eddrogers84 Posted February 19, 2014 Report post Posted February 19, 2014 Hi All I am pleeding for a little guidance. I am in the process of putting together a new image for the educational establishment that I work for. Our setup is a single site server running Win 20012 R2 with SQL 2012 and SCCM 2012 R2. The server is running on V-Sphere 5.1 Everything has been working fine until I hit the deployment of windows 7 > joining domain > installing apps/packages I have had this working on an older version of Windows/SCCM 2012 however, that server was setup incorrectly and was causing more harm than good. Thus leading me to create a new server with the above config. The OS seems to be installing perfectly as well as the joining of the domain. I have deleted all apps and OS images/installers and recreated them many times. I have also distributed and re-distributed everything. The Network Access account verifies perfectly Please see the attached smsts.log from a machine and the basic task sequence. I am aware there are errors, I am looking for a solution to these errors. Should I look at using a MDT TS instead of the standard SCCM TS? 90% of the time I get the error Code 0x80004005 (It usually errors on the install of Office 2013) Any advice would be highly appreciated. PLEASE Many Thanks Edd smsts.log smsts-20140219-162335.log Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted February 19, 2014 Report post Posted February 19, 2014 It seems to be an issue with retrieving the MP, something I see a lot lately... Usually the solution, well actually workaround, is in increasing the time-out in a task sequence after it fails to retrieve the MP. Specifically for this, you can use the variable SMSTSMPListRequestTimeout. Quote Share this post Link to post Share on other sites More sharing options...
eddrogers84 Posted February 20, 2014 Report post Posted February 20, 2014 Thank you Peter. I shall give this a go now. Would you happen to know weather this variable is in seconds or minutes? Can anyone see any other issues? Would like to get this out of the way. Thanks Quote Share this post Link to post Share on other sites More sharing options...
eddrogers84 Posted February 20, 2014 Report post Posted February 20, 2014 Sadly this doesn't appeared to have worked. I have added it to the TS before the Office install. Is this correct or should I be adding it else where? Thanks Quote Share this post Link to post Share on other sites More sharing options...
shadycat Posted February 21, 2014 Report post Posted February 21, 2014 I was getting the exact same problem with error code 0x80004005, i have the book "Deployment Fundamentals - Volume 4" which mentions the error and it also says MDT has no clue, that's it, no solution. I eventually opted to deploy the office 2013 installation after the OS deployment which works fine, same deployment package. I would be interested if anyone has a work around for this too. Quote Share this post Link to post Share on other sites More sharing options...
