Showing results for tags 'System Centre'.
O.P. Hey Guys, This is oneof those very long stories which might take me several posts to try and explain in detail. Essentially what my issue is: On boot press F12 to PXE boot IP4 Lan Card. WDS is detected and loads the Pre-Installation environment. I see Task Sequences which have been setup and configured. I created a TaskSequence with Win 10 Pro 64bit with Adobe Package installed. When I click on Win 10 Pro Media Task Sequence it tries to tun for a second. Then it fails and gives me the following error. Error Message: Failed To Run Task Sequence: The Task Sequence failed to run because the program files for PPP000099 cannot be located on a distribution point. For more information please contact your system Administrator or Helpdesk Operator. End of Error message: So I am the poor Administrator trying to grapple my way around SCCM and the finer points of smoothing over ruffled feathers. I have been trying to find a fix for this for the past few days without much success. What I really need is a way to get a Step by Step on how I can resolve this frustrating problem. I understand it's a tall order but a guide would be nice. Okay, so I can see under Task Sequences for "Win10 Pro Media" there is a Distribute content button. WhenI check my Software Deployments for this Operating System Image I can see it's failing to distribute this package. It says there is not enough space or permissions are wrong. I have checked Folder path and directory permissions for SCCMAAA user has complete Administrator permissions. Also I have freed up around 30Gb on E drive with Image Captures on it. But I keep getting this error...with the Distribution Point Image failing to Redistribute. I have tried to look for the SMSTS.log file but I can't locate it, where it's suppose to be. Please Help....
I have written a series on the PowerShell Deployment Toolkit (PDT). However, recently there has been a new addition of a GUI element. Check out the PDT GUI article on my blog here: http://adinermie.wordpress.com/2014/06/14/my-experience-with-the-powershell-deployment-toolkit-pdt-part-4-pdt-gui-for-powershell-deployment-toolkit/ Or check out the beginning of the series here: http://adinermie.wordpress.com/2014/01/26/my-experience-with-the-powershell-deployment-toolkit-pdt-part-1-downloader-ps1/
- PDT
- PowerShell
(and 1 more)
Tagged with:
