,2),16)} $Packet = (,[byte]255 * 6) + ($MakingPacket * 16) $UDPclient.Connect($BroadcastAddress,$Port) Do { [void]$UDPclient.Send($Packet, 102) $PacketSentCount++ } while ($PacketSentCount -lt $PacketsToSend) $SentPacket = $true $Results = Select-Object -InputObject "" One, Two, Three, Four, Five $Results.One = "$CompName" $Results.Two = "$MAC" $Results.Three = "$Instance" $Results.Four = "$MaskInstance" $Results.Five = "$Port" $Script:SuccessfulArray += $Results } } } } if ($SentPacket -eq $false) { $Results = Select-Object -InputObject "" One $Results.One = "$CompName" $Script:UnsuccessfulArray += $Results } $SentPacket } $Client_Actions = { $CompName = $args[0] $strAction = $args[1] $Answer = $args[2] If (Test-Connection -computername $CompName -count 1 -quiet){ if ($Answer -eq 6) { $ActionObject = Get-WmiObject -Query "Select * from InventoryActionStatus where InventoryActionID = '$strAction'" -Namespace root\ccm\invagt -ComputerName $CompName $ActionObject | Remove-WmiObject } $Error.Clear() $WMIPath = "\\" + $CompName + "\root\ccm:SMS_Client" $SMSwmi = [wmiclass] $WMIPath [Void]$SMSwmi.TriggerSchedule($strAction) if($Error[0]){$strOutput = "$CompName" + "|Error|" + $Error} else{$strOutput = "$CompName" + "|Successful"} } else {$strOutput = "$CompName" + "|Off"} Write-Output $strOutput } $Ping_Computer = { $CompName = $args[0] $strOutput = "$CompName|Left|" Test-connection -computername $CompName -count 1 | ForEach-Object { $StrOutput = $strOutput + $_.ProtocolAddress $StrOutput = $strOutput + "|" + $_.ResponseTime + "ms" $StrOutput = $strOutput + "|" + $_.ReplySize $StrOutput = $strOutput + "|" + $_.ResponseTimeToLive + "|" } if ($Error[0]) {$strOutput = "$CompName|Right|Off"} Write-Output $strOutput } $GPUpdate_Computer = { $CompName = $args[0] $UserPolicy = $args[1] $ComputerPolicy = $args[2] $Error.Clear() if ($UserPolicy -eq "True" -and $ComputerPolicy -eq "True") {$strCommand = "cmd /c echo N | gpupdate /force"} elseif ($UserPolicy -eq "True") {$strCommand = "cmd /c echo N | gpupdate /Target:User /force"} elseif ($ComputerPolicy -eq "True") {$strCommand = "cmd /c echo N | gpupdate /Target:Computer /force"} else {$strCommand = "cmd /c echo N | gpupdate /force"} if (Test-Connection $CompName -Count 1) { if ($UserPolicy -eq "True") { $LoggedOnUser = $null $strQuery = "Select UserName from Win32_ComputerSystem" Get-WmiObject -Query $strQuery -ComputerName $CompName | ForEach-Object {$LoggedOnUser = $_.UserName} if ($LoggedOnUser.Length -lt 1) { $strQuery = "Select * from Win32_Process where Name like 'explorer.exe'" Get-WmiObject -Query $strQuery -ComputerName $CompName | ForEach-Object {$LoggedOnUser = $_.GetOwner()} $LoggedOnUser = $LoggedOnUser.Domain + "\" + $LoggedOnUser.User } $LoggedOnUser = $LoggedOnUser | Out-String $LoggedOnUser = $LoggedOnUser.replace("`n","") if ($LoggedOnUser.Length -gt 2) { $Today = Get-Date $Tomorrow = $Today.AddDays(1) $Today = "{0:MM/dd/yyyy}" -f [DateTime]$Today $Tomorrow = "{0:MM/dd/yyyy}" -f [DateTime]$Tomorrow & cmd /c schtasks.exe /create /S "$CompName" /RU "$LoggedOnUser" /SC DAILY /SD "$Today" /ST "00:02" /ED "$Tomorrow" /Z /F /TN "Temp_GPUpdate_Task" /TR "`"$strCommand`"" Start-Sleep 10 & cmd /c schtasks.exe /run /S "$CompName" /i /tn "Temp_GPUpdate_Task" & cmd /c schtasks.exe /delete /S "$CompName" /f /tn "Temp_GPUpdate_Task" if ($Error[0]) { $ErrorMsg = $Error[0].Exception.Message $strOutput = "$CompName|Error|$ErrorMsg" } else {$strOutput = "$CompName|Successful|$LoggedOnUser"} } else { [WMIClass]$wmi = "\\$CompName\root\cimv2:Win32_Process" $wmi.Create($strCommand) | Out-Null if ($Error[0]) { $ErrorMsg = $Error[0].Exception.Message $strOutput = "$CompName|Error|$ErrorMsg" } else {$strOutput = "$CompName|Successful"} } } else { [WMIClass]$wmi = "\\$CompName\root\cimv2:Win32_Process" $wmi.Create($strCommand) | Out-Null if ($Error[0]) { $ErrorMsg = $Error[0].Exception.Message $strOutput = "$CompName|Error|$ErrorMsg" } else {$strOutput = "$CompName|Successful"} } } else {$strOutput = "$CompName|Off"} Write-Output $strOutput } $Cancel_Pending_Reboot = { $CompName = $args[0] If (test-connection -computername $CompName -count 1 -quiet){ $Error.Clear() & shutdown.exe /m $CompName /a $ShutdownExitCode = $LastExitCode if ($ShutdownExitCode -eq 1116) {$strOutput = "$CompName" + "|No pending shutdown"} elseif ($ShutdownExitCode -eq 0) {$strOutput = "$CompName" + "|Cancelled pending shutdown"} else {$strOutput = "$CompName" + "|Error|" + $Error} } else {$strOutput = "$CompName|Off"} Write-Output $strOutput } $Change_Cache_Size = { $CompName = $args[0] $NewCacheSize = $args[1] If (test-connection -computername $CompName -count 1 -quiet){ $Error.Clear() $CacheUsed = 0 $strQuery = "select ContentSize from CacheInfoEx" Get-WmiObject -ComputerName $CompName -Query $strQuery -Namespace root\ccm\SoftMgmtAgent | ForEach-Object { if ($_.ContentSize -ne $null) { $TempNum = 0 $TempNum = $_.ContentSize $TempNum = $TempNum / 1024 $CacheUsed = $CacheUsed + $TempNum } } $cachesize = Get-WmiObject -ComputerName $CompName -Class CacheConfig -Namespace root\ccm\softmgmtagent foreach ($instance in $cachesize) {$OldCache = $instance.Size} $Error.Clear() $cachesize.Size = "$NewCacheSize" $cachesize.Put() | Out-Null if($Error[0]){$strOutput = $CompName + "|Error|" + $Error} else{$strOutput = $CompName + "|Successful|" + $NewCacheSize + "|" + $OldCache + "|" + $CacheUsed} } else {$strOutput = "$Compname|Off"} Write-Output $strOutput } $Clear_Cache = { $CompName = $null $CompName = $args[0] If (test-connection -computername $CompName -count 1 -quiet){ $Error.Clear() Get-WmiObject -ComputerName $CompName -Class CacheInfoEx -Namespace root\ccm\softmgmtagent | ForEach-Object { $CachePath = $_.Location $CachePath = $CachePath.replace(":","$") $CachePath = "\\$CompName\$CachePath" Remove-Item $CachePath -Recurse -Force $_ | Remove-WmiObject } if ($Error[0]) {$strOutput = "$CompName" + "|Error| " + $Error} else {$strOutput = "$CompName" + "|Successful"} } else {$strOutput = "$CompName" + "|Off"} Write-Output $strOutput } $Repair_Client = { $CompName = $null $CompName = $args[0] If (test-connection -computername $CompName -count 1 -quiet){ $Error.Clear() $WMIPath = "\\" + $CompName + "\root\ccm:SMS_Client" $SMSwmi = [wmiclass] $WMIPath [Void]$SMSwmi.RepairClient() if ($Error[0]) {$strOutput = "$CompName" + "|Error|" + $Error} else {$strOutput = "$CompName" + "|Successful"} } else {$strOutput = "$CompName" + "|Off"} Write-Output $strOutput } $Restart_SMS_Service = { $CompName = $null $CompName = $args[0] If (test-connection -computername $CompName -count 1 -quiet){ $Error.Clear() $CcmExecService = Get-Service -ComputerName $CompName -Name "CcmExec" Restart-Service -InputObject $CcmExecService if ($Error[0]) {$strOutput = "$CompName" + "|Error| " + $Error} else {$strOutput = "$CompName" + "|Successful"} } else {$strOutput = "$CompName" + "|Off"} Write-Output $strOutput } $Uninstall_Client = { $CompName = $null $CompName = $args[0] If (test-connection -computername $CompName -count 1 -quiet){ $Error.Clear() Get-WmiObject -ComputerName $CompName -Class CCM_InstalledProduct -Namespace root\ccm | ForEach-Object {$ProductCode = $_.ProductCode} $UninstallCommand = "msiexec /x `"$ProductCode`" REBOOT=ReallySuppress /q" $WMIPath = "\\" + $CompName + "\root\cimv2:Win32_Process" $StartProcess = [wmiclass] $WMIPath $ProcError = $StartProcess.Create($UninstallCommand,$null,$null) $ProcError = $ProcError.ReturnValue if ($Error[0]) {$strOutput = "$CompName" + "|Error| " + $Error} else { if ($ProcError -eq 0){$strOutput = "$CompName" + "|Successful"} else {$strOutput = "$CompName" + "|Error| " + $Error} } } else {$strOutput = "$CompName" + "|Off"} Write-Output $strOutput } $Schedule_ShutdownRestart = { $CompName = $null $CompName = $args[0] $Action = $args[1] $Delay = $args[2] $IfUserOnBoxText = $args[3] $TaskName = $args[4] $FreqText = $args[5] $Modifier = $args[6] $StartDate = $args[7] $StartTime = $args[8] $EndDate = $args[9] $Directory = $args[10] $StartDay = $args[11] If (test-connection -computername $CompName -count 1 -quiet){ $Error.Clear() if ($Action -eq "Restart"){ if ($IfUserOnBoxText -eq "Restart/Shutdown") { $ShutdownCommand = "shutdown /r /f /t $delay" } elseif ($IfUserOnBoxText -eq "Give user a prompt to cancel"){ Get-WmiObject -ComputerName $CompName -class Win32_OperatingSystem | ForEach-Object {$WinDirectory = $_.WindowsDirectory} $ShutdownCommand = "$WinDirectory\ConfigMgr_Shutdown_Utility.exe /r /t $Delay /Schtask `"$WinDirectory\ConfigMgr_Shutdown_Utility.exe`"" $CopyDirectory = $WinDirectory.ToLower().replace("c:","\\$CompName\c$") Copy-Item "$Directory\ConfigMgr_Shutdown_Utility.exe" $CopyDirectory -Force Copy-Item "$Directory\ConfigMgr_Shutdown_Utility.vbs" $CopyDirectory -Force } elseif ($IfUserOnBoxText -eq "Cancel Restart/Shutdown") { Get-WmiObject -ComputerName $CompName -class Win32_OperatingSystem | ForEach-Object {$WinDirectory = $_.WindowsDirectory} $ShutdownCommand = "$WinDirectory\ConfigMgr_Shutdown_Utility.exe /r /t $Delay /Skip /Schtask `"$WinDirectory\ConfigMgr_Shutdown_Utility.exe`"" $CopyDirectory = $WinDirectory.ToLower().replace("c:","\\$CompName\c$") Copy-Item "$Directory\ConfigMgr_Shutdown_Utility.exe" $CopyDirectory -Force } } elseif ($Action -eq "Shutdown") { if ($IfUserOnBoxText -eq "Restart/Shutdown") { $ShutdownCommand = "shutdown /s /f /t $delay" } elseif ($IfUserOnBoxText -eq "Give user a prompt to cancel"){ Get-WmiObject -ComputerName $CompName -class Win32_OperatingSystem | ForEach-Object {$WinDirectory = $_.WindowsDirectory} $ShutdownCommand = "$WinDirectory\ConfigMgr_Shutdown_Utility.exe -arguments /s /t $Delay /Schtask `"$WinDirectory\ConfigMgr_Shutdown_Utility.exe`"" $CopyDirectory = $WinDirectory.ToLower().replace("c:","\\$CompName\c$") Copy-Item "$Directory\ConfigMgr_Shutdown_Utility.exe" $CopyDirectory -Force Copy-Item "$Directory\ConfigMgr_Shutdown_Utility.vbs" $CopyDirectory -Force } elseif ($IfUserOnBoxText -eq "Cancel Restart/Shutdown") { Get-WmiObject -ComputerName $CompName -class Win32_OperatingSystem | ForEach-Object {$WinDirectory = $_.WindowsDirectory} $ShutdownCommand = "$WinDirectory\ConfigMgr_Shutdown_Utility.exe -arguments /s /t $Delay /Skip /Schtask `"$WinDirectory\ConfigMgr_Shutdown_Utility.exe`"" $CopyDirectory = $WinDirectory.ToLower().replace("c:","\\$CompName\c$") Copy-Item "$Directory\ConfigMgr_Shutdown_Utility.exe" $CopyDirectory -Force } } if ($Error[0]) {$strOutput = "$CompName" + "|Error| " + $Error} else { if ($FreqText -eq "Once") { $Error.Clear() $strTest = & schtasks.exe /create /S "$CompName" /RU SYSTEM /SC ONCE /SD "$StartDate" /ST "$StartTime" /F /TN "$TaskName" /TR "`"$ShutdownCommand`"" if ($Error[0]) {$strOutput = "$CompName" + "|Error| " + $Error} else {$strOutput = "$CompName" + "|Successful"} } elseif ($FreqText -eq "Daily") { $Error.Clear() $strTest = & schtasks.exe /create /S "$CompName" /RU SYSTEM /SC DAILY /SD "$StartDate" /ST "$StartTime" /ED "$EndDate" /Z /F /TN "$TaskName" /TR "`"$ShutdownCommand`"" if ($Error[0]) {$strOutput = "$CompName" + "|Error| " + $Error} else {$strOutput = "$CompName" + "|Successful"} } elseif ($FreqText -eq "Weekly") { $Error.Clear() $strTest = & schtasks.exe /create /S "$CompName" /RU SYSTEM /SC WEEKLY /d "$StartDay" /SD "$StartDate" /ST "$StartTime" /ED "$EndDate" /Z /F /TN "$TaskName" /TR "`"$ShutdownCommand`"" if ($Error[0]) {$strOutput = "$CompName" + "|Error|$Error"} else {$strOutput = "$CompName" + "|Successful"} } elseif ($FreqText -eq "Monthly (On Day)") { $Error.Clear() if ($Modifier -eq "LASTDAY") {$strTest = & schtasks.exe /create /S "$CompName" /RU SYSTEM /SC MONTHLY /MO $Modifier /M * /SD "$StartDate" /ST "$StartTime" /ED "$EndDate" /Z /F /TN "$TaskName" /TR "`"$ShutdownCommand`""} else {$strTest = & schtasks.exe /create /S "$CompName" /RU SYSTEM /SC MONTHLY /MO $Modifier /d $StartDay /SD "$StartDate" /ST "$StartTime" /ED "$EndDate" /Z /F /TN "$TaskName" /TR "`"$ShutdownCommand`""} if ($Error[0]) {$strOutput = "$CompName" + "|Error| " + $Error} else {$strOutput = "$CompName" + "|Successful"} } elseif ($FreqText -eq "Monthly (On Date)") { $Error.Clear() $strTest = & schtasks.exe /create /S "$CompName" /RU SYSTEM /SC MONTHLY /d $StartDay /SD "$StartDate" /ST "$StartTime" /ED "$EndDate" /Z /F /TN "$TaskName" /TR "`"$ShutdownCommand`"" if ($Error[0]) {$strOutput = "$CompName" + "|Error| " + $Error} else {$strOutput = "$CompName" + "|Successful"} } } } else {$strOutput = "$CompName" + "|Off"} Write-Output $strOutput } $ShutdownRestart_Device = { $CompName = $args[0] $strAction = $args[1] $IndexNum = $args[2] $Delay = $args[3] $msg = $args[4] $Directory = $args[5] $psexec = $args[6] $LoggedOnUser = $null $LoggedOnDomain = $null If (test-connection $CompName -count 1 -quiet){ $Error.Clear() if ($strAction -eq "Restart"){ if ($IndexNum -eq 0){ & shutdown.exe /r /f /t $Delay /d p:0:0 /m $CompName /c $msg if ($Error[0]){ $ErrorMsg = $Error[0] $strOutput = $CompName + "|Error|" + $ErrorMsg } else {$strOutput = $CompName + "|Successful|" + $strAction} } elseif ($IndexNum -eq 1){ Get-WmiObject -ComputerName $CompName -class Win32_OperatingSystem | ForEach-Object {$WinDirectory = $_.WindowsDirectory} $CopyDirectory = $WinDirectory.ToLower().replace("c:","\\$CompName\c$") Copy-Item "$Directory\ConfigMgr_Shutdown_Utility.exe" $CopyDirectory -Force Copy-Item "$Directory\ConfigMgr_Shutdown_Utility.vbs" $CopyDirectory -Force $strQuery = "Select * from Win32_Process where Name='explorer.exe'" $SentShutdown = $false Get-WmiObject -ComputerName $CompName -Query $strQuery | ForEach-Object{ if ($_.Name -ne $null){ $SessionID = $_.SessionID $LoggedOnUser = $_.GetOwner().User $LoggedOnDomain = $_.GetOwner().Domain $LoggedOn = "$LoggedOnDomain" + "\" + "$LoggedOnUser" if (!($Error[0])) {$ClearError = $true} & $psexec "\\$CompName" /d /s /i $SessionID wscript.exe "$WinDirectory\ConfigMgr_Shutdown_Utility.vbs" "$WinDirectory\ConfigMgr_Shutdown_Utility.exe" /r /t $Delay /msg "`"$msg`"" | Out-Null if ($ClearError -eq $true) {$Error.Clear()} $SentShutdown = $true $strOutput = $Compname + "|Successful|Gave $LoggedOn a prompt to cancel $strAction" } } if ($SentShutdown -eq $false) { & shutdown.exe /r /f /t $Delay /d p:0:0 /m $CompName /c $msg $strOutput = $CompName + "|Successful|" + "$strAction" } if ($Error[0]) {$strOutput = $CompName + "|Error|" + $Error} } elseif ($IndexNum -eq 2){ $skip = 0 $strQuery = "Select * from Win32_Process where Name='explorer.exe'" Get-WmiObject -ComputerName $CompName -query $strQuery | ForEach-Object{ if ($_.Name -ne $null){ $skip = 1 $LoggedOnUser = $_.GetOwner().User $LoggedOnDomain = $_.GetOwner().Domain $LoggedOn = "$LoggedOnDomain" + "\" + "$LoggedOnUser" $strOutput = $CompName + "|Successful|Skipped - $LoggedOn" } } if ($skip -eq 0){ $Error.Clear() & shutdown.exe /r /f /t $Delay /d p:0:0 /m $CompName /c $msg if ($Error[0]){ $ErrorMsg = $Error[0] $strOutput = $CompName + "|Error|" + $ErrorMsg } else {$strOutput = $CompName + "|Successful|" + "$strAction"} } } } elseif ($strAction -eq "Shutdown"){ if ($IndexNum -eq 0){ & shutdown.exe /s /f /t $Delay /d p:0:0 /m $CompName /c $msg if ($Error[0]){ $ErrorMsg = $Error[0] $strOutput = $CompName + "|Error|" + $ErrorMsg } else {$strOutput = $CompName + "|Successful|" + "$strAction"} } elseif ($IndexNum -eq 1){ Get-WmiObject -ComputerName $CompName -class Win32_OperatingSystem | ForEach-Object {$WinDirectory = $_.WindowsDirectory} $CopyDirectory = $WinDirectory.ToLower().replace("c:","\\$CompName\c$") Copy-Item "$Directory\ConfigMgr_Shutdown_Utility.exe" $CopyDirectory -Force Copy-Item "$Directory\ConfigMgr_Shutdown_Utility.vbs" $CopyDirectory -Force $strQuery = "Select * from Win32_Process where Name='explorer.exe'" $SentShutdown = $false Get-WmiObject -ComputerName $CompName -Query $strQuery | ForEach-Object{ if ($_.Name -ne $null){ $SessionID = $_.SessionID $LoggedOnUser = $_.GetOwner().User $LoggedOnDomain = $_.GetOwner().Domain $LoggedOn = "$LoggedOnDomain" + "\" + "$LoggedOnUser" if (!($Error[0])) {$ClearError = $true} & $psexec "\\$CompName" /d /s /i $SessionID wscript.exe "$WinDirectory\ConfigMgr_Shutdown_Utility.vbs" "$WinDirectory\ConfigMgr_Shutdown_Utility.exe" /s /t $Delay /msg "`"$msg`"" | Out-Null if ($ClearError -eq $true) {$Error.Clear()} $SentShutdown = $true $strOutput = $Compname + "|Successful|Gave $LoggedOn a prompt to cancel $strAction" } } if ($SentShutdown -eq $false) { & shutdown.exe /s /f /t $Delay /d p:0:0 /m $CompName /c $msg $strOutput = $CompName + "|Successful|" + "$strAction" } if ($Error[0]) {$strOutput = $CompName + "|Error|" + $Error[0]} } elseif ($IndexNum -eq 2){ $skip = 0 $strQuery = "Select * from Win32_Process where Name='explorer.exe'" Get-WmiObject -ComputerName $CompName -query $strQuery | ForEach-Object{ if ($_.Name -ne $null){ $skip = 1 $LoggedOnUser = $_.GetOwner().User $LoggedOnDomain = $_.GetOwner().Domain $LoggedOn = "$LoggedOnDomain" + "\" + "$LoggedOnUser" $strOutput = "$CompName" + "|Successful|Skipped - $LoggedOn" } } if ($skip -eq 0){ $Error.Clear() & shutdown.exe /s /f /t $Delay /d p:0:0 /m $CompName /c $msg if ($Error[0]){ $ErrorMsg = $Error[0] $strOutput = $CompName + "|Error|" + $ErrorMsg } else {$strOutput = $CompName + "|Successful|" + "$strAction"} } } } } else {$strOutput = "$CompName |Off"} Write-Output $strOutput } $Rerun_Deployment = { $CompName = $null $CompName = $args[0] $AdvID = $args[1] If (test-connection -computername $CompName -count 1 -quiet){ $Error.Clear() $strQuery = "Select * from CCM_Scheduler_ScheduledMessage where ScheduledMessageID like '" + $AdvID + "%'" $objSMSSchID = Get-WmiObject -Query $strQuery -Namespace root\ccm\policy\machine\actualconfig -computername $CompName foreach($instance in $objSMSSchID){$strScheduleID = $instance.ScheduledMessageID} if ($Error[0]){$strOutput = "$CompName" + "|Error| " + $Error} else { $strQuery = "Select * from CCM_SoftwareDistribution where ADV_AdvertisementID='" + $AdvID + "'" Get-WmiObject -ComputerName $CompName -Namespace "root\CCM\Policy\Machine\ActualConfig" -Query $strQuery | ForEach-Object { $_.ADV_MandatoryAssignments = "True" $_.ADV_RepeatRunBehavior = "RerunAlways" [Void]$_.Put() } $WMIPath = "\\" + $CompName + "\root\ccm:SMS_Client" $SMSwmi = [wmiclass] $WMIPath [Void]$SMSwmi.TriggerSchedule($strScheduleID) if ($Error[0]){$strOutput = "$CompName" + "|Error| " + $Error} else {$strOutput = "$CompName" + "|Successful"} } } else {$strOutput = "$CompName" + "|Off"} Write-Output $strOutput } $CcmEval = { $CompName = $null $CompName = $args[0] $CcmEvalPath = $null If(Test-Connection $CompName -Count 1) { Get-WmiObject -ComputerName $CompName -Class Win32_OperatingSystem | ForEach-Object {$WindowsDirectory = $_.WindowsDirectory} $WindowsDirectory = $WindowsDirectory.replace(":","$") $WindowsDirectory = "\\$CompName\$WindowsDirectory" $TestPath1 = $WindowsDirectory + "\CCM\CcmEval.exe" $TestPath2 = $WindowsDirectory + "\System32\CCM\CcmEval.exe" $TestPath3 = $WindowsDirectory + "\syswow64\CCM\CcmEval.exe" if (Test-Path $TestPath1){$CCMEvalPath = $TestPath1} elseif (Test-Path $TestPath2){$CCMEvalPath = $TestPath2} elseif (Test-Path $TestPath3){$CCMEvalPath = $TestPath3} if ($CcmEvalPath -ne $null) { $Error.Clear() ([WMIClass]"\\$CompName\root\CIMV2:Win32_Process").Create($CcmEvalPath) | Out-Null if ($Error[0]) {$strOutput = "$CompName" + "|Error|" + "$Error"} else {$strOutput = "$CompName" + "|Successful"} } else {$strOutput = "$CompName" + "|Error|" + "$Error"} } else {$strOutput = "$CompName" + "|Off"} Write-Output $strOutput } #>
