Showing results for tags 'build and capture'.
    • build and capture ×
Found 19 results
  1. I'm doing a quick build and capture with Windows 10 Build 14393 (1607) in which I have a script that removes some of the default installed apps. It's being done with System Center. In regards to the Contact app, it's now able to be uninstalled as a package. $Packages = (Get-WindowsPackage...
  2. Hello - I'm looking for the best practice regarding the build and capture of Win10 + O365 with SCCM 1702/MDT 2013 Do you think the captured image (Wim) should include the third party apps, or add them in the imaging task sequence ?
  3. I`m trying to capture a Win10 image with Office 365 but my TS is failing. The O365 application installs fine from Software Centre, but failing during OSD. I attached the SMSTS log smsts-20170718-132035.log
  4. I've built a task sequence to build and capture our reference image; windows 10. I have been successful in the build and capture task sequence. I have a couple of application installations built into the task sequence; MS Office 2016 and Chrome. So far so good. The big issue I see with the proce...
  5. I am trying to build and capture a Winddows 7 X64 Image using SCCM 2012 R2 (SP1). I have also installed Cumulative Updates 1 for R2 SP1 and made sure the client Patches CU1 during setup. I have been using Software Updates to clients on the Domain successfully but the OSD is failing to complete wi...
  6. My build and capture for Win10 is failing on 'prepare OS' step. It BSOD with the error System_thread_expection_not_handled. It restarts to the Win10 log in screen. My B&C works fine with 8.1 and I've upgraded to r2 sp1 cu1. MDT 2013 update 1 and USMT 10. this is on a VM and I'm not findin...
  7. Hi All, Trying to build and capture a VM machine. Created a collection, however when trying to build and capture I get the following error 0x00000037 Please can anyone help, I've checked the internet and cant find anything to help. Cheers
  8. I wanted to put this topic in the main CM2012 forum, but I can't, for some reason. That's why it's posted here. Hello, I was really hoping someone could help me with this. Background information: - We have a CM07 server in a production environment. - I've set up a CM12 RTM server, foll...
  9. Hello, Wondering if someone could help me out. I'm trying to do a build and capture including Software Updates. I can do a build and capture (without) Software Updates and everything works fine. But when I include Software Updates, the task bar will just sit there for like 30 minutes...
  10. I have read some blogs about restarting wds but it seems it was stuck at status starting so i could not start the process i uninstall pxe and then reinstalled it and it was still at starting i force the restart and it worked but still can't boot from PXE i have 2012 R2 installed i have here a...
  11. Morning all. I started this thread over on TechNet but I thought it would also benefit me to post it here as well. I've copied the contents here as well. Please let me know if you have seen this and/or have any additional information. Thanks! http://social.technet.microsoft.com/Forums/en-US/ac3143d...
  12. So I finally got the PXE to boot and install the image with updates. However it failed to Capture the image. I created a VM PC for this which the install for the OS and updates took 2 days for some reason, think its my VM because when it loads to windows it takes it sweet time to respond to my c...
  13. Hello, The following has accured: I am trying to build and capture a windows 7 (x64) SP1 on a sccm 2012 server (no SP1 installed). I've build an default task sequence according to the windows-noob "standards" (http://www.windows-n...dows-7-x64-sp1/). But when i try to run the task se...
  14. Hello, I have a build and capture TS that works great for creating my thin-image, however, I would like to somehow interrupt the build and capture at some point and force it to boot into audit mode so I can install some apps that cannot be repackaged or otherwise scripted. Can this be done?...
  15. I am trying to build and capture a Windows 7 Ent x64 System (SCCM 2007 R3) I have created the OS image etc and the TS using the SCCM wizard. When my system reboots at the end of the TS I am greeted with the message: BOOTMGR is missing Press Ctrl+Alt+Del to restart The system I am tr...
  16. I Set up SCCM 2012 RTM, and have been fighting with deploy and capture for a few days. I successfully imported an Operating System Installer I successfully created a task sequence I I was able to get the machine to PXE boot, and it almost loaded windows PE; however, I kept getting the follow...
  17. I just setup SCCM 2007 R3 on a Windows 2008 R2 Server with SQL 2008. The 2008 server is joined to my domain (DC = 2003 running AD, DHCP, DNS). I have followed all the steps here for installation and configuration. I am currently in the process of trying to run a Build and Capture of Windows 7 Ent...
  18. Hi, I have followed the guides found here to setup SCCM 2012 Beta 2, however I have run into a problem when following part 8. The image successfully PXE boots and once I enter the password and click through the dialogs the setup process starts. The setup manages to get to the stage "Setup Win...
