carlux
State Migration Point not working
Hi to all. I've a problem with an State Migration Point at one of our Primary sites (see attached File). I found some Information already in the internet, but all (settings rights for User and so on) didn't solved the problem. Any ideas here? the environment is : Windows 2003 Server SP2, SCCM r2
Thanks to all for your help.
Regards
Carsten
SMP.bmpFetching info...
6 answers to this question
is the port 80 listed in the log the correct one that iis is listening on ? have you tried uninstalling the SMP and reinstalling it ?
some info from Technet on USMT SMP http://technet.microsoft.com/en-us/library/bb693655.aspx
Hi anyweb,
sorry for late answer. Where could I checked with port is setup to listen?
IIS is a requirement for SMP, so check the server the the SMP is installed on and verify what port(s) IIS is configured to listen on
