Showing results for tags 'configmgr 2012'.
Hi all, Background We’re running SCCM 2012 R2 CU1. It’s a single primary site with a physical Site Server, six virtual distribution points, and a physical SQL cluster. Our physical site server hosts, among other things, the distribution point role and has a 600GB drive for packages and the...
- 1 reply
- sccm
- distribution point
(and 2 more)
Tagged with:
Application requirement / Global Condition issue
stgrdk posted a topic in Configuration Manager 2012
Hi Windows-Noob ppl, I have this problem and I don't know how to solve it. If i want to edit an applications requirement I get the first image no options at all. When I want to set an requirement on a application I get the second image, no options at all. It's like the box is not initia...- 2 replies
- Configmgr 2012
- SCCM 2012
(and 3 more)
Tagged with:
Microsoft released free ebook on Configuration manager 2012 Troubleshooting Guide which will help to understand the key components like components manager,distribution points,SUP and its relative log files and more troubleshooting logs from the real world. more information and download Ebook here
- 2 replies
- free ebook
- troubleshooting Guide
(and 1 more)
Tagged with:
I have SCCM 2012 SP1 setup with MDT integration. I have setup the Software Base Variable to Coalescedapps in the UDI properties. I setup the TS to install as shown below, but it just blows by the stage. I took the default Install Applications sequence from the MDT wizard and added a Run Comma...
- 1 reply
- SCCM 2012
- ConfigMgr 2012
(and 2 more)
Tagged with:
ConfigMgr 2012 not downloading Software Updates
P@docIT posted a topic in Configuration Manager 2012
I setup a test lab using Hyper-V and following the guides here. Everything seems to have gone OK, however I tried deploying software updates to my test client and get what you see in the screenshot below. I tried tracking down a log file that might tell me what is going on however nothing jumped out... -
When I try to deploy windows 8 updates follow Anyweb's guide SCCM 2012 RC Part 6 - Deploying Software Updates, Step Install Software Updates failed with 0X800705B4 while system join workgroup instead of domain. If I config system to join domain everything is fine. I have specified SMSMP=CM01.cor...
- 2 replies
- 0x800705b4
- sccm 2012
(and 4 more)
Tagged with:
Hi, I've been sitting with a problem, whereby no updates go through to computers, although it has synchronized properly, and no errors are shown. I've followed the guides on this site step-by-step, and I get no noticeable errors. If I try to send and update using wsus, it goes through fi...
- 2 replies
- configmgr 2012
- updates
(and 2 more)
Tagged with:
I am trying to enable and activate the TPM chip on the Dell machine's we have. So far I have created the CCTK package, pushed it to my DP, etc, but it keeps failing at setting the BIOS password. I have been unable to get my task sequence to complete. Everything that I have read so far seems to lead...
- 3 replies
- ConfigMgr 2012
- Dell
(and 3 more)
Tagged with:
