Showing results for tags 'sccm 2012 sp1'.
I'm tryin to setup the report services point site system role on my SCCM 2012 SP1 primary site. However when I get the configuring the settings the "Reporting Services server instance" is blank, and I'm not able enter anything inside that box. I verified my reporting services configuration manager t...
- 10 replies
- sccm 2012 SP1
- reporting server
(and 1 more)
Tagged with:
Hi All, Been a while !! I have a production SCCM system in place, and seem to have inherited sole responsibility for all sccm matters. this is fine, however recently I was asked to create some standalone media, which again in itself is an easy task. Upon trying to create this, via the gui me...
- 2 replies
- cert
- sccm 2012 sp1
(and 1 more)
Tagged with:
Yesterday we found that one of our DPs was not receiving packages, so we started digging around to find out why. In the process I discovered that the DP did not have the Software Update Point role installed. "Great!" Nobody who has access has admitted making any changes to the system, of course....
I already Installed SCCM 2012 sp1 successfully, but when i'm trying to give access to different user i'm getting below error. The user account running the Configuration Manager console has insufficient permissions to read information from the Configuration Manager site database. The account must be...
- 5 replies
- SCCM 2012 sp1
- DCOM
(and 1 more)
Tagged with:
Hello, I have inherited a SCCM environment and I need to configure reporting services for an asset manager internally. It looks like the current install is a bit broken as when we browse the website internally we get the attached site. reporting We can run reports from the SCCM console ok ho...
Hello, I need help. 1 month ago I configure Application Catalog and deploy a lot of application w icon, description and othe beautiful things. But 2 days ago I want add one more application and discover something strange. Application didn't appear in the AC. Ok, it was end of day, and I went home....
Hey Guys, I am in the need of a query , report or script that will generate a list of all of the applications that use a specific version of Java. I've used report Software 01A and as it does give me all of the versions of software I need to know what applications actually have a dependency...
Hey guys, I am fairly new to the world of SCCM Administration (4 months), but I have maintained fairly well. There is one aspect that I would like to get a better grasp on and that is creating custom queries. An example of a job that I have been tasked with is finding all versions of Java in...
After upgrading to SP1 I can no longer schedule Windows updates on an operating system image. The Scheduled Updates Status goes from "Processing", to "Failed to mount the image on the system". This feature did work prior to upgrading to SP1. I have made sure that Endpoint Protection has C:\ConfigM...
Hi, I have a stand alone Primary Site... I want to have High availability, because we have a datacenter in another city. The two site are one subnet, linked by Gb/s fiber link. When i look on internet, it seems there is no real possibility to have high availability for SCCM 2012 SP1?? Am...
I am trying to figure out how to remedy a bunch of expired Microsoft updates (1,000+) that Is showing up in my SCCM console after I ran my first sync once WSUS and SUP was installed. Below are the steps take so far: Removed SUP role from my site server (SCCM) Removed WSUS from Server 2012 Resta...
- 2 replies
- application management
- Software updates
(and 3 more)
Tagged with:
Hello all I just finish configuring WSUS and my SUP on my SCCM server but seem to have made an error in judgment. During the setup of the SUP I was given the option to select which software updates to received form Microsoft: Security, Critical, Office etc. Well I selected one called updates...
- 4 replies
- SCCM 2012 sp1
- software updates
(and 1 more)
Tagged with:
I am testing to different models in my environment to move from SCCM 2007 R3 to SCCM 2012 SP1. I have run into an issue do to SCCM 2012 boot wim's are windows 8. We have some intel p4's that we have and they do not support the boot wim of windows 8. I took the x86 boot wim that I had from the sccm...
We are looking at deploying Windows 8 via SCCM 2012 to a load of Tablets. We are currently doing the deployments over the wired network but it would be great if we could connect to the wireless network during the OSD so the machines always connect to it when on allowing first time domain login to be...
- SCCM 2012 SP1
- Wireless
(and 1 more)
Tagged with:
I was wondering if anyone had a link that explains how to deploy Windows 2008 R2 Server using SCCM 2012 SP1. I'd like to be able to install certain Windows 2008 R2 roles (file sharing, printing, dfs, etc) and features (branchcache, snmp, etc) with SCCM 2012. I've looked around, but mainly I find...
- 2 replies
- windows 2008 R2
- OSD
(and 2 more)
Tagged with:
Windows server 2012 as DP TS error 80070002
Kerimrasmop posted a topic in Configuration Manager 2012
I have got the following problem with OSD in SCCM 2012 SP1. TS OSD works without problems on distribution points into primary or secondary sites and DP with Windows server 2008 R2 OS, the problem, however, occurs at the DP with OS Windows 2012 TS downloaded boot image and then restart in Win PE but...- 1 reply
- SCCM 2012 SP1
- DP
(and 2 more)
Tagged with:
Hi all, I am currently getting error in SCCM 2012 for SMS_POLICY_PROVIDER as per attached picture. Can someone help me to solve this issues. I cannot create any software update groups in SCCM getting following error (please find attached picture Untitled1)
I'm running SCCM 2012 SP1 and here's what I'm trying to achieve. I'm trying to deploy Windows 7 x64 SP1 updates via the same task sequence that deploys the OS. What I've done: Task sequence works and it targets the All Unknown Computers device collection Created a Scan For Updates task Crea...
- 4 replies
- updates
- task sequence
(and 2 more)
Tagged with:
The Cumulative Update 1 for System Center 2012 Configuration Manager Service Pack 1 KB2817245 has been released. http://support.microsoft.com/kb/2817245 contains the fixes, updates, and the request link for the hotfix which is approximately 59 MB.
- 2 replies
- SCCM 2012 SP1
- CU1
(and 1 more)
Tagged with:
I'm in the process of configuring boundary groups for site assignment, but I want to ensure that each boundary in my boundary group is not a member of another boundary group with a different site assignment. I currently have a SCCM 2007 source hierarchy in our environment, which have a separate...
- sccm 2012 SP1
- boundaries
(and 1 more)
Tagged with:
So we're in this waiting game along with everyone else who still has that odd number of older workstations that they need to provide support for, and hoping that someone will come up with a solution to the issue. While going over some different threads, I ran across the mention of running WDS in...
I am currently using SCCM 2012 SP1 RTM on server 2012. My trouble is PXE boot is not working. It go through the pxe process and see the pxe server and connects it tries to boot from both. I have included images of what i am getting. I know i might have left some things out any help would greatly app...
