I am using SCCM 2012 sp1 cu 3 on a single primary Windows 2008 server with SQL 2008 sp2. the problem I am having is I have built a Windows 7 64 bit thick image and that was cpatured up to our server just fine but when I try to distribute the wim to the DP, it is stuck in progress.
I have made sure the folder permissions were fine, to the best of my knowledge, deleted the folder and made a different folder, checked its permissions, looked through the distmgr.log, despool.log, and sender.log and can't find any reference to the Image ID in any of those logs. Also tried deleting the wim in SCCM Console and re-dsitributing it to no avail. The server can see all of the details of the wim, but will not send it to the DP....which is the same server. The wim properties are set to Automatically download the content and the account I am using has full control permissions to the folder, the file, and is the account I use for deploying updates etc. Any ideas?
