Showing results for tags 'distribution points'.
    • distribution points ×
Found 8 results
  1. team, I have Offices spread about the world with DPs at each of them. I'm cooking with Config Man CB 1702, Single site. 14 internal DPs and 1 internet facing DP. Shiny. Albeit Drivers, Packages or Applications; not every site (office) requires all content I have to offer. I have a single OSD...
  2. O.P. Hey Guys, This is oneof those very long stories which might take me several posts to try and explain in detail. Essentially what my issue is: On boot press F12 to PXE boot IP4 Lan Card. WDS is detected and loads the Pre-Installation environment. I see Task Sequences which have...
  3. I setup about 10 distribution new points that I cloned the content from the old dp and 4 of them have a content status of "distribution manager is waiting for package content to be prestaged". So I verified that the pkgx file is extracted to the new server by manually trying and it told me that the...
  4. Dear, I've created a new security rol in SCCM 2012 R2 for our Servicedesk. They are able to view and add Resources to a collection and redistribute content to their DP's. But the option: Update Distribution Points on a Package is not available for this role, and i can't find the right permi...
  5. Hi There, I am in the middle of a OS refresh of our estate (XP to Windows 7) and many of the sites are running 20+ machines on slow links (20mb or less) and the OS refresh must be ran outside of hours We have a very tight timescale for the OS refresh so i would like to create a protected di...
  6. Complex to me, anyway. We've got two DPGs set up. DPG1 contains all of our existing DPs. It has all software assigned to it. A large portion is set as High Priority packages (don't ask... this is a client and something to fix). Many packages appear to still be replicating. DPG2 is new. We're rep...
  7. In our organization, at the moment we have one primary site, two secondary sites and 8 distribution points (these 8 dist. points are for 8 sites other than the 3 primary&seconday sites). Due to the chatter and bandwidth limitations 8 distribution sites are not the most feasible set up any longer....
  8. Everyone, I want to give you all an insite as to my current setup, and let me know what you think I should do if anything to optimize Performance of my SCCM 2012 sp1 environment: I manage a public school district, containing around 1,800 computers and have one SCCM that handles everything at this...
