Showing results for tags 'remote control'.
    • remote control ×
Found 9 results
  1. I have problems with remote control. And I don’t understand why it’s working on some computers but others not. Under client settings I have enabled remote tools. The agent on the client the Remote tools agent enabled. The client with the problem: Service: Configuration Manager Remote Co...
  2. Hi I have SCCM 2016 with 1706, the latest version When I have added a new server or client, is always so that Remote Desktop grayed-out. I have set the Client Settings for Remote Control, Se below, How will I do to fix that , so the Client will install CCM to my new server or c...
  3. I have an admin in one of our remote sites who only has access to his boundary. However, he needs access to several specialized systems in a different location's boundary. I have given him access to the collection I created for those specific PC's, but I imagine the limitation here is the boun...
  4. Hi all, I've set up Configuration Manager 2012 in a lab environment and trying to get Remote Control to work. I have pretty much tried everything I can think of at this point but still can't work out why I cannot get Remote Control to connect correctly on any workstations. When launching...
  5. I have a weird issue that I cannot track down. In our environment we keep getting complaints from helpdesk and users that their fonts change after they are remote controlled. Sometimes this happens after the helpdesk disconnects and other when they initially connect to the user via sccm remote con...
  6. Hello I've found out that I have a problem using Remote Control. When I try to connect to managed domain-joined machine the connection hangs up at the "Connecting to the host session" step. After a while a message is logged to RC console "Viewer disconnected". Now the configuration: Win2k8r2...
  7. Hey! I'm new in SCCM and I'm trying the remote control function. is there any way that more than one user will remote control a computer? I haven't find any way to do it... We can do it with CA ITCM and we found it very useful while the Help-desk need some help from tire 2 engineers... What...
  8. SCCM 2012 CU1 - Client CU1 update. When I use "remote control" from SCCM 2012 console the dual monitors get squished to a single monitor on my end. (I have dual monitors as well). How do I enable remote control to take up both monitors I can't find this anywhere. My Machine is Windows 8 wi...
  9. Does anyone know if it is possible to remote control a PC based on the currently logged on user ?? We recently switched from a Novell based network to a Microsoft based network. In the old environment all windows machines were managed using the Zenworks client for Microsoft and cosoleone. I could...
