Showing results for tags 'in-place upgrade'.
    • in-place upgrade ×
Found 3 results
  1. Hi, I had old installation of sccm 2012 r2 sp1 on 2008 r2 with sql 2008 r2 on same server. I wanted to start deploy windows 10 (1703) but it turned out that this version is supported only on newest SCCM 1702. So I have upgraded sccm 2012 to 1606 using baseline media and then to 1610 usin...
  2. I have been tasked with upgrading roughly 800 PCs in my environment from Windows 7 to Windows 10. One problem that I am discovering is that we have multiple versions of Windows 7(Home, Pro and Enterprise). Professional is overwhelmingly most common, tho as we are trying to use bitlocker, we need to...
  3. Microsoft explains that an in-place OS upgrade from Server 2012 to Server 2012 R2 is supported (let's make that clear before someone pulls out the backup / reinstall / site recover copypasta, ok?) for a site server running Config Manager 2012 R2 SP1. So, I did just that, and after wrangling with som...
