Showing results for tags 'servicing plan'.
    • servicing plan ×
Found 2 results
  1. I just upgraded to 1703 using a Servicing Plan in SCCM, however I lost all the pinned program from the Start menu. Also, I had to re-install the RSAT update. Wondering if you anyone had the same issue? Thanks,
  2. Hello, I was wondering if there is a way to set a servicing plan deployment to Available instead of Required, so the users can trigger it manually. Also I'm missing the "Upgrade to Windows 10 1703" , all the upgrades available are for 1511 and 1607 ,any idea why?
