Showing results for tags 'sccm 2007 r3'.
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
    • Windows 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Official Forum Supporters
    • Windows News
    • Suggestion box
    • Jobs
    • How do I ?
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Windows Server General
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
Website URL
Location
Interests
Found 6 results
  1. Hi, while proceeding to clean up the deletion of a child site in SCCM 2007 using "Preinst /Delsite xyz" command, I erroneously typed the wrong site code. This action resulted in a the wrong child site to be removed from the Admin console, although the SCCM files are OK on the site server. Is there a way to recover the child site "xyz" in the database? Thanks, Silvio
  2. Hi everyone I have deploy in some time no problems, I have SCCM 2007 R3. In OSD -> Task Sequence -> Windows 7 2012 Fall -> inside of that TS -> References -> Type: Software package; Name MDT 2010 Files; Package ID NUK00014; Version 1.00 that "MDT 2010 Files" is in SD -> Package -> OS Installation -> MDT 2010 Files and the DP is okey i can find it. when I deploy OS now i choose Task Sequence Wizard and choose "Windows 7 2012 Fall" and its start to deploy but stops and tells me that this Package "NUK00014" is inaccessible even its looks okey, last week i can deploy with no problems has anyone got suggestions ?-) thanks in advance
  3. Hello I run SCCM 2007 R3, we have these new machines from Lenovo and the Company has always using Lenovo. I was trying to deploy OS to new machines but it reboot the machine i never has this problem by it rebooting. So I tried another machine that is not new it doesnt reboot and starts deploy OS. the way i go it goes like this: with old machines starts the PC->press F12->choose network->press F12 again->the WinPE.wim loading->the logo of SCCM shows off and waiting->insert password->choose which OS to install->deploy OS->finish the way it goes wrong: with new machines starts the PC->press F12->choose network->press F12 again->the WinPE.wim loading->the logo of SCCM shows off and waiting->the machine reboot-> :wacko: can someone help me or have this problem, thanks in advance :D best regards Genie from Greenland
  4. Hi, I would like some advice on howto go about upgrading a Live Environment of Sccm 2007 R3 with MDT 2010 integration to MDT 2012. Im using MDT 2012 in are test environment and its working very well and I would like to upgrade the Live Environment without breaking anything. Has anyone done this ? how do I integrate it to sccm 2007 r3 once ive upgraded. Any help would be appreciated. thank you
  5. Hey guys. Im trying to install a secondary site (working with SCCM 2007 R3) which is in a different subnet than its primary. Now the initial setup completes fine (i've checked the configmgr setup log). but then the site remains in peding state. so i check the sender log and this is what I see over and over: sender.txt also i checked the despooler and i see this over and over:despooler.txt So, im confused because i can connect via RDP to the primary server, and i can ping the primary server with its FQDN, so clearly there is something wrong somewhere. i have tried before to manually exchange keys en control file. and then the site did turn active. but i could not push anything to the site because there was still that communication error. then i deleted the secondary site and build it up again but same error, same problem. need help with this!
  6. The patch downloads slowly take place and the majority of downloads only taking place when the deadline is reached in SCCM 2007 R3 .But I want to download the patches at the beginning in just few minutes of time . Is there any way to achieve it ? THANKS,
