Showing results for tags 'configuration baseline'.
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
    • Windows 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Official Forum Supporters
    • Windows News
    • Suggestion box
    • Jobs
  • MDT, SMS, SCCM
    • How do I ?
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Windows Server General
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
Website URL
Location
Interests
Found 4 results
  1. All, I am trying to report on what machines might have a vulnerable chrome extension for Webex. These are stored in the user's profile in app data. I have created a config item and baseline trying %userprofile% but am having no luck. Any direction would be great if you know how I might gather this information for different users on different machines in my environment. Thanks! Rob
  2. Here's a quick resume of the current setup I am using. I've been using AD groups to deploy applications from SCCM with query-based collection membership for devices. In short, this means that in AD a computer is added to a group and whenever SCCM runs AD Group discovery and sees a change, the collection which queries that group also updates that group and the application is deployed on the target computer. This was done in order to preserve the historical AD structure and method of deploying applications (previously done with GPOs). This works flawlessly and is relatively quick. Since we do not have a way to remove applications as of now, I am trying to trigger an uninstall deployment whenever a computer is removed from an AD group. I cannot push an uninstall deployment method on a collection that would include all systems except those that are members of the deployment group since this would break systems with the target application installed before SCCM implementation. There is however something that I have tested with a single application which consists of deploying a configuration baseline to all systems that detects if that particular application is installed. I then create a collection that excludes the "Install target software" collection and queries for compliant computers. I then deploy an uninstall application on the resulting collection therefore uninstall the application from the member systems. It seems to work properly for now. I am using configuration baselines because of their ability to run powershell scripts as part of the compliance process. My question is, is it against best practice to have a lot of configuration baselines? I have around 40+ applications that are deployed through SCCM and it would require the same amount of configuration baselines to ensure application are uninstalled in sync with AD group membership. Thanks.
  3. Hello, We actually use SCCM 2012 R2 to manage our desktops. I noticed that we can do a lot of things with the configurations items and baselines. I would like to know if there is a way to export GPOs in order to import them as configuration baselines in SCCM and also if someone is working with configuration baselines instead of GPO. In general, is there any added value to use CIs instead of GPO ? Thanks in advance
  4. Hi, We have two "Configuration Baselines". ie a baseline of XP and a Baseline of Win7. There are typical software for each baseline and a certain set of about 15-20 softwares are fixed. Hence to deploy a new machine can we create a collection/group of software packages/applications by which i can deploy the whole baseline in one go? These software are not attached and are different to one another say Perforce, VS, Perl,XMLspy etc.
