We're currently deploying WIN7 via SCCM 2007 R3 and have a program to run before the task sequence starts the state capture. The program is an "hta" that displays a countdown timer and a custom message to close outlook and get on a wired connection. After the timeout period of 5 minutes, or if a user clicks "ok", the program stops and the task continues.
I'm curious if there's any way I can script and force the wireless to turn off?
