Showing results for tags 'Uninstall silent'.
    • uninstall silent ×
Found 1 result
  1. Hi, the process for uninstallation for ALL Office, Visio and Project versions (2007 and 2010) would go like this: create a new .xml file named: "SilentUninstallConfig.xml" and save it in your installation folder or where you want. Populate the file with: <Configuration Product="APPL...
