Showing results for tags 'not working'.
Hello Windows Noob family! I am attempting to a very basic, nothing crazy refresh from windows 8.1 to windows 10 using SCCM with MDT. I am doing a user driven installation with the latest ADK installation. I create a standard User Driven task sequence. Under the capture user state step I have Capture all user profiles by using standard options selected, with verbose logging and Copy by using file system access - checked continue if some files cannot be captured and capture locally using hard links. Then under Restore User state I am using Restore all captured user profiles with standard options. When kicking off the task sequence from within the OS, I have no trouble managing the wizard... which reboots me into WinPE and begins the image. I watch it run the USMT package which "Processes the User State". When the image is done, the user profiles are not restored, altho - all the data is still there under C:\StateStore. I can browse through that folder and see all the user profiles that were backed up, and all the content is there. It just appears to be skipping, or failing? On the Loadstate portion... I cannot find any scanstate / loadstate logs - and the SMTS.log files don't appear to display any errors. Any thoughts from the gurus here? Thank you!
Hello All We are having an issue with our new SCCM Environment. SCCM was happily working, Deploying OS's, Installing and Uninstalling applications and the other day just stopped Uninstalling applications. It will install but wont remove. We are SCCM 2012 SP1 installed on Server 2008R2 we have a Standalone site and our Collections are populated via Querying AD Groups. Our Install and Uninstall Collections are updating and when we check the deployments within properties on the Device it shows the relevant 'Install' or 'Removal' for the required application. What we have noticed is: Before we had the problem even if we didnt have an application installed, within the Software Centre the application would be listed with a Status of Not Installed - Now it does not. If we delete the deployment and recreate we get the same issue If we delete the collection and recreate and then create a new deployment we get the same issue If we create a new application and create an uninstall deployment on the old collection it works We have looked through a lot of logs and have found some errors, not sure of which to post as not sure what is relevant. Can anyone offer any advice? Many Thanks Mark Jones
