Showing results for tags 'rebuild SCCM'.
Issue: Current SCCM 2012r2 has not been able to provide Windows updates since 01/07/2015. History: On 01/07/2015 a predecessor, apparently, installed KB 2734608 and promptly started updates to all the enterprise servers. Of course, they all tried to reboot during business hours. He was instructed to “Stop the process immediately” which he did, and the system has never worked since. There is no documentation as to what he did, what his successors did, or a backup of the application/ server prior to the event. Current configuration: Platform: Windows server 2008 r2 (Updates on this server are current) IIS version 7.0 WSUS is version 3.0 with SP2 (3.2.7600.226) SCCM for manual deployment of 3rd party applications and endpoint protection currently works. Windows Update Services do not synchronize. SQL version 2008r2 (64bit) Endpoint protection, system imaging, 3rd party application deployments/updates work OK. Just WSUS does not work. Hierarchy demands previous content files and packages be retained. Currently have a 2007 SCCM that was updated to 2012, then r2 running on a 2008 server. Since migration to server 2012r2 requires a fully functional SCCM at start, this is not an option. Bottom line is I am faced with a sabotaged system, 18 months of ‘well meaning database programmers’ trying to “fix the WSUS system” and no documentation of who did what. If the entire system had failed this would be easy, but everything works BUT the WSUS. End result should have same site code, content database, and program folder. All comments appreciated.
- 2 replies
- Replace SCCM 2012r2
- rebuild SCCM
(and 1 more)
Tagged with:
