Showing results for tags 'sccm 2012'.
    • sccm 2012 ×
  1. Hello, We have created Automatic Deployment Rules and collections for our Software Updates for our servers. In the Software Update collections, we have defined a specific Maintenance Window, which relates to Microsoft's Patch Tuesday as shown in attached graphic. However, we are finding tha...
  2. Hi All, Can anybody help. Currently trying to build a HP probook 650 with Win7 x86, however I get the following error message during the task sequence, when it is applying system settings "windows could not configure one or more system components, to install windows restart the computer...
  3. Hello, Im a bit of a newbie to SCCM so hear goes; I am trying to deploy Windows 8 64 bit to a HP 8470p laptop using UEFI. The build is failing on an error code of 80004001 or (0x80004001) I have attached a screen shot of the task sequence editor that I am using at the bottom of the page....
  4. Hi Everybody, this thread is for those who want the old SCCM 2007 driver management back. Normally you have to import every driver to the database first, put them into a driver package, and then deploy them during OSD. In SCCM 2007 you could easily create a Driver Package from your Driver Sour...
  5. I've got an SCCM 2012 installation. hardware inventory is running correctly (for the most part). Resource explorer is reporting back on physical hardware but no installed software is showing up. I've followed guidance from several KB articles but the issue is not resolved. After doing the following...
  6. Hi! Yesterday I tried to create a distribution point on a Windows 7 Enterprise SP1 x86 machine because on SCCM 2007 we have about 110 small locations with a BDP. So we need this feature in 2012, too. I clicked through the wizard to add a new site system but on the Windows 7 machine nothing happens....
  7. Having trouble pulling the mapped network printers for a user; here’s what I have done so far: On a test computer ran the attached (zipped) SCCM_REGINI.txt (with regini.exe) to build a registry structure to pull the users network printers (from the CURRENT_USER hive) to a hive called SCCMINV (in...
  8. Hi all, So we are in the process of switching to Configuration Manager 2012 and we are now having MANY instances of WMI corruption on user workstations. The OS we are deploying is Win 7 SP1. Symptoms: -Keeping users from logging in (heavily delayed or not at all), spinning at the blue login scree...
  9. Hello everyone, I have to install several computers that will not be inside our domain or in our network. It is possible to install the sccm client so that I can report the inventory to those computers connected to the internet. Thank you very much.
  10. Dear Admin, My Apologize - I feel to raise this Question separately to make myself clarity on asking question and getting answer, As per the previous post, Phase I : Upgrade from SCCM 2012 SP2 to SCCM CB V1606 At Present, the Environment is having as below and mentioned with To...
  11. Dear Experts, My Sincere thanks for your extended support and great mentorship with System Center Products I am trying to Perform the Build and Capture and Unable to do getting an error Very Shortly - We are planning to upgrade the Environment from SCCM 2012 SP2 to SCCM CB 1702 (Upgra...
  12. Hei ho, I wonder if anyone can help me with this strange error. I have followed the the instructions here to a tee to install a test of SCCM 2012 but have hit a strange error - Config. Manager cannot connect to the site. And this has me perplexed as the account I am using has full domain...
  13. I have deployed a task sequence available via SCCM 2012 (latest build) for install to upgrade windows 10 1511 or 1607 to 1703. The task sequence on windows surfaces and Lenovos work however, when I run them on HP I get Insufficient Permission for Software installation. The HP are are in the same co...
  14. How can you quickly figure out what collections are associated with a Computer? I am trying to figure out what policies are being given higher priority by viewing what collections they are associated with. Does anyone know how to find this information?
  15. We recently had a situation where a SCCM patch broke our imaging capability. After weeks, I finally found the solution. My boss asked if there was a way to have a secondary server that we didn't patch, for availability in case we have this problem again. I suspect that in this particular sit...
  16. Hello WN community! I have a bit of stumper I was hoping to get some feedback on! Let me know what you think... Scenario: We're running SCCM 2012 now for a little over a year, problem free. We've noticed however, that randomly (about 10 out of 1000 clients) the SCCM Client is reporting that the...
  17. I have problem with installation of SCCM 2012 with SQL Server 2008 R2 Sp2 (no cumulative updates) installed on the failover cluster. On cluster I create sysadmin for SQL and this user is local administrator. with this user I installing SCCM: I got this message: <11-16-2012 03:31:40> ERROR: Fail...
  18. Hi All we work offline without internet connection NAT only and i want to know what is the best practice for Sccm and Windows 10 ( LTSB OR CB OR CBB Enterprise )
  19. Morning All, I have a Windows 10 Task Sequence for a standalone laptop which I need to encrypt with Bitlocker as part of the OSD build. The machine encrypts with bitlocker fine but I cannot find a way to export the recovery key either to a network share (with appropriate credentials) or t...
  20. Hi All We have upgraded to SCCM 2012 1702 with hotfix KB4019926 installed, everything seems to have installed fine. I am using the pre-production client which appears to be working a treat and turned my attention to OSD task sequences to test the new client on a build. The task sequen...
  21. While I've been working with SCCM for over 6 years I have what's probably a "newbie" question. Is it ok to import drivers while current task sequences are running that deploy operating systems to clients? I won't be editing the task sequences just importing new model drivers (we do use auto apply)...
  22. Hello Everyone, I have an interesting problem. I have an OSD to deploy Windows 7 in SCCM 2012 SP1 that works perfectly, expect when imaging one model of laptop. The OSD fails to join the domain, I check the logs in Windows\Panther\UnattendGC on the laptop and they say that the laptop is una...
  23. I took over for our sccm admin who left and we have a CAS and 2 primaries one primary is for VM infrastructure . I'm trying to do updates and I am successful on your desktop primary but I can't seem to get them to go on the second primary where the VM's live . They all have clients installed and ar...
  24. Is there a way to generate a report for All microsoft products and usage? I cant find one in the reports for something like that
  25. Hello Folks, I am running into SCCM compliance issue. I have deployed one power shell script to 25 machines(pilot group), 24 machines are successfully installed(95%) and 1 machine got failure as per compliance status but Got error 16 and script got stopped when I check logs on 17 client machin...
