Showing results for tags 'click-to-run'.
    • click-to-run ×
Found 2 results
  1. Hi, I'm in the process of deploying Windows 10 (x64 Enterprise Build 1809) at a customer site using Configuration Manager Current Branch (1806 + Hotfix). Office 365 Click-to-Run is a Tier 1 application that I am installing during deployment of the OS to the endpoint machine. In order to ensure...
  2. Hello, Is there a way to deploy Skype for Business Basic (O365 Click-to-Run) during an Operating System Deployment task sequence? I'm able to deploy O365 Pro Plus with OSD. But if I include Skype in the configuration xml file, the application will not install. I broke Skype out into its own...
