Showing results for tags 'Remote Control Viewer'.
    • remote control viewer ×
Found 2 results
  1. Hi all, When I connect to workstation through Remote Control Viewer, second user can't to connect to that workstation. How can I change client settings to allow more than one Remote Control Viewer connection ? Thanks
  2. Having an issue with are Helpdesk users when remoting machines they can no longer use the Intel Graphics and Media Control Panel. I think this is do to the driver (Screen Scaper) SCCM uses. We can use the windows tool to change everything but selecting the primary monitor like we could in the Intel...
