Showing results for tags 'power management'.
    • power management ×
Found 7 results
  1. I have a OSD Task Sequence for Windows 11 22H2 being deployed to new Dell Optiplex 7000's. The Dell's are going to sleep during the "Setup Windows and Configuration Manager" step of the Task sequence. I have checked the "Run as high performance power plan" box in the more options tab, but the PC sti...
  2. Hi There, Is there anyway to set schedule for Start and Shut down client computer? I am trying to create and apply power plans in System Center Configuration Manager, however nothing happen. Here are these step In the Configuration Manager console, click Assets and Compliance....
  3. Microsoft's SCCM has a new feature called "wake up proxy" whereby host a pretends to be host b (host a spoof's the mac address of host when host b goes to sleep. Needless to say, we were seeing tons of mac address flapping and port-security issues. On the client settings that you deploy to your...
  4. Hello, i have implemented power management policy via SCCM 2012. i have configured a customized power plan and applied it to collection, i can see power plan is active on user's system normally. But end user can change the power plan to "balanced" or "power saver" i want to restrict end...
  5. Hello, Does anyone know of a way that the options function can be greyed out or removed from the software center? Or is the only way to control these functions done through Group Policy? We are about to push out SCCM client to all workstations at my company soon and i'm concerned about u...
  6. ====================================================================================================================================================================================== >> Available via download here on the TechNet Galleries! << =======================================================...
  7. Hi All, I want to use powermanagement. I have installed SCCM R3. When I right click on the site and go to properties, it shows: R3 Installed: Yes Build number: 6487 When I click help -> About System Center Configuration Manager the version number is Version: 4.00.6487.2000 I have report...
