Showing results for tags 'deploy and capture'.
    • deploy and capture ×
Found 1 result
  1. Hi All, I am having a problem capturing a gold image in SCCM 2007. I have created a build and capture task sequence and the build part of the task sequence completes with no issues however it will not capture the system image after this. Can you please advise what logs I should look at to tr...
