Hi guys,
I've got an issue that I'd like to run by you if I may?
I deployed a CAS to a Windows 2008 R2 server and used the default instance on a SQL 2008 R2 SP2 server. This worked just fine with SPNs registered for both FQDN and NETBIOS.
The issue arises when I try to use a named SQL in...
