Showing results for tags 'scom 2012'.
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
    • Windows 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Official Forum Supporters
    • Windows News
    • Suggestion box
    • Jobs
    • How do I ?
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Windows Server General
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
Website URL
Location
Interests
Found 4 results
  1. HI Everyone, We recently migrated some servers from SCOM 2007 to SCOM 2012. In that 3 servers were in PCI zone [ under Firewall ] . So we installed the SCOM 2012 agent manually in those servers and restarted the services. But in the SCOM 2012 console we could see the servers is in NOT MONITORED status. Kindly help me how can I get SCOM monitoring the servers from the firewall servers. Regards, Gowri Shankar
  2. Hi , I have installed Scom 2012 in my environnement , i wanna have a report of all the access to my server . So i found a post in this forum about how to install ACS (amazing guide) , i install it. My problem is when i try to generate any report , i got an error message telling me that it's impossible to create a connexion with the datasource 1. Thank you and sorry for my bad english.
  3. Hello, I have 4 domains being monitored under SCOM. I have a very weird problem as every now and then one of the domains (always the same one), appears as offline (by domain, i mean all the servers that are in the domain). Evey time this happens, i check all servers, and they are absolutely fine. I can ping them, RDP, nothing in the event logs etc. It comes back after a couple of hours on it's own... Do you have any ideas? Which log should i be looking into? Thank you in advance! PS. I am a newbie in SCOM so please "be simple" in your answers
  4. I've been searching for a definitive answer, and also checked on technet. So does anyone know is SCOM 2012 supported with SQL 2012 SP1? I know SCOM 2012 SP1 is supported, just can't verify if SCOM 2012 is. Thanks, Paul
