Showing results for tags 'conditional installation'.
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
    • Windows 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Official Forum Supporters
    • Windows News
    • Suggestion box
    • Jobs
    • How do I ?
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Windows Server General
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
Website URL
Location
Interests
Found 1 result
  1. Hi Guys and Gals, Hope this finds you all well, and having a great start to 2013. I had a quick search of the forums, and didnt find anything related Also hit google / bing and found nearly what i am after. I thought I would ask here as someone is bound to have done what i am trying to achieve. I would like to set a condition on some software in my sccm 2012 task sequence to only deploy certain apps if the client is a laptop, and only install some others if it is a desktop. Thus a single task sequence with a bit of logic. At the moment i have 2 task sequences one for laptops and one for desktops. - This is fine, just wanted to know how to do it really. I have located the codes for the chassis type / system enclosure, and locally on my box, have been able to return the chassis type / enclosure type via wmi. I have also seen this is alot easier if you integrate mdt 2012 and use the ISLAPTOP, ISDESKTOP, IS SERVER env vars. I have also seen the "check to see if has a battery >0" example somewhere on google. Using chass/enclosure as the condition is better than battery>0 HOWEVER.... how easy is it to do the same thing without installing MDT I was thinking wmi, but cant seem to get my command prompt syntax to be valid within sccm. Has anyone done this or similar before ? And if so - could you point me in any direction. As always, any help is really appreciated, Thanks and regards, WAZZIE
