Showing results for tags 'edge and mail icons'.
    • edge and mail icons ×
Found 1 result
  1. Hi everyone, if you ever struggled to get the Edge and Mail icons removed from the Taskbar via TS layoutmodification.xml in Windows 10 1703, try this: Dont use "%APPDATA%" in your <taskbar:TaskbarPinList> section of your layoutmodification.xml !! This will not work in your XML: <...
