Showing results for tags 'sccm 2007'.
    • sccm 2007 ×
  1. Hi Everybody, this thread is for those who want the old SCCM 2007 driver management back. Normally you have to import every driver to the database first, put them into a driver package, and then deploy them during OSD. In SCCM 2007 you could easily create a Driver Package from your Driver Sour...
  2. Hi I Want Deploy Windows 10 1606 LTSB with Sccm 2007 Ver 4.00.6487.2000 is it Possibole ??
  3. Hi I Want Deploy Windows 10 1606 LTSB with Sccm 2007 Ver 4.00.6487.2000 is it Possibole ??
  4. Hi, I'm hoping someone can help me. I need to add a condition into a software task sequence so that an uninstall cmd line will only run if a particular piece of software is installed, let's say Adobe Acrobat. Can any helpful soul tell me what syntax I should be using? Will it be different for 64-bi...
  5. Greetings ! i am excited to be part of this! i am new to SCCM 2007! I have machines that are failing to update, i get the following error [with this error status id: 11751] from the WUHandler log: Unable to read existing WUA resultant policy. Error = 0x80070002.... Group policy settings wer...
  6. hello! i have sccm 2007 1. what restrictions are imposed on the organization of remote sessions to a workstation? 2. The maximum number of remote connections through the console sccm 2007 a group of employees (number)? 3. Does the simultaneous connectivity to a single workstation in several s...
  7. Hello, How to do automation document for ConfigMgr 2007 environment. System Center Configuration Manager Microsoft Corporation Version: 4.00.6487.2000 and Windows Server 2008 R2 Standard. Appreciate for quick response. Thanks, Chinna
  8. Can someone help me with a report that shows the individual patch sizes for a deployment? I can't seem to find any view that shows size. Thanks.
  9. Does SCCM 2007 support a creating a distribution pint share on a Windows 2008 R2 Failover cluster file server? I can't find any where that it say's this is not supported. But I can create a Distribution point share on a non clustered file server but when I created this on the clustered server the...
  10. Hi, I have an SCCM 2007 site server which all my clients have the agent. We setup a Eval of SCCM 2012. Well one of the techs turn on automatic client install on the SCCM 2012 server. Now all of the clients have the new client with a new site name. I need to remove all the new agents and re-insta...
  11. I am currently implementing SCCM 2012 and already have SCCM 2007 in place. I have unchecked PXE building in SCCM 2007 and set up PXE building in SCCM 2012 but when I attempt to PXE build on one of our machines it still seems to receive the PXE request from the SCCM 2007 system. If anybody ha...
  12. Hi all a few quick questions. We had a disaster here at that deleted our SCCM server. (VM). Apparently our server team was only backing up the packages folder and nothing else including the VMDK. Anyway, we were about to move to CM2012 so we decided that if were going to rebuild anyway might as...
  13. SCCM 2007 SP2 R3, SQL Server 2008 x64, Windows Server 2008 R2 x64 I am having difficulty with a bare metal install and capture of Win7 on a laptop. I have followed all guides closely and verified correct version of MDT, AIK, WINPE, but I simply cannot inject drivers into my boot image. I keep ge...
  14. Recently went through the process of migrating all our desktop clients to 2012. Curious if anyone has had any experience properly shutting off 2007. From my research, I was planning on uninstalling Config. Mgr. 2007 on the old server, and putting in a ticket to the server team remove the old 2007...
  15. Hi, I have some specific requirement in SCCM 2007 & 2012. I need to create a master patch for Windows 7 machines. When ever any machines formatted and added to the domain, patch should get installed automatically from the master patch list and it should not get expire at any point of time. Is it...
  16. I noticed this past Sunday that servers that received updates are not reporting back into SCCM 2007 and some servers that were scheduled to patched did not receive any updates at all. I am trying to figure out if this could be firewall related or has anyone ever encountered this issue.
  17. Recently a new drive was installed on my remote SCCM 2007 distribution point. This new drive (F:) was larger and had more space on it than my previous drive designated to be used for my packages (D:). After distributing and updating a few packages, I realized (too late) that these files were being...
  18. I'm needing some clarification and assistance here. I'm providing some background as well. This is my first foray in to this process, so the simpler and more thorough the explanations are, the better it will be. We're running Config. Mgr. 2007 in Mixed Mode (can't go Native at this point) in our...
  19. Hello I need some help to figure out why I am not receiving a pop up balloon on XP , I have sccm 2007 r3 set up and it sees the client which is Windows XP Now trying to push out some updates to this machine and the pop up balloon is not appearing not sure what I need and need some help to find...
  20. Hi all, I've been reading articles an topics here that already helped me a lot, but i'm very new here as a members. I'll need your help to set my mind about Active directory group based collections in SCCM 2007. My configuration: Both "AD System Group discovery" and "AD Security Grou...
  21. Is it possible to rollup all of the updates that are required for a server into a setup.exe file? Then export this file in order to install it on a server that is on an isolated network.
  22. i seem to be having trouble getting the task sequence to run on our engineering specific model of desktop, Dell Precision T3600 with Windows 7 x64. they are being ordered with two 500GB drives and for some reason i cant seem to get the task sequence to complete. i did however finally get the machine...
  23. Hi All, I have searched high and low, non-stop for days trying to find an answer. I have finally admitted defeat because I am unable to find the information "out there", as I can normally find "anything" within minutes of searching and so after 3 days, it's fair to say I have been unsuccessful....
  24. Hi There, Our primary site server is constantly sitting on 'install pending' when trying to update distribution points with new package versions. This has been left full days with no effect. The distmgr.log file seems to indicate it has picked up the command to update to a new version number...
  25. Hi everyone, I have got a question on how to cancel a software distribution to a collection. Let me specify. We have 2 collections, servers and workstations. On the root of the workstation collection there are several software packages advertised to run on the collection and on all sub-collections...
