Showing results for tags 'Offline ISO'.
    • offline iso ×
Found 1 result
  1. Hi, I am deploying Win 7 operating system, customized with Drivers and Softwares, The installation is going fine, the size of the Image is close to 15GB and i am using a 32 GB USB pendrive for installation. Everytime i have to modify anything on the Task sequence i will have to recreate the imag...
