StefanT
Add Operating System installer problem on SCCM 2012 R2
Just upgraded from SCCM 2012 to SCCM 2012 R2 including WADK 8.1.
Every time I want to add a Operating System Installers (win 7 / win 8 / win 8.1) I get the following error message: "The specified path does not contain a valid operating system or you do not have permission to access it. Specify a valid path"
I am searching now for 2 days for a solution but can't find is. This is very frustrating...
So far I have done the following:
Installed WADK multiple times
Checked security multiple times
create new share and security
checked wim file (it is ok, can be mounted by the windows tool)
When I install an Operating System Images it also produces the same error message, but when I wait a few minutes than it works....
Does anyone know what the problem is here...?
With kind regards,
StefanT
