ptotham
Help Please
I am new to sccm 2012 have some experience of sccm 2007,
My Test server setup at the moment is Server 2012 which is the DC running the SQL and SCCM 2012, I know not the ideal setup but this is jsut for testing.
My Task sequence is set to build a machine using "Apply Operating System From Original Installer Source" I have have everything copied to the DP but when the ts runs is spends a bit of time formatting the HDD and then flys through the other steps and then reboots leaving me with no error codes could some have a look at the log file attach and advise me as to wear I am going wrong.
<![LOG[LOGGING: Finalize process ID set to 732]LOG]!><time="13:07:29.745+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="736" file="tslogging.cpp:1495">
<![LOG[==============================[ TSBootShell.exe ]==============================]LOG]!><time="13:07:29.745+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="736" file="bootshell.cpp:1052">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\x64\1033\TSRES.DLL']LOG]!><time="13:07:29.745+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="736" file="util.cpp:963">
<![LOG[Debug shell is enabled]LOG]!><time="13:07:29.745+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="736" file="bootshell.cpp:1063">
<![LOG[Waiting for PNP initialization...]LOG]!><time="13:07:29.792+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="748" file="bootshell.cpp:60">
<![LOG[RAM Disk Boot Path: NET(0)\SMSIMAGES\SPF00005\BOOT.SPF00005.WIM]LOG]!><time="13:07:29.792+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="748" file="configpath.cpp:186">
<![LOG[booted from network (PXE)]LOG]!><time="13:07:29.792+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="748" file="configpath.cpp:201">
<![LOG[Network(PXE) path: X:\sms\data\]LOG]!><time="13:07:29.792+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="748" file="configpath.cpp:203">
<![LOG[Found config path X:\sms\data\]LOG]!><time="13:07:29.792+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="748" file="bootshell.cpp:545">
<![LOG[booting from removable media, not restoring bootloaders on hard drive]LOG]!><time="13:07:29.792+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="748" file="bootshell.cpp:579">
<![LOG[X:\sms\data\WinPE does not exist.]LOG]!><time="13:07:29.792+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="748" file="bootshell.cpp:596">
<![LOG[X:\_SmsTsWinPE\WinPE does not exist.]LOG]!><time="13:07:29.792+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="748" file="bootshell.cpp:610">
<![LOG[Executing command line: wpeinit.exe -winpe]LOG]!><time="13:07:29.792+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="748" file="bootshell.cpp:857">
<![LOG[The command completed successfully.]LOG]!><time="13:07:40.779+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="748" file="bootshell.cpp:939">
<![LOG[starting DNS client service.]LOG]!><time="13:07:40.779+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="748" file="bootshell.cpp:663">
<![LOG[Executing command line: X:\sms\bin\x64\TsmBootstrap.exe /env:WinPE /configpath:X:\sms\data\]LOG]!><time="13:07:41.293+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="748" file="bootshell.cpp:857">
<![LOG[The command completed successfully.]LOG]!><time="13:07:41.293+480" date="03-05-2014" component="TSBootShell" context="" type="1" thread="748" file="bootshell.cpp:939">
<![LOG[==============================[ TSMBootStrap.exe ]==============================]LOG]!><time="13:07:41.402+480" date="03-05-2014" component="TSMBootstrap" context="" type="1" thread="520" file="tsmbootstrap.cpp:1129">
<![LOG[Command line: X:\sms\bin\x64\TsmBootstrap.exe /env:WinPE /configpath:X:\sms\data\]LOG]!><time="13:07:41.402+480" date="03-05-2014" component="TSMBootstrap" context="" type="0" thread="520" file="tsmbootstrap.cpp:1130">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\x64\1033\TSRES.DLL']LOG]!><time="13:07:41.402+480" date="03-05-2014" component="TSMBootstrap" context="" type="1" thread="520" file="util.cpp:963">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\x64\TSRESNLC.DLL']LOG]!><time="13:07:41.402+480" date="03-05-2014" component="TSMBootstrap" context="" type="1" thread="520" file="resourceutils.cpp:169">
<![LOG[Adding SMS bin folder "X:\sms\bin\x64" to the system environment PATH]LOG]!><time="13:07:41.417+480" date="03-05-2014" component="TSMBootstrap" context="" type="0" thread="520" file="tsmbootstrap.cpp:963">
<![LOG[PXE Boot with Root = X:\]LOG]!><time="13:07:41.417+480" date="03-05-2014" component="TSMBootstrap" context="" type="1" thread="520" file="tsmbootstrap.cpp:1062">
<![LOG[Executing from PXE in WinPE]LOG]!><time="13:07:41.417+480" date="03-05-2014" component="TSMBootstrap" context="" type="1" thread="520" file="tsmbootstrap.cpp:1077">
<![LOG[Loading TsPxe.dll from X:\sms\bin\x64\TsPxe.dll]LOG]!><time="13:07:41.417+480" date="03-05-2014" component="TSMBootstrap" context="" type="0" thread="520" file="tsmbootstraputil.cpp:1320">
<![LOG[TsPxe.dll loaded]LOG]!><time="13:07:41.433+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tsmbootstraputil.cpp:1330">
<![LOG[Device has PXE booted]LOG]!><time="13:07:41.433+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tspxe.cpp:122">
<![LOG[Variable Path: \SMSTemp\2014.03.05.10.55.26.0008.{0E5C83DB-85AD-4344-A5EC-9CD47416D44A}.boot.var]LOG]!><time="13:07:41.433+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tspxe.cpp:134">
<![LOG[succesfully added firewall rule for Tftp]LOG]!><time="13:07:41.449+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="fwopen.cpp:123">
<![LOG[Executing: X:\sms\bin\x64\smstftp.exe -i 10.100.43.50 get \SMSTemp\2014.03.05.10.55.26.0008.{0E5C83DB-85AD-4344-A5EC-9CD47416D44A}.boot.var X:\sms\data\variables.dat]LOG]!><time="13:07:41.449+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tspxe.cpp:177">
<![LOG[Command line for extension .exe is "%1" %*]LOG]!><time="13:07:41.527+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="commandline.cpp:228">
<![LOG[set command line: "X:\sms\bin\x64\smstftp.exe" -i 10.100.43.50 get \SMSTemp\2014.03.05.10.55.26.0008.{0E5C83DB-85AD-4344-A5EC-9CD47416D44A}.boot.var X:\sms\data\variables.dat]LOG]!><time="13:07:41.527+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="commandline.cpp:731">
<![LOG[Executing command line: "X:\sms\bin\x64\smstftp.exe" -i 10.100.43.50 get \SMSTemp\2014.03.05.10.55.26.0008.{0E5C83DB-85AD-4344-A5EC-9CD47416D44A}.boot.var X:\sms\data\variables.dat]LOG]!><time="13:07:41.527+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="520" file="commandline.cpp:827">
<![LOG[Process completed with exit code 0]LOG]!><time="13:07:41.636+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="520" file="commandline.cpp:1123">
<![LOG[succesfully removed firewall rule for Tftp]LOG]!><time="13:07:41.651+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="fwopen.cpp:146">
<![LOG[successfully downloaded pxe variable file.]LOG]!><time="13:07:41.651+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="520" file="tspxe.cpp:187">
<![LOG[we are booted using PXE]LOG]!><time="13:07:41.651+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="520" file="tsmediawizardcontrol.cpp:2629">
<![LOG[we are booted using PXE and we don't use a password or the password is provided by the user]LOG]!><time="13:07:41.651+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="520" file="tsmediawizardcontrol.cpp:2645">
<![LOG[Found network adapter "Broadcom NetLink Gigabit Ethernet" with IP Address 10.100.43.100.]LOG]!><time="13:07:41.651+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tsmbootstraputil.cpp:474">
<![LOG[Run PXE Interactive]LOG]!><time="13:07:41.651+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tsmediawizardcontrol.cpp:2780">
<![LOG[Running Wizard in Interactive mode]LOG]!><time="13:07:41.651+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="520" file="tsmediawizardcontrol.cpp:2782">
<![LOG[Loading Media Variables from "X:\sms\data\variables.dat"]LOG]!><time="13:07:41.667+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="520" file="tsremovablemedia.cpp:322">
<![LOG[CryptDecrypt (hKey, 0, 1, 0, pData, &dwDecryptedLen), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\smscrypt\windes.cpp,165)]LOG]!><time="13:07:41.667+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="windes.cpp:165">
<![LOG[sMS::Crypto::DES::DecryptBuffer( (BYTE*)pszPassword, (DWORD)(wcslen(pszPassword)*sizeof(WCHAR)), encryptedBuffer.getBuffer(), (DWORD)encryptedBuffer.size(), pbDecryptedBuffer, dwDecryptedBufferSize ), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\tscore\tsremovablemedia.cpp,387)]LOG]!><time="13:07:41.667+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tsremovablemedia.cpp:387">
<![LOG[Activating Welcome Page.]LOG]!><time="13:07:41.667+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tsmediawelcomepage.cpp:131">
<![LOG[Loading bitmap]LOG]!><time="13:07:41.683+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="520" file="tsmbootstrap.cpp:1228">
<![LOG[WelcomePage::OnWizardNext()]LOG]!><time="13:10:04.370+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tsmediawelcomepage.cpp:340">
<![LOG[Loading Media Variables from "X:\sms\data\variables.dat"]LOG]!><time="13:10:04.370+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="520" file="tsremovablemedia.cpp:322">
<![LOG[CryptDecrypt (hKey, 0, 1, 0, pData, &dwDecryptedLen), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\smscrypt\windes.cpp,165)]LOG]!><time="13:10:04.370+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="windes.cpp:165">
<![LOG[sMS::Crypto::DES::DecryptBuffer( (BYTE*)pszPassword, (DWORD)(wcslen(pszPassword)*sizeof(WCHAR)), encryptedBuffer.getBuffer(), (DWORD)encryptedBuffer.size(), pbDecryptedBuffer, dwDecryptedBufferSize ), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\tscore\tsremovablemedia.cpp,387)]LOG]!><time="13:10:04.370+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tsremovablemedia.cpp:387">
<![LOG[Verifying media password.]LOG]!><time="13:10:04.370+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="520" file="tsmediawizardcontrol.cpp:271">
<![LOG[spawned thread 1012 to download policy.]LOG]!><time="13:10:04.432+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="520" file="tsmediawelcomepage.cpp:405">
<![LOG[Entering TSMediaWizardControl::GetPolicy.]LOG]!><time="13:10:04.432+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tsmediawizardcontrol.cpp:527">
<![LOG[Creating key 'Software\Microsoft\SMS\47006C006F00620061006C005C007B00350031004100300031003600420036002D0046003000440045002D0034003700350032002D0042003900370043002D003500340045003600460033003800360041003900310032007D00']LOG]!><time="13:10:04.432+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="environmentscope.cpp:284">
<![LOG[Environment scope successfully created: Global\{51A016B6-F0DE-4752-B97C-54E6F386A912}]LOG]!><time="13:10:04.432+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="environmentscope.cpp:659">
<![LOG[Creating key 'Software\Microsoft\SMS\47006C006F00620061006C005C007B00420041003300410033003900300030002D0043004100360044002D0034006100630031002D0038004300320038002D003500300037003300410046004300320032004200300033007D00']LOG]!><time="13:10:04.432+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="environmentscope.cpp:284">
<![LOG[Environment scope successfully created: Global\{BA3A3900-CA6D-4ac1-8C28-5073AFC22B03}]LOG]!><time="13:10:04.432+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="environmentscope.cpp:659">
<![LOG[setting LogMaxSize to 1000000]LOG]!><time="13:10:04.432+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:555">
<![LOG[setting LogMaxHistory to 1]LOG]!><time="13:10:04.432+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:556">
<![LOG[setting LogLevel to 0]LOG]!><time="13:10:04.432+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:557">
<![LOG[setting LogEnabled to 1]LOG]!><time="13:10:04.432+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:558">
<![LOG[setting LogDebug to 1]LOG]!><time="13:10:04.432+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:559">
<![LOG[uEFI: false]LOG]!><time="13:10:04.432+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:569">
<![LOG[Loading variables from the Task Sequencing Removable Media.]LOG]!><time="13:10:04.432+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:584">
<![LOG[Loading Media Variables from "X:\sms\data\variables.dat"]LOG]!><time="13:10:04.432+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsremovablemedia.cpp:322">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\x64\1033\TSRES.DLL']LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="util.cpp:963">
<![LOG[setting SMSTSMP TS environment variable]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:604">
<![LOG[setting _SMSMediaGuid TS environment variable]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:604">
<![LOG[setting _SMSTSBootMediaPackageID TS environment variable]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:604">
<![LOG[setting _SMSTSHTTPPort TS environment variable]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:604">
<![LOG[setting _SMSTSHTTPSPort TS environment variable]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:604">
<![LOG[setting _SMSTSIISSSLState TS environment variable]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:604">
<![LOG[setting _SMSTSLaunchMode TS environment variable]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:604">
<![LOG[setting _SMSTSMediaPFX TS environment variable]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:604">
<![LOG[setting _SMSTSPublicRootKey TS environment variable]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:604">
<![LOG[setting _SMSTSSiteCode TS environment variable]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:604">
<![LOG[setting _SMSTSSiteSigningCertificate TS environment variable]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:604">
<![LOG[setting _SMSTSUseFirstCert TS environment variable]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:604">
<![LOG[setting _SMSTSx64UnknownMachineGUID TS environment variable]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:604">
<![LOG[setting _SMSTSx86UnknownMachineGUID TS environment variable]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:604">
<![LOG[Root CA Public Certs=]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:615">
<![LOG[Missing root CA environment variable from variables file]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:621">
<![LOG[support Unknown Machines: 0]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:632">
<![LOG[Custom hook from X:\\TSConfig.INI is ]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:675">
<![LOG[No hook is found to be executed before downloading policy]LOG]!><time="13:10:04.448+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:699">
<![LOG[Authenticator from the environment is empty.]LOG]!><time="13:10:04.463+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:838">
<![LOG[Need to create Authenticator Info using PFX]LOG]!><time="13:10:04.463+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:850">
<![LOG[initialized CStringStream object with string: {B407B519-EA17-4C2A-85B7-092713FFBF40};2014-03-05T21:10:04Z.]LOG]!><time="13:10:04.557+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="stringstream.cpp:101">
<![LOG[set media certificate in transport]LOG]!><time="13:10:04.604+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:9418">
<![LOG[set authenticator in transport]LOG]!><time="13:10:04.604+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:7751">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 GET /SMS_MP/.sms_aut?MPKEYINFORMATIONMEDIA]LOG]!><time="13:10:04.619+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:04.682+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:8956">
<![LOG[Default CSP is Microsoft Enhanced RSA and AES Cryptographic Provider]LOG]!><time="13:10:04.682+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libcrypt.cpp:1904">
<![LOG[Default CSP Type is 24]LOG]!><time="13:10:04.682+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libcrypt.cpp:1905">
<![LOG[New settings:]LOG]!><time="13:10:04.697+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:925">
<![LOG[ site=SPF,SPF, MP=http://SV-DCSCCM-01.spitfire.local, ports: http=80,https=443]LOG]!><time="13:10:04.697+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:927">
<![LOG[ certificates are received from MP.]LOG]!><time="13:10:04.697+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:931">
<![LOG[unknown machine GUIDs: d41d77d8-2d65-40da-8941-ae6b5ebdd2ad 6d4ab1d2-42e8-4fb8-bef2-141ff84f0757]LOG]!><time="13:10:04.697+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:986">
<![LOG[Getting MP time information]LOG]!><time="13:10:04.697+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:1021">
<![LOG[set authenticator in transport]LOG]!><time="13:10:04.697+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:7751">
<![LOG[Requesting client identity]LOG]!><time="13:10:04.744+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:5760">
<![LOG[setting message signatures.]LOG]!><time="13:10:04.760+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:1297">
<![LOG[setting the authenticator.]LOG]!><time="13:10:04.760+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:1327">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 CCM_POST /ccm_system/request]LOG]!><time="13:10:04.760+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:04.775+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:8956">
<![LOG[::DecompressBuffer(65536)]LOG]!><time="13:10:04.791+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="ccmzlib.cpp:739">
<![LOG[Decompression (zlib) succeeded: original size 430, uncompressed size 2536.]LOG]!><time="13:10:04.791+480" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="ccmzlib.cpp:651">
<![LOG[-60 -60]LOG]!><time="13:10:04.791+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:5956">
<![LOG[server time zone info: 0, , [0 10 0 5 2 0 0 0], 0, , [0 3 0 5 1 0 0 0], -60]LOG]!><time="13:10:04.791+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:6055">
<![LOG[Client Identity: ]LOG]!><time="13:10:04.791+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:6140">
<![LOG[Netbios name: ]LOG]!><time="13:10:04.791+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:6156">
<![LOG[Current time: 2014-03-05 21:10:04.791 TZ:Pacific Standard Time Bias:0480]LOG]!><time="13:10:04.791+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:1090">
<![LOG[Current time zone info: 480, Pacific Standard Time, [0 0 0 0 0 0 0 0], 0, , [0 0 0 0 0 0 0 0], 0]LOG]!><time="13:10:04.791+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:1118">
<![LOG[Adjusting the system time: -28799.315 seconds]LOG]!><time="13:10:04.791+480" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:1120">
<![LOG[Time zone info set to: 0, , [0 10 0 5 2 0 0 0], 0, , [0 3 0 5 1 0 0 0], -60]LOG]!><time="21:10:04.791+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:1156">
<![LOG[New time: 2014-03-05 13:10:05.475]LOG]!><time="13:10:05.464+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:1172">
<![LOG[Current time: 2014-03-05 13:10:05.464 TZ: Bias:0000]LOG]!><time="13:10:05.464+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:1178">
<![LOG[Downloading policy from http://SV-DCSCCM-01.spitfire.local.]LOG]!><time="13:10:05.500+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tsmediawizardcontrol.cpp:1185">
<![LOG[initializing HTTP transport.]LOG]!><time="13:10:05.500+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:817">
<![LOG[ Setting URL = http://SV-DCSCCM-01.spitfire.local.]LOG]!><time="13:10:05.500+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:818">
<![LOG[ Setting Ports = 80,443.]LOG]!><time="13:10:05.500+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:821">
<![LOG[ Setting CRL = false.]LOG]!><time="13:10:05.500+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:824">
<![LOG[ Setting Server Certificates.]LOG]!><time="13:10:05.500+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:841">
<![LOG[set authenticator in transport]LOG]!><time="13:10:05.500+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:7751">
<![LOG[ Setting Media Certificate.]LOG]!><time="13:10:05.500+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:849">
<![LOG[Preparing Client Identity Request.]LOG]!><time="13:10:05.546+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:583">
<![LOG[ Setting transport.]LOG]!><time="13:10:05.546+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:586">
<![LOG[ Setting SourceID = {B407B519-EA17-4C2A-85B7-092713FFBF40}.]LOG]!><time="13:10:05.546+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:590">
<![LOG[ Setting site code = SPF.]LOG]!><time="13:10:05.546+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:595">
<![LOG[Can not find DeploymentType in file TsmBootstrap.ini or the file doesn't exist. This is not running on Windows To Go.]LOG]!><time="13:10:05.546+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="utils.cpp:1314">
<![LOG[ Setting SMBIOS GUID = 815DA2F2-2A4A-CB11-834A-A75C285CF24F.]LOG]!><time="13:10:06.326+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:623">
<![LOG[ Adding MAC Address 00:1C:25:95:E4:93.]LOG]!><time="13:10:06.373+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:642">
<![LOG[Executing Client Identity Request.]LOG]!><time="13:10:06.373+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:666">
<![LOG[Requesting client identity]LOG]!><time="13:10:06.373+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:5760">
<![LOG[setting message signatures.]LOG]!><time="13:10:06.389+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:1297">
<![LOG[setting the authenticator.]LOG]!><time="13:10:06.389+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:1327">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 CCM_POST /ccm_system/request]LOG]!><time="13:10:06.389+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:06.404+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:8956">
<![LOG[::DecompressBuffer(65536)]LOG]!><time="13:10:06.404+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="ccmzlib.cpp:739">
<![LOG[Decompression (zlib) succeeded: original size 429, uncompressed size 2536.]LOG]!><time="13:10:06.404+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="ccmzlib.cpp:651">
<![LOG[-60 -60]LOG]!><time="13:10:06.404+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:5956">
<![LOG[server time zone info: 0, , [0 10 0 5 2 0 0 0], 0, , [0 3 0 5 1 0 0 0], -60]LOG]!><time="13:10:06.404+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:6055">
<![LOG[Client Identity: ]LOG]!><time="13:10:06.404+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:6140">
<![LOG[Netbios name: ]LOG]!><time="13:10:06.404+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:6156">
<![LOG[Client GUID = , Netbios name = , State = Known]LOG]!><time="13:10:06.404+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:686">
<![LOG[using unknown machine GUID: 6d4ab1d2-42e8-4fb8-bef2-141ff84f0757]LOG]!><time="13:10:06.404+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tspolicy.cpp:901">
<![LOG[GetSystemEnclosureChassisInfo: IsFixed=TRUE, IsLaptop=TRUE]LOG]!><time="13:10:06.420+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libmachineinfo.cpp:189">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32772, HashSize: 20 ]LOG]!><time="13:10:06.436+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libcrypt.cpp:699">
<![LOG[Computed HardwareID=2:3C79BE89126F022C85DB564212BAFE8C42EEBC63
Win32_SystemEnclosure.SerialNumber=Not Available
Win32_SystemEnclosure.SMBIOSAssetTag=No Asset Information
Win32_BaseBoard.SerialNumber=VF1XX88P0AG
Win32_BIOS.SerialNumber=L3P4050
Win32_NetworkAdapterConfiguration.MACAddress=<Not used on laptop>]LOG]!><time="13:10:06.436+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libmachineinfo.cpp:958">
<![LOG[Hardware ID: 2:3C79BE89126F022C85DB564212BAFE8C42EEBC63]LOG]!><time="13:10:06.436+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tspolicy.cpp:404">
<![LOG[Preparing the Client DDR Message]LOG]!><time="13:10:06.451+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:456">
<![LOG[ Setting SourceID = {B407B519-EA17-4C2A-85B7-092713FFBF40}.]LOG]!><time="13:10:06.451+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:464">
<![LOG[sending the Client DDR message.]LOG]!><time="13:10:06.451+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:546">
<![LOG[sending Report]LOG]!><time="13:10:06.467+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:7099">
<![LOG[<Report><ReportHeader><Identification><Machine><ClientInstalled>0</ClientInstalled><ClientType>1</ClientType><Unknown>1</Unknown><ClientID>GUID:612ad4ce-de06-4eae-8078-cd6861a3529a</ClientID><ClientVersion>5.00.0000.0000</ClientVersion><NetBIOSName>Unknown</NetBIOSName><CodePage>437</CodePage><SystemDefaultLCID>1033</SystemDefaultLCID></Machine></Identification><ReportDetails><ReportContent>Inventory Data</ReportContent><ReportType>Full</ReportType><Date>20140305131006.000000+000</Date><Version>1.0</Version><Format>1.1</Format></ReportDetails><InventoryAction ActionType="Predefined"><InventoryActionID>{00000000-0000-0000-0000-000000000003}</InventoryActionID><Description>Discovery</Description><InventoryActionLastUpdateTime>20140305131006.000000+000</InventoryActionLastUpdateTime></InventoryAction>
</ReportHeader>
<ReportBody><Instance ParentClass="CCM_ClientIdentificationInformation" Class="CCM_ClientIdentificationInformation" Namespace="root\ccm" Content="New"><CCM_ClientIdentificationInformation><HardwareID1>2:3C79BE89126F022C85DB564212BAFE8C42EEBC63</HardwareID1></CCM_ClientIdentificationInformation></Instance><Instance ParentClass="Win32_NetworkAdapterConfiguration" Class="Win32_NetworkAdapterConfiguration" Namespace="root\cimv2" Content="New"><Win32_NetworkAdapterConfiguration><MACAddress>00:1C:25:95:E4:93</MACAddress></Win32_NetworkAdapterConfiguration></Instance><Instance ParentClass="Win32_ComputerSystemProduct" Class="Win32_ComputerSystemProduct" Namespace="root\cimv2" Content="New"><Win32_ComputerSystemProduct><UUID>815DA2F2-2A4A-CB11-834A-A75C285CF24F</UUID></Win32_ComputerSystemProduct></Instance></ReportBody>
</Report>
]LOG]!><time="13:10:06.467+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:7100">
<![LOG[setting message signatures.]LOG]!><time="13:10:06.467+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:1297">
<![LOG[setting the authenticator.]LOG]!><time="13:10:06.467+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:1327">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 CCM_POST /ccm_system/request]LOG]!><time="13:10:06.467+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:06.467+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:8956">
<![LOG[submitted new client identity: GUID:612ad4ce-de06-4eae-8078-cd6861a3529a]LOG]!><time="13:10:06.482+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tspolicy.cpp:926">
<![LOG[Preparing Policy Assignment Request.]LOG]!><time="13:10:06.482+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:944">
<![LOG[ Setting transport.]LOG]!><time="13:10:06.482+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:945">
<![LOG[ Setting site code = SPF.]LOG]!><time="13:10:06.482+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:948">
<![LOG[ Setting client ID = 6d4ab1d2-42e8-4fb8-bef2-141ff84f0757.]LOG]!><time="13:10:06.482+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:950">
<![LOG[ Setting site signing Certificate.]LOG]!><time="13:10:06.482+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:955">
<![LOG[setting SiteSigningCertificateContext]LOG]!><time="13:10:06.482+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:2516">
<![LOG[Executing Policy Assignment Request.]LOG]!><time="13:10:06.482+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:967">
<![LOG[sending RequestAssignments]LOG]!><time="13:10:06.482+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:2793">
<![LOG[setting message signatures.]LOG]!><time="13:10:06.482+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:1297">
<![LOG[setting the authenticator.]LOG]!><time="13:10:06.482+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:1327">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 CCM_POST /ccm_system/request]LOG]!><time="13:10:06.482+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:06.514+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:8956">
<![LOG[::DecompressBuffer(65536)]LOG]!><time="13:10:06.514+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="ccmzlib.cpp:739">
<![LOG[Decompression (zlib) succeeded: original size 26003, uncompressed size 123304.]LOG]!><time="13:10:06.514+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="ccmzlib.cpp:651">
<![LOG[Request client ID: 6d4ab1d2-42e8-4fb8-bef2-141ff84f0757]LOG]!><time="13:10:06.529+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:2847">
<![LOG[Response client ID: 6d4ab1d2-42e8-4fb8-bef2-141ff84f0757]LOG]!><time="13:10:06.529+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:2848">
<![LOG[Retrieving Policy Assignments:]LOG]!><time="13:10:06.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:971">
<![LOG[ Processing Policy Assignment {64c8008d-de87-4083-9b9e-4941a59115e4}.]LOG]!><time="13:10:06.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {c1636d3d-7666-4374-9661-de41d9ac80c2}.]LOG]!><time="13:10:06.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {2dab3766-5ffe-4924-83c2-81e5913f4be4}.]LOG]!><time="13:10:06.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {f5e8aea1-14ec-4dc7-8b40-41f1f2bb2807}.]LOG]!><time="13:10:06.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {cfab20a1-2f82-4deb-bd3d-8dd29ddf46a0}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {14e37255-9eec-4b07-91f5-ad2149ed88a5}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {8dff6c80-1cc1-4f6e-b0ef-31a2e81fb4fe}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {181a8456-bbc0-4636-889a-f8f4d77478ef}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {ca985356-5963-4d93-a634-4346a2e76152}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {e28dabf0-8e7b-4058-afc9-fc41b3c85516}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {88fe718a-7a75-4c1d-b6a6-7be8688373a2}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {5dd54f72-6fea-4c15-bf0e-20e96a5a6eef}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {f6b9a07d-19bd-4266-86f8-b91bca8036fc}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {43ab0dae-00cc-4d0c-a223-6ba0faa2c36d}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {2c5b5819-db2a-49b2-85ba-545918d1eddf}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {cf9f153a-5b22-476b-870c-6d41be176cd2}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {c615fbe7-f7c6-4151-ad1c-ab5a783fb025}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {c81bcf76-aa87-45cd-afc5-6a8d25733bfe}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {da0ffa55-741a-4f6b-8110-bbbbf7395864}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {f930b725-04a5-4dc6-8899-b66bc1034ed0}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {6bc5392a-ad33-443d-9856-09918e459461}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {77e980e3-a6ca-4402-86fc-3606beae8e9f}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {9fd5ed01-11dd-4bbd-a589-6adeb798ded1}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {d23599c1-35bd-4617-9091-3356fc721d4d}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {ead11352-c376-43a9-b021-0bd68b242b62}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {2544384c-4328-47e8-8f63-fdd46632c622}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {49f29ccd-1ea7-4cd8-bc1a-dd24f170a636}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {0cc939db-caa4-4643-81b2-1b2eba3cb018}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {00ad013d-5e7b-43e2-a4c5-c4123f6659a5}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {0a21581e-9bc9-4968-a34d-ee2fc77d1bf3}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {fb8f1ae5-e652-427c-af47-01658c17f270}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {805c8dda-9004-4fd8-b5c4-de19b8a4863b}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {fd80382c-3022-4c0b-9bf4-64c7c664a2e2}.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment SPF20000-SPF00004-3B5BFFE2.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment SRC10000.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment SPF20004-SPF0000D-6F6BCC28.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment DEP-SPF20004-SPF00005-6F6BCC28.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment DEP-SPF20004-SPF00003-6F6BCC28.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {3B800AB4-058A-45DA-A407-FB4C301AA5E1}/4.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {3B800AB4-058A-45DA-A407-FB4C301AA5E1}/9.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {3B800AB4-058A-45DA-A407-FB4C301AA5E1}/13.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {3B800AB4-058A-45DA-A407-FB4C301AA5E1}/25.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment {3B800AB4-058A-45DA-A407-FB4C301AA5E1}/26.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[ Processing Policy Assignment DEP-SPF20004-SPF0000F-6F6BCC28.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:977">
<![LOG[successfully read 44 policy assignments.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tspolicy.cpp:991">
<![LOG[Downloading policy body SPF20004-SPF0000D-6F6BCC28.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tspolicy.cpp:2040">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:2043">
<![LOG[ Setting transport.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:2044">
<![LOG[ Setting policy location = http://<mp>/SMS_MP/.sms_pol?SPF20004-SPF0000D-6F6BCC28.26_00.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:2046">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:2063">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 GET /SMS_MP/.sms_pol?SPF20004-SPF0000D-6F6BCC28.26_00]LOG]!><time="13:10:06.545+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:06.560+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libsmsmessaging.cpp:8956">
<![LOG[Found a secure policy.]LOG]!><time="13:10:06.560+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:4563">
<![LOG[Trying to decode policy.]LOG]!><time="13:10:06.560+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:4567">
<![LOG[Policy decoded.]LOG]!><time="13:10:06.576+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:4602">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32780, HashSize: 32 ]LOG]!><time="13:10:06.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libcrypt.cpp:699">
<![LOG[Expected Hash size: 32, Computed Hash size: 32 ]LOG]!><time="13:10:06.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="libcrypt.cpp:746">
<![LOG[Request location: HTTP://<MP>/SMS_MP/.SMS_POL?SPF20004-SPF0000D-6F6BCC28.26_00]LOG]!><time="13:10:06.592+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:4815">
<![LOG[Response ID: SPF20004-SPF0000D-6F6BCC28]LOG]!><time="13:10:06.592+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="libsmsmessaging.cpp:4816">
<![LOG[Reading Policy Body.]LOG]!><time="13:10:06.592+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:2071">
<![LOG[Parsing Policy Body.]LOG]!><time="13:10:06.592+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:2078">
<![LOG[This Task sequence is set for DownloadOnDemand]LOG]!><time="13:10:06.592+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tspolicy.cpp:3150">
<![LOG[Retrieving collection variable policy.]LOG]!><time="13:10:06.607+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tspolicy.cpp:1512">
<![LOG[Found 0 collection variables.]LOG]!><time="13:10:06.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:1520">
<![LOG[Retrieving machine variable policy.]LOG]!><time="13:10:06.607+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="tspolicy.cpp:1530">
<![LOG[Found 0 machine variables.]LOG]!><time="13:10:06.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tspolicy.cpp:1538">
<![LOG[setting collection variables in the task sequencing environment.]LOG]!><time="13:10:06.607+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="utils.cpp:157">
<![LOG[setting machine variables in the task sequencing environment.]LOG]!><time="13:10:06.607+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1012" file="utils.cpp:157">
<![LOG[Exiting TSMediaWizardControl::GetPolicy.]LOG]!><time="13:10:06.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1012" file="tsmediawizardcontrol.cpp:1378">
<![LOG[WelcomePage::OnWizardNext()]LOG]!><time="13:10:06.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tsmediawelcomepage.cpp:340">
<![LOG[Loading Media Variables from "X:\sms\data\variables.dat"]LOG]!><time="13:10:06.607+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="520" file="tsremovablemedia.cpp:322">
<![LOG[CryptDecrypt (hKey, 0, 1, 0, pData, &dwDecryptedLen), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\smscrypt\windes.cpp,165)]LOG]!><time="13:10:06.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="windes.cpp:165">
<![LOG[sMS::Crypto::DES::DecryptBuffer( (BYTE*)pszPassword, (DWORD)(wcslen(pszPassword)*sizeof(WCHAR)), encryptedBuffer.getBuffer(), (DWORD)encryptedBuffer.size(), pbDecryptedBuffer, dwDecryptedBufferSize ), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\tscore\tsremovablemedia.cpp,387)]LOG]!><time="13:10:06.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tsremovablemedia.cpp:387">
<![LOG[skipping Confirmation Page.]LOG]!><time="13:10:06.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tsmediaconfirmationpage.cpp:170">
<![LOG[Activating Task Sequence Selection Page.]LOG]!><time="13:10:06.623+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tsmediataskselectionpage.cpp:112">
<![LOG[Executing command line: X:\WINDOWS\system32\cmd.exe /k]LOG]!><time="13:10:07.855+00" date="03-05-2014" component="TSBootShell" context="" type="1" thread="736" file="bootshell.cpp:857">
<![LOG[The command completed successfully.]LOG]!><time="13:10:07.855+00" date="03-05-2014" component="TSBootShell" context="" type="1" thread="736" file="bootshell.cpp:939">
<![LOG[successfully launched command shell.]LOG]!><time="13:10:07.855+00" date="03-05-2014" component="TSBootShell" context="" type="1" thread="736" file="bootshell.cpp:430">
<![LOG[TaskSelectionPage::OnWizardNext()]LOG]!><time="13:10:10.754+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tsmediataskselectionpage.cpp:137">
<![LOG[skipping Variables Selection Page.]LOG]!><time="13:10:10.769+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tsmediavariablesselectionpage.cpp:155">
<![LOG[Activating Resolve Progress Page.]LOG]!><time="13:10:10.769+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tsmediaresolveprogresspage.cpp:76">
<![LOG[ResolveProgressPage::OnWizardNext()]LOG]!><time="13:10:10.769+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="520" file="tsmediaresolveprogresspage.cpp:113">
<![LOG[spawned thread 1516 to resolve task sequence dependencies.]LOG]!><time="13:10:10.769+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="520" file="tsmediaresolveprogresspage.cpp:142">
<![LOG[No content source files for selected task sequence.]LOG]!><time="13:10:10.769+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:3387">
<![LOG[Getting policy for CCM_SoftwareDistribution[AdvertID=SPF20004", PackageID="SPF00003", ProgramID="*]]LOG]!><time="13:10:10.769+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2430">
<![LOG[Downloading policy body DEP-SPF20004-SPF00003-6F6BCC28.]LOG]!><time="13:10:10.769+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2040">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:10:10.769+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2043">
<![LOG[ Setting transport.]LOG]!><time="13:10:10.769+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2044">
<![LOG[ Setting policy location = http://<mp>/SMS_MP/.sms_pol?DEP-SPF20004-SPF00003-6F6BCC28.1_00.]LOG]!><time="13:10:10.769+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2046">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:10:10.769+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2063">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 GET /SMS_MP/.sms_pol?DEP-SPF20004-SPF00003-6F6BCC28.1_00]LOG]!><time="13:10:10.769+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:10.785+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:8956">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32780, HashSize: 32 ]LOG]!><time="13:10:10.785+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:699">
<![LOG[Expected Hash size: 32, Computed Hash size: 32 ]LOG]!><time="13:10:10.785+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:746">
<![LOG[Request location: HTTP://<MP>/SMS_MP/.SMS_POL?DEP-SPF20004-SPF00003-6F6BCC28.1_00]LOG]!><time="13:10:10.785+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4815">
<![LOG[Response ID: DEP-SPF20004-SPF00003-6F6BCC28]LOG]!><time="13:10:10.785+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4816">
<![LOG[Reading Policy Body.]LOG]!><time="13:10:10.785+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2071">
<![LOG[Parsing Policy Body.]LOG]!><time="13:10:10.785+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2078">
<![LOG[Getting content hash value for reference package SPF00003 from policy]LOG]!><time="13:10:10.785+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2503">
<![LOG[successfully resolved policy for SPF00003.]LOG]!><time="13:10:10.785+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2558">
<![LOG[Resolving content location for SPF00003]LOG]!><time="13:10:10.785+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2575">
<![LOG[Getting network access account.]LOG]!><time="13:10:10.785+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:1836">
<![LOG[Downloading policy body {f930b725-04a5-4dc6-8899-b66bc1034ed0}.]LOG]!><time="13:10:10.785+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2040">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:10:10.785+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2043">
<![LOG[ Setting transport.]LOG]!><time="13:10:10.785+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2044">
<![LOG[ Setting policy location = http://<mp>/SMS_MP/.sms_pol?{f930b725-04a5-4dc6-8899-b66bc1034ed0}.2_00.]LOG]!><time="13:10:10.785+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2046">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:10:10.785+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2063">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 GET /SMS_MP/.sms_pol?{f930b725-04a5-4dc6-8899-b66bc1034ed0}.2_00]LOG]!><time="13:10:10.801+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:10.801+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:8956">
<![LOG[Found a secure policy.]LOG]!><time="13:10:10.801+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4563">
<![LOG[Trying to decode policy.]LOG]!><time="13:10:10.801+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4567">
<![LOG[Policy decoded.]LOG]!><time="13:10:10.816+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4602">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32780, HashSize: 32 ]LOG]!><time="13:10:10.816+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:699">
<![LOG[Expected Hash size: 32, Computed Hash size: 32 ]LOG]!><time="13:10:10.816+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:746">
<![LOG[Request location: HTTP://<MP>/SMS_MP/.SMS_POL?{F930B725-04A5-4DC6-8899-B66BC1034ED0}.2_00]LOG]!><time="13:10:10.816+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4815">
<![LOG[Response ID: {F930B725-04A5-4DC6-8899-B66BC1034ED0}]LOG]!><time="13:10:10.816+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4816">
<![LOG[Reading Policy Body.]LOG]!><time="13:10:10.816+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2071">
<![LOG[Parsing Policy Body.]LOG]!><time="13:10:10.816+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2078">
<![LOG[Found NetworkAccessUsername/NetworkAccessPassword from NAAConfig CCM_NetworkAccessAccount]LOG]!><time="13:10:10.816+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:1754">
<![LOG[Network Access Account has a non-empty value]LOG]!><time="13:10:10.816+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.h:175">
<![LOG[Getting local network information.]LOG]!><time="13:10:10.816+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:1991">
<![LOG[DhcpGetOriginalSubnetMask entry point is supported.]LOG]!><time="13:10:10.816+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmiputil.cpp:117">
<![LOG[begin checking Alternate Network Configuration]LOG]!><time="13:10:10.816+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmiputil.cpp:1095">
<![LOG[spNamespace.Open(sNamespacePath), HRESULT=8004100e (e:\nts_sccm_release\sms\framework\ccmutillib\ccmiputil.cpp,1109)]LOG]!><time="13:10:10.832+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmiputil.cpp:1109">
<![LOG[Finished checking Alternate Network Configuration]LOG]!><time="13:10:10.832+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmiputil.cpp:1172">
<![LOG[Adapter {32486CA1-6462-4242-AF7B-874B4231267E} is DHCP enabled. Checking quarantine status.]LOG]!><time="13:10:10.847+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmiputil.cpp:436">
<![LOG[Content location request:]LOG]!><time="13:10:10.847+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:1996">
<![LOG[ Package : SPF00003.1]LOG]!><time="13:10:10.847+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:1997">
<![LOG[ Client : 6d4ab1d2-42e8-4fb8-bef2-141ff84f0757]LOG]!><time="13:10:10.847+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:1998">
<![LOG[ Local : 1]LOG]!><time="13:10:10.847+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:1999">
<![LOG[ Remote : 4]LOG]!><time="13:10:10.847+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2000">
<![LOG[ Internet: 0]LOG]!><time="13:10:10.847+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2001">
<![LOG[sending RequestContentLocations for SPF00003]LOG]!><time="13:10:10.863+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:3464">
<![LOG[setting message signatures.]LOG]!><time="13:10:10.863+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:1297">
<![LOG[setting the authenticator.]LOG]!><time="13:10:10.863+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:1327">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 CCM_POST /ccm_system/request]LOG]!><time="13:10:10.863+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:8956">
<![LOG[::DecompressBuffer(65536)]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:739">
<![LOG[Decompression (zlib) succeeded: original size 554, uncompressed size 1746.]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:651">
<![LOG[Location Reply: <ContentLocationReply SchemaVersion="1.00"><ContentInfo PackageFlags="16777216"><ContentHashValues/></ContentInfo><Sites><Site><MPSite SiteCode="SPF" MasterSiteCode="SPF" SiteLocality="FALLBACK" IISPreferedPort="80" IISSSLPreferedPort="443"/><LocationRecords><LocationRecord><URL Name="http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF00003" Signature="http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSSIG$/SPF00003"/><ADSite Name="Default-First-Site-Name"/><IPSubnets><IPSubnet Address="10.100.43.0"/><IPSubnet Address=""/></IPSubnets><Metric Value=""/><Version>7804</Version><Capabilities SchemaVersion="1.0"><Property Name="SSLState" Value="0"/></Capabilities><ServerRemoteName>SV-DCSCCM-01.spitfire.local</ServerRemoteName><DPType>SERVER</DPType><Windows Trust="0"/><Locality>FALLBACK</Locality></LocationRecord></LocationRecords></Site></Sites></ContentLocationReply>]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:3491">
<![LOG[MCS server: ]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:3678">
<![LOG[Found location: http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF00003]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:3766">
<![LOG[Local=0]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:3803">
<![LOG[Processing 1 locations.]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2032">
<![LOG[Processing remote location:]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2079">
<![LOG[ Flags: 01000000]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2080">
<![LOG[ URLs : 1]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2081">
<![LOG[ SMB : ]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2082">
<![LOG[ MCS : ]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2083">
<![LOG[Adding URL location item 3 2 00000390 00000000 http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF00003]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2117">
<![LOG[Prioritized locations:]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2146">
<![LOG[ http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF00003]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2162">
<![LOG[sPF00003 content location: ]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2642">
<![LOG[sPF00003 http content location: http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF00003]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2660">
<![LOG[Getting policy for CCM_SoftwareDistribution[AdvertID=SPF20004", PackageID="SPF00005", ProgramID="*]]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2430">
<![LOG[Downloading policy body DEP-SPF20004-SPF00005-6F6BCC28.]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2040">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2043">
<![LOG[ Setting transport.]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2044">
<![LOG[ Setting policy location = http://<mp>/SMS_MP/.sms_pol?DEP-SPF20004-SPF00005-6F6BCC28.2_00.]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2046">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2063">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 GET /SMS_MP/.sms_pol?DEP-SPF20004-SPF00005-6F6BCC28.2_00]LOG]!><time="13:10:10.894+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:8956">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32780, HashSize: 32 ]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:699">
<![LOG[Expected Hash size: 32, Computed Hash size: 32 ]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:746">
<![LOG[Request location: HTTP://<MP>/SMS_MP/.SMS_POL?DEP-SPF20004-SPF00005-6F6BCC28.2_00]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4815">
<![LOG[Response ID: DEP-SPF20004-SPF00005-6F6BCC28]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4816">
<![LOG[Reading Policy Body.]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2071">
<![LOG[Parsing Policy Body.]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2078">
<![LOG[Getting content hash value for reference package SPF00005 from policy]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2503">
<![LOG[successfully resolved policy for SPF00005.]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2558">
<![LOG[Resolving content location for SPF00005]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2575">
<![LOG[Getting network access account.]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:1836">
<![LOG[Found NetworkAccessUsername/NetworkAccessPassword from NAAConfig CCM_NetworkAccessAccount]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:1754">
<![LOG[Network Access Account has a non-empty value]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.h:175">
<![LOG[Getting local network information.]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:1991">
<![LOG[DHCP entry points already initialized.]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmiputil.cpp:75">
<![LOG[begin checking Alternate Network Configuration]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmiputil.cpp:1095">
<![LOG[spNamespace.Open(sNamespacePath), HRESULT=8004100e (e:\nts_sccm_release\sms\framework\ccmutillib\ccmiputil.cpp,1109)]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmiputil.cpp:1109">
<![LOG[Finished checking Alternate Network Configuration]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmiputil.cpp:1172">
<![LOG[Adapter {32486CA1-6462-4242-AF7B-874B4231267E} is DHCP enabled. Checking quarantine status.]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmiputil.cpp:436">
<![LOG[Content location request:]LOG]!><time="13:10:10.910+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:1996">
<![LOG[ Package : SPF00005.6]LOG]!><time="13:10:10.925+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:1997">
<![LOG[ Client : 6d4ab1d2-42e8-4fb8-bef2-141ff84f0757]LOG]!><time="13:10:10.925+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:1998">
<![LOG[ Local : 1]LOG]!><time="13:10:10.925+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:1999">
<![LOG[ Remote : 4]LOG]!><time="13:10:10.925+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2000">
<![LOG[ Internet: 0]LOG]!><time="13:10:10.925+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2001">
<![LOG[sending RequestContentLocations for SPF00005]LOG]!><time="13:10:10.925+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:3464">
<![LOG[setting message signatures.]LOG]!><time="13:10:10.925+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:1297">
<![LOG[setting the authenticator.]LOG]!><time="13:10:10.925+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:1327">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 CCM_POST /ccm_system/request]LOG]!><time="13:10:10.925+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:10.941+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:8956">
<![LOG[::DecompressBuffer(65536)]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:739">
<![LOG[Decompression (zlib) succeeded: original size 549, uncompressed size 1738.]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:651">
<![LOG[Location Reply: <ContentLocationReply SchemaVersion="1.00"><ContentInfo PackageFlags="1056"><ContentHashValues/></ContentInfo><Sites><Site><MPSite SiteCode="SPF" MasterSiteCode="SPF" SiteLocality="FALLBACK" IISPreferedPort="80" IISSSLPreferedPort="443"/><LocationRecords><LocationRecord><URL Name="http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF00005" Signature="http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSSIG$/SPF00005"/><ADSite Name="Default-First-Site-Name"/><IPSubnets><IPSubnet Address="10.100.43.0"/><IPSubnet Address=""/></IPSubnets><Metric Value=""/><Version>7804</Version><Capabilities SchemaVersion="1.0"><Property Name="SSLState" Value="0"/></Capabilities><ServerRemoteName>SV-DCSCCM-01.spitfire.local</ServerRemoteName><DPType>SERVER</DPType><Windows Trust="0"/><Locality>FALLBACK</Locality></LocationRecord></LocationRecords></Site></Sites></ContentLocationReply>]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:3491">
<![LOG[MCS server: ]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:3678">
<![LOG[Found location: http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF00005]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:3766">
<![LOG[Local=0]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:3803">
<![LOG[Processing 1 locations.]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2032">
<![LOG[Processing remote location:]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2079">
<![LOG[ Flags: 00000420]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2080">
<![LOG[ URLs : 1]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2081">
<![LOG[ SMB : ]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2082">
<![LOG[ MCS : ]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2083">
<![LOG[Adding URL location item 3 2 00000075 00000000 http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF00005]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2117">
<![LOG[Prioritized locations:]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2146">
<![LOG[ http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF00005]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2162">
<![LOG[sPF00005 content location: ]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2642">
<![LOG[sPF00005 http content location: http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF00005]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2660">
<![LOG[Getting policy for CCM_SoftwareDistribution[AdvertID=SPF20004", PackageID="SPF0000F", ProgramID="*]]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2430">
<![LOG[Downloading policy body DEP-SPF20004-SPF0000F-6F6BCC28.]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2040">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2043">
<![LOG[ Setting transport.]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2044">
<![LOG[ Setting policy location = http://<mp>/SMS_MP/.sms_pol?DEP-SPF20004-SPF0000F-6F6BCC28.5_00.]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2046">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2063">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 GET /SMS_MP/.sms_pol?DEP-SPF20004-SPF0000F-6F6BCC28.5_00]LOG]!><time="13:10:10.957+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:8956">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32780, HashSize: 32 ]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:699">
<![LOG[Expected Hash size: 32, Computed Hash size: 32 ]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:746">
<![LOG[Request location: HTTP://<MP>/SMS_MP/.SMS_POL?DEP-SPF20004-SPF0000F-6F6BCC28.5_00]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4815">
<![LOG[Response ID: DEP-SPF20004-SPF0000F-6F6BCC28]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4816">
<![LOG[Reading Policy Body.]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2071">
<![LOG[Parsing Policy Body.]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2078">
<![LOG[Getting content hash value for reference package SPF0000F from policy]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2503">
<![LOG[successfully resolved policy for SPF0000F.]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2558">
<![LOG[Resolving content location for SPF0000F]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2575">
<![LOG[Getting network access account.]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:1836">
<![LOG[Found NetworkAccessUsername/NetworkAccessPassword from NAAConfig CCM_NetworkAccessAccount]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:1754">
<![LOG[Network Access Account has a non-empty value]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.h:175">
<![LOG[Getting local network information.]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:1991">
<![LOG[DHCP entry points already initialized.]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmiputil.cpp:75">
<![LOG[begin checking Alternate Network Configuration]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmiputil.cpp:1095">
<![LOG[spNamespace.Open(sNamespacePath), HRESULT=8004100e (e:\nts_sccm_release\sms\framework\ccmutillib\ccmiputil.cpp,1109)]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmiputil.cpp:1109">
<![LOG[Finished checking Alternate Network Configuration]LOG]!><time="13:10:10.972+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmiputil.cpp:1172">
<![LOG[Adapter {32486CA1-6462-4242-AF7B-874B4231267E} is DHCP enabled. Checking quarantine status.]LOG]!><time="13:10:10.988+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmiputil.cpp:436">
<![LOG[Content location request:]LOG]!><time="13:10:10.988+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:1996">
<![LOG[ Package : SPF0000F.2]LOG]!><time="13:10:10.988+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:1997">
<![LOG[ Client : 6d4ab1d2-42e8-4fb8-bef2-141ff84f0757]LOG]!><time="13:10:10.988+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:1998">
<![LOG[ Local : 1]LOG]!><time="13:10:10.988+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:1999">
<![LOG[ Remote : 4]LOG]!><time="13:10:10.988+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2000">
<![LOG[ Internet: 0]LOG]!><time="13:10:10.988+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2001">
<![LOG[sending RequestContentLocations for SPF0000F]LOG]!><time="13:10:10.988+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:3464">
<![LOG[setting message signatures.]LOG]!><time="13:10:11.003+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:1297">
<![LOG[setting the authenticator.]LOG]!><time="13:10:11.003+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:1327">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 CCM_POST /ccm_system/request]LOG]!><time="13:10:11.003+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:8956">
<![LOG[::DecompressBuffer(65536)]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:739">
<![LOG[Decompression (zlib) succeeded: original size 557, uncompressed size 1746.]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:651">
<![LOG[Location Reply: <ContentLocationReply SchemaVersion="1.00"><ContentInfo PackageFlags="67108896"><ContentHashValues/></ContentInfo><Sites><Site><MPSite SiteCode="SPF" MasterSiteCode="SPF" SiteLocality="FALLBACK" IISPreferedPort="80" IISSSLPreferedPort="443"/><LocationRecords><LocationRecord><URL Name="http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF0000F" Signature="http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSSIG$/SPF0000F"/><ADSite Name="Default-First-Site-Name"/><IPSubnets><IPSubnet Address="10.100.43.0"/><IPSubnet Address=""/></IPSubnets><Metric Value=""/><Version>7804</Version><Capabilities SchemaVersion="1.0"><Property Name="SSLState" Value="0"/></Capabilities><ServerRemoteName>SV-DCSCCM-01.spitfire.local</ServerRemoteName><DPType>SERVER</DPType><Windows Trust="0"/><Locality>FALLBACK</Locality></LocationRecord></LocationRecords></Site></Sites></ContentLocationReply>]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:3491">
<![LOG[MCS server: ]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:3678">
<![LOG[Found location: http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF0000F]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:3766">
<![LOG[Local=0]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:3803">
<![LOG[Processing 1 locations.]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2032">
<![LOG[Processing remote location:]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2079">
<![LOG[ Flags: 04000020]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2080">
<![LOG[ URLs : 1]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2081">
<![LOG[ SMB : ]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2082">
<![LOG[ MCS : ]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2083">
<![LOG[Adding URL location item 3 2 00000146 00000000 http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF0000F]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2117">
<![LOG[Prioritized locations:]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2146">
<![LOG[ http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF0000F]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:2162">
<![LOG[sPF0000F content location: ]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2642">
<![LOG[sPF0000F http content location: http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF0000F]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2660">
<![LOG[No need to register providers]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tsmbootstraputil.cpp:1000">
<![LOG[Registering the Progress UI.]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1726">
<![LOG[Command line for extension .exe is "%1" %*]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="commandline.cpp:228">
<![LOG[set command line: "X:\sms\bin\x64\TsProgressUI.exe" /Register:WinPE]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="commandline.cpp:731">
<![LOG[Executing command line: "X:\sms\bin\x64\TsProgressUI.exe" /Register:WinPE]LOG]!><time="13:10:11.019+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="commandline.cpp:827">
<![LOG[==========[ TsProgressUI started in process 1528 ]==========]LOG]!><time="13:10:11.066+00" date="03-05-2014" component="TsProgressUI" context="" type="1" thread="1532" file="winmain.cpp:330">
<![LOG[Command line: "X:\sms\bin\x64\TsProgressUI.exe" /Register:WinPE]LOG]!><time="13:10:11.066+00" date="03-05-2014" component="TsProgressUI" context="" type="0" thread="1532" file="winmain.cpp:332">
<![LOG[Registering COM classes]LOG]!><time="13:10:11.066+00" date="03-05-2014" component="TsProgressUI" context="" type="1" thread="1532" file="winmain.cpp:187">
<![LOG[sbModulePath = X:\sms\bin\x64\TsProgressUI.exe]LOG]!><time="13:10:11.066+00" date="03-05-2014" component="TsProgressUI" context="" type="1" thread="1532" file="tsprogressuiclass.cpp:625">
<![LOG[unregistering class objects]LOG]!><time="13:10:11.066+00" date="03-05-2014" component="TsProgressUI" context="" type="1" thread="1532" file="winmain.cpp:495">
<![LOG[shutdown complete.]LOG]!><time="13:10:11.066+00" date="03-05-2014" component="TsProgressUI" context="" type="1" thread="1532" file="winmain.cpp:512">
<![LOG[Process completed with exit code 0]LOG]!><time="13:10:11.066+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="commandline.cpp:1123">
<![LOG[successfully registered TS Progress UI.]LOG]!><time="13:10:11.066+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="utils.cpp:2279">
<![LOG[Creating the Task Sequencing Environment.]LOG]!><time="13:10:11.066+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1733">
<![LOG[setting Media Variables in Task Sequencing Environment.]LOG]!><time="13:10:11.066+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1739">
<![LOG[setting WinPE Flag in the Task Sequencing Environment.]LOG]!><time="13:10:11.066+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1763">
<![LOG[setting Media Type Flag in the Task Sequencing Environment.]LOG]!><time="13:10:11.066+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1769">
<![LOG[setting Local Computer Name in the Task Sequencing Environment.]LOG]!><time="13:10:11.066+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1775">
<![LOG[setting Selected Task Sequence Information Task Sequencing Environment.]LOG]!><time="13:10:11.066+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1782">
<![LOG[setting selected task sequence information in the environment.]LOG]!><time="13:10:11.066+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:3490">
<![LOG[::CompressBuffer(65536,-1)]LOG]!><time="13:10:11.081+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:700">
<![LOG[Compression (zlib) succeeded: original size 22450, compressed size 2712.]LOG]!><time="13:10:11.081+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:489">
<![LOG[setting source for SPF00003 to ]LOG]!><time="13:10:11.081+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:3754">
<![LOG[setting _SMSTSHTTPSPF00003 to http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF00003]LOG]!><time="13:10:11.081+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:3629">
<![LOG[setting _SMSTSPKGFLAGSSPF00003 to 16777216]LOG]!><time="13:10:11.081+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:3653">
<![LOG[Compression (zlib) succeeded: original size 22254, compressed size 2712.]LOG]!><time="13:10:11.081+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:489">
<![LOG[setting source for SPF00005 to ]LOG]!><time="13:10:11.081+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:3754">
<![LOG[setting _SMSTSHTTPSPF00005 to http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF00005]LOG]!><time="13:10:11.081+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:3629">
<![LOG[setting _SMSTSPKGFLAGSSPF00005 to 1056]LOG]!><time="13:10:11.081+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:3653">
<![LOG[Compression (zlib) succeeded: original size 22178, compressed size 2695.]LOG]!><time="13:10:11.081+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:489">
<![LOG[setting source for SPF0000F to ]LOG]!><time="13:10:11.081+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="resolvesource.cpp:3754">
<![LOG[setting _SMSTSHTTPSPF0000F to http://SV-DCSCCM-01.spitfire.local/SMS_DP_SMSPKG$/SPF0000F]LOG]!><time="13:10:11.081+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:3629">
<![LOG[setting _SMSTSPKGFLAGSSPF0000F to 67108896]LOG]!><time="13:10:11.081+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:3653">
<![LOG[initializing the local data path.]LOG]!><time="13:10:11.081+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1788">
<![LOG[user did not specify local data drive]LOG]!><time="13:10:11.097+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="utils.cpp:1391">
<![LOG[Volume C:\ has 79917633536 bytes of free space]LOG]!><time="13:10:11.097+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="utils.cpp:536">
<![LOG[Volume D:\ is not a fixed hard drive]LOG]!><time="13:10:11.097+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="utils.cpp:495">
<![LOG[Volume X:\ is not a fixed hard drive]LOG]!><time="13:10:11.097+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="utils.cpp:495">
<![LOG[TSM root drive = C:\]LOG]!><time="13:10:11.097+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="utils.cpp:559">
<![LOG[C:\_SMSTaskSequence folder exists, removing]LOG]!><time="13:10:11.097+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="utils.cpp:1161">
<![LOG[Creating directory C:\_SMSTaskSequence]LOG]!><time="13:10:11.097+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="utils.cpp:1200">
<![LOG[updated security on object C:\_SMSTaskSequence.]LOG]!><time="13:10:11.482+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="utils.cpp:1121">
<![LOG[setting Task Sequence User State Path to "%_SMSTSMDataPath%\UserState".]LOG]!><time="13:10:11.482+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:145">
<![LOG[setting Network Access Account Information in Task Sequencing Environment.]LOG]!><time="13:10:11.482+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1811">
<![LOG[Found NetworkAccessUsername/NetworkAccessPassword from NAAConfig CCM_NetworkAccessAccount]LOG]!><time="13:10:11.482+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:1754">
<![LOG[Network Access Account has a non-empty value]LOG]!><time="13:10:11.482+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.h:175">
<![LOG[Downloading policy body {2c5b5819-db2a-49b2-85ba-545918d1eddf}.]LOG]!><time="13:10:11.482+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2040">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:10:11.482+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2043">
<![LOG[ Setting transport.]LOG]!><time="13:10:11.482+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2044">
<![LOG[ Setting policy location = http://<mp>/SMS_MP/.sms_pol?{2c5b5819-db2a-49b2-85ba-545918d1eddf}.1_00.]LOG]!><time="13:10:11.482+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2046">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:10:11.482+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2063">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 GET /SMS_MP/.sms_pol?{2c5b5819-db2a-49b2-85ba-545918d1eddf}.1_00]LOG]!><time="13:10:11.482+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:11.498+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:8956">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32780, HashSize: 32 ]LOG]!><time="13:10:11.498+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:699">
<![LOG[Expected Hash size: 32, Computed Hash size: 32 ]LOG]!><time="13:10:11.498+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:746">
<![LOG[Request location: HTTP://<MP>/SMS_MP/.SMS_POL?{2C5B5819-DB2A-49B2-85BA-545918D1EDDF}.1_00]LOG]!><time="13:10:11.498+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4815">
<![LOG[Response ID: {2C5B5819-DB2A-49B2-85BA-545918D1EDDF}]LOG]!><time="13:10:11.498+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4816">
<![LOG[Reading Policy Body.]LOG]!><time="13:10:11.498+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2071">
<![LOG[Parsing Policy Body.]LOG]!><time="13:10:11.498+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2078">
<![LOG[Downloading policy body {3B800AB4-058A-45DA-A407-FB4C301AA5E1}/4.]LOG]!><time="13:10:11.498+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2040">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:10:11.498+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2043">
<![LOG[ Setting transport.]LOG]!><time="13:10:11.498+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2044">
<![LOG[ Setting policy location = http://<mp>/SMS_MP/.sms_pol?{3B800AB4-058A-45DA-A407-FB4C301AA5E1}/4.SHA256:98B9068EA1A0739D16C0FF34C8E47DD51350A98FB9793269151028B498FCFED9.]LOG]!><time="13:10:11.498+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2046">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:10:11.498+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2063">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 GET /SMS_MP/.sms_pol?{3B800AB4-058A-45DA-A407-FB4C301AA5E1}/4.SHA256:98B9068EA1A0739D16C0FF34C8E47DD51350A98FB9793269151028B498FCFED9]LOG]!><time="13:10:11.498+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[::DecompressBuffer(65536)]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:739">
<![LOG[Decompression (zlib) succeeded: original size 705, uncompressed size 4962.]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:651">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32780, HashSize: 32 ]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:699">
<![LOG[Expected Hash size: 32, Computed Hash size: 32 ]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:746">
<![LOG[Request location: HTTP://<MP>/SMS_MP/.SMS_POL?{3B800AB4-058A-45DA-A407-FB4C301AA5E1}/4.SHA256:98B9068EA1A0739D16C0FF34C8E47DD51350A98FB9793269151028B498FCFED9]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4815">
<![LOG[Response ID: {3B800AB4-058A-45DA-A407-FB4C301AA5E1}/4]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4816">
<![LOG[Reading Policy Body.]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2071">
<![LOG[Parsing Policy Body.]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2078">
<![LOG[Found property CCM_ClientAgentConfig.BrandingTitle = ]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:1706">
<![LOG[Client agent branding title is empty. Ignoring.]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="2" thread="1516" file="tsmediawizardcontrol.cpp:1839">
<![LOG[setting Client ID in Task Sequencing Environment.]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1845">
<![LOG[Not using the unknown machine name]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tsmediawizardcontrol.cpp:1855">
<![LOG[setting SysHealthConfig policy in the environment.]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1874">
<![LOG[Downloading policy body {6bc5392a-ad33-443d-9856-09918e459461}.]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2040">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2043">
<![LOG[ Setting transport.]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2044">
<![LOG[ Setting policy location = http://<mp>/SMS_MP/.sms_pol?{6bc5392a-ad33-443d-9856-09918e459461}.1_00.]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2046">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2063">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 GET /SMS_MP/.sms_pol?{6bc5392a-ad33-443d-9856-09918e459461}.1_00]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:8956">
<![LOG[Request location: HTTP://<MP>/SMS_MP/.SMS_POL?{6BC5392A-AD33-443D-9856-09918E459461}.1_00]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4815">
<![LOG[Response ID: {6BC5392A-AD33-443D-9856-09918E459461}]LOG]!><time="13:10:11.513+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4816">
<![LOG[Reading Policy Body.]LOG]!><time="13:10:11.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2071">
<![LOG[Parsing Policy Body.]LOG]!><time="13:10:11.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2078">
<![LOG[::CompressBuffer(65536,-1)]LOG]!><time="13:10:11.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:700">
<![LOG[Compression (zlib) succeeded: original size 4652, compressed size 690.]LOG]!><time="13:10:11.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:489">
<![LOG[setting SoftUpdConfig policy in the environment.]LOG]!><time="13:10:11.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1882">
<![LOG[Downloading policy body {43ab0dae-00cc-4d0c-a223-6ba0faa2c36d}.]LOG]!><time="13:10:11.529+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2040">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:10:11.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2043">
<![LOG[ Setting transport.]LOG]!><time="13:10:11.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2044">
<![LOG[ Setting policy location = http://<mp>/SMS_MP/.sms_pol?{43ab0dae-00cc-4d0c-a223-6ba0faa2c36d}.1_00.]LOG]!><time="13:10:11.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2046">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:10:11.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2063">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 GET /SMS_MP/.sms_pol?{43ab0dae-00cc-4d0c-a223-6ba0faa2c36d}.1_00]LOG]!><time="13:10:11.529+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:11.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:8956">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32780, HashSize: 32 ]LOG]!><time="13:10:11.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:699">
<![LOG[Expected Hash size: 32, Computed Hash size: 32 ]LOG]!><time="13:10:11.529+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:746">
<![LOG[Request location: HTTP://<MP>/SMS_MP/.SMS_POL?{43AB0DAE-00CC-4D0C-A223-6BA0FAA2C36D}.1_00]LOG]!><time="13:10:11.529+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4815">
<![LOG[Response ID: {43AB0DAE-00CC-4D0C-A223-6BA0FAA2C36D}]LOG]!><time="13:10:11.529+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4816">
<![LOG[Downloading policy body {3B800AB4-058A-45DA-A407-FB4C301AA5E1}/9.]LOG]!><time="13:10:11.545+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2040">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:10:11.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2043">
<![LOG[ Setting transport.]LOG]!><time="13:10:11.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2044">
<![LOG[ Setting policy location = http://<mp>/SMS_MP/.sms_pol?{3B800AB4-058A-45DA-A407-FB4C301AA5E1}/9.SHA256:894EE09FC5BBB71C50D95C57FE93363BBA589E4F42029CF93B74258220718A7A.]LOG]!><time="13:10:11.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2046">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:10:11.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2063">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 GET /SMS_MP/.sms_pol?{3B800AB4-058A-45DA-A407-FB4C301AA5E1}/9.SHA256:894EE09FC5BBB71C50D95C57FE93363BBA589E4F42029CF93B74258220718A7A]LOG]!><time="13:10:11.545+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:11.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:8956">
<![LOG[::DecompressBuffer(65536)]LOG]!><time="13:10:11.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:739">
<![LOG[Decompression (zlib) succeeded: original size 1567, uncompressed size 13956.]LOG]!><time="13:10:11.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:651">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32780, HashSize: 32 ]LOG]!><time="13:10:11.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:699">
<![LOG[Expected Hash size: 32, Computed Hash size: 32 ]LOG]!><time="13:10:11.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:746">
<![LOG[Request location: HTTP://<MP>/SMS_MP/.SMS_POL?{3B800AB4-058A-45DA-A407-FB4C301AA5E1}/9.SHA256:894EE09FC5BBB71C50D95C57FE93363BBA589E4F42029CF93B74258220718A7A]LOG]!><time="13:10:11.545+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4815">
<![LOG[Response ID: {3B800AB4-058A-45DA-A407-FB4C301AA5E1}/9]LOG]!><time="13:10:11.545+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4816">
<![LOG[Reading Policy Body.]LOG]!><time="13:10:11.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2071">
<![LOG[Parsing Policy Body.]LOG]!><time="13:10:11.545+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2078">
<![LOG[::CompressBuffer(65536,-1)]LOG]!><time="13:10:11.560+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:700">
<![LOG[Compression (zlib) succeeded: original size 29690, compressed size 2011.]LOG]!><time="13:10:11.560+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:489">
<![LOG[setting SoftDistClient config policy in the environment.]LOG]!><time="13:10:11.560+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1890">
<![LOG[Downloading policy body {da0ffa55-741a-4f6b-8110-bbbbf7395864}.]LOG]!><time="13:10:11.560+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2040">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:10:11.560+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2043">
<![LOG[ Setting transport.]LOG]!><time="13:10:11.560+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2044">
<![LOG[ Setting policy location = http://<mp>/SMS_MP/.sms_pol?{da0ffa55-741a-4f6b-8110-bbbbf7395864}.1_00.]LOG]!><time="13:10:11.560+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2046">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:10:11.560+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2063">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 GET /SMS_MP/.sms_pol?{da0ffa55-741a-4f6b-8110-bbbbf7395864}.1_00]LOG]!><time="13:10:11.560+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:11.560+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:8956">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32780, HashSize: 32 ]LOG]!><time="13:10:11.560+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:699">
<![LOG[Expected Hash size: 32, Computed Hash size: 32 ]LOG]!><time="13:10:11.560+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:746">
<![LOG[Request location: HTTP://<MP>/SMS_MP/.SMS_POL?{DA0FFA55-741A-4F6B-8110-BBBBF7395864}.1_00]LOG]!><time="13:10:11.560+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4815">
<![LOG[Response ID: {DA0FFA55-741A-4F6B-8110-BBBBF7395864}]LOG]!><time="13:10:11.560+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4816">
<![LOG[Reading Policy Body.]LOG]!><time="13:10:11.560+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2071">
<![LOG[Parsing Policy Body.]LOG]!><time="13:10:11.560+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2078">
<![LOG[::CompressBuffer(65536,-1)]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:700">
<![LOG[Compression (zlib) succeeded: original size 13742, compressed size 1330.]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:489">
<![LOG[setting software update policy in the environment.]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1898">
<![LOG[bad zlib compression ratio: original size 32, compressed size 38.]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:480">
<![LOG[setting software update policy in the environment.]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1906">
<![LOG[Downloading policy body {64c8008d-de87-4083-9b9e-4941a59115e4}.]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2040">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2043">
<![LOG[ Setting transport.]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2044">
<![LOG[ Setting policy location = http://<mp>/SMS_MP/.sms_pol?{64c8008d-de87-4083-9b9e-4941a59115e4}.1_00.]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2046">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2063">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 GET /SMS_MP/.sms_pol?{64c8008d-de87-4083-9b9e-4941a59115e4}.1_00]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:8956">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32780, HashSize: 32 ]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:699">
<![LOG[Expected Hash size: 32, Computed Hash size: 32 ]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:746">
<![LOG[Request location: HTTP://<MP>/SMS_MP/.SMS_POL?{64C8008D-DE87-4083-9B9E-4941A59115E4}.1_00]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4815">
<![LOG[Response ID: {64C8008D-DE87-4083-9B9E-4941A59115E4}]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4816">
<![LOG[Reading Policy Body.]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2071">
<![LOG[Parsing Policy Body.]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2078">
<![LOG[Compression (zlib) succeeded: original size 372, compressed size 181.]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:489">
<![LOG[setting quarantine policy in the environment.]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1914">
<![LOG[Downloading policy body {c1636d3d-7666-4374-9661-de41d9ac80c2}.]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2040">
<![LOG[ Setting policy location = http://<mp>/SMS_MP/.sms_pol?{c1636d3d-7666-4374-9661-de41d9ac80c2}.1_00.]LOG]!><time="13:10:11.576+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2046">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2063">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 GET /SMS_MP/.sms_pol?{c1636d3d-7666-4374-9661-de41d9ac80c2}.1_00]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:8956">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32780, HashSize: 32 ]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:699">
<![LOG[Expected Hash size: 32, Computed Hash size: 32 ]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:746">
<![LOG[Request location: HTTP://<MP>/SMS_MP/.SMS_POL?{C1636D3D-7666-4374-9661-DE41D9AC80C2}.1_00]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4815">
<![LOG[Response ID: {C1636D3D-7666-4374-9661-DE41D9AC80C2}]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4816">
<![LOG[Reading Policy Body.]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2071">
<![LOG[Parsing Policy Body.]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2078">
<![LOG[::CompressBuffer(65536,-1)]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:700">
<![LOG[Compression (zlib) succeeded: original size 2274, compressed size 563.]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:489">
<![LOG[setting NAAConfig policy in the environment.]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1922">
<![LOG[Compression (zlib) succeeded: original size 2940, compressed size 772.]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:489">
<![LOG[setting CIVersionInfo policy in the environment.]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1930">
<![LOG[bad zlib compression ratio: original size 32, compressed size 38.]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:480">
<![LOG[CIVersionInfo policy: <PolicyList/>
]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1936">
<![LOG[setting RebootSettingsConfig policy in the environment.]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1939">
<![LOG[Downloading policy body {cf9f153a-5b22-476b-870c-6d41be176cd2}.]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2040">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2043">
<![LOG[ Setting transport.]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2044">
<![LOG[ Setting policy location = http://<mp>/SMS_MP/.sms_pol?{cf9f153a-5b22-476b-870c-6d41be176cd2}.1_00.]LOG]!><time="13:10:11.591+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2046">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 GET /SMS_MP/.sms_pol?{cf9f153a-5b22-476b-870c-6d41be176cd2}.1_00]LOG]!><time="13:10:11.607+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:11.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:8956">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32780, HashSize: 32 ]LOG]!><time="13:10:11.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:699">
<![LOG[Expected Hash size: 32, Computed Hash size: 32 ]LOG]!><time="13:10:11.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:746">
<![LOG[Request location: HTTP://<MP>/SMS_MP/.SMS_POL?{CF9F153A-5B22-476B-870C-6D41BE176CD2}.1_00]LOG]!><time="13:10:11.607+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4815">
<![LOG[Response ID: {CF9F153A-5B22-476B-870C-6D41BE176CD2}]LOG]!><time="13:10:11.607+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4816">
<![LOG[Reading Policy Body.]LOG]!><time="13:10:11.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2071">
<![LOG[Parsing Policy Body.]LOG]!><time="13:10:11.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2078">
<![LOG[::CompressBuffer(65536,-1)]LOG]!><time="13:10:11.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:700">
<![LOG[Compression (zlib) succeeded: original size 1556, compressed size 431.]LOG]!><time="13:10:11.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:489">
<![LOG[setting AppManClientConfig policy in the environment.]LOG]!><time="13:10:11.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tsmediawizardcontrol.cpp:1947">
<![LOG[Downloading policy body {9fd5ed01-11dd-4bbd-a589-6adeb798ded1}.]LOG]!><time="13:10:11.607+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tspolicy.cpp:2040">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:10:11.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2043">
<![LOG[ Setting transport.]LOG]!><time="13:10:11.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2044">
<![LOG[ Setting policy location = http://<mp>/SMS_MP/.sms_pol?{9fd5ed01-11dd-4bbd-a589-6adeb798ded1}.1_00.]LOG]!><time="13:10:11.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2046">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:10:11.607+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2063">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 GET /SMS_MP/.sms_pol?{9fd5ed01-11dd-4bbd-a589-6adeb798ded1}.1_00]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libsmsmessaging.cpp:8956">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32780, HashSize: 32 ]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:699">
<![LOG[Expected Hash size: 32, Computed Hash size: 32 ]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="libcrypt.cpp:746">
<![LOG[Request location: HTTP://<MP>/SMS_MP/.SMS_POL?{9FD5ED01-11DD-4BBD-A589-6ADEB798DED1}.1_00]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4815">
<![LOG[Response ID: {9FD5ED01-11DD-4BBD-A589-6ADEB798DED1}]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="libsmsmessaging.cpp:4816">
<![LOG[Reading Policy Body.]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2071">
<![LOG[Parsing Policy Body.]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="tspolicy.cpp:2078">
<![LOG[::CompressBuffer(65536,-1)]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:700">
<![LOG[Compression (zlib) succeeded: original size 6100, compressed size 956.]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="ccmzlib.cpp:489">
<![LOG[Launch mode read from environment variable: 'PXE'.']LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tsmediawizardcontrol.cpp:1975">
<![LOG[bootpackageID: SPF00005 AssociatedWInPE: SPF00005 SourceVersion: 6 AssociatedSourceVersion: 6]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tsmediawizardcontrol.cpp:2102">
<![LOG[WinPE assocated with task sequence is the same as the boot media.]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tsmediawizardcontrol.cpp:2116">
<![LOG[setting time zone info to ]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tsmediawizardcontrol.cpp:2122">
<![LOG[No TimeZone information to set.]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tsmbootstraputil.cpp:201">
<![LOG[starting Task Sequence Manager.]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tsmediawizardcontrol.cpp:2132">
<![LOG[executing TS Manager not in full media]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tsmbootstraputil.cpp:537">
<![LOG[executing TS Manager in x:\sms\bin\x64]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="tsmbootstraputil.cpp:548">
<![LOG[Command line for extension .exe is "%1" %*]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="commandline.cpp:228">
<![LOG[set command line: "TsManager.exe"]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="0" thread="1516" file="commandline.cpp:731">
<![LOG[Executing command line: "TsManager.exe"]LOG]!><time="13:10:11.623+00" date="03-05-2014" component="TSPxe" context="" type="1" thread="1516" file="commandline.cpp:827">
<![LOG[successfully intialized Logging for TS Manager.]LOG]!><time="13:10:11.654+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsmanager.cpp:705">
<![LOG[Commandline: "TsManager.exe"]LOG]!><time="13:10:11.654+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsmanager.cpp:60">
<![LOG[/service parameter found at index: -1]LOG]!><time="13:10:11.654+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsmanager.cpp:67">
<![LOG[/standalone parameter found at index: -1]LOG]!><time="13:10:11.654+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsmanager.cpp:77">
<![LOG[/noclient parameter found at index: -1]LOG]!><time="13:10:11.654+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsmanager.cpp:98">
<![LOG[successfully registered Task Sequencing COM Interface.]LOG]!><time="13:10:11.654+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="environmentlib.cpp:799">
<![LOG[Executing as a standalone exe]LOG]!><time="13:10:11.654+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsmanager.cpp:723">
<![LOG[initializing TS Environment]LOG]!><time="13:10:11.654+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsmanager.cpp:994">
<![LOG[Opening Task Sequencing Environment]LOG]!><time="13:10:11.654+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsmanager.cpp:1031">
<![LOG[Env variable _SMSTSProtectedPaths set to %OSDStateStorePath%;%_SMSTSClientCache%;%_SMSTSNewClientCachePathToCleanup%]LOG]!><time="13:10:11.654+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsmanager.cpp:968">
<![LOG[!sVolumeID.empty(), HRESULT=80004005 (e:\nts_sccm_release\sms\framework\tscore\resolvesource.cpp,478)]LOG]!><time="13:10:11.669+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="resolvesource.cpp:478">
<![LOG[Deleting volume ID file C:\_SMSTSVolumeID.7159644d-f741-45d5-ab29-0ad8aa4771ca ...]LOG]!><time="13:10:11.669+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="resolvesource.cpp:519">
<![LOG[DeleteFileW(sVolumeIDFile.c_str()), HRESULT=80070002 (e:\nts_sccm_release\sms\framework\tscore\resolvesource.cpp,521)]LOG]!><time="13:10:11.669+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="resolvesource.cpp:521">
<![LOG[pwszPath && *pwszPath, HRESULT=80070057 (e:\nts_sccm_release\sms\framework\tscore\resolvesource.cpp,255)]LOG]!><time="13:10:11.669+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="resolvesource.cpp:255">
<![LOG[Executing in WinPE]LOG]!><time="13:10:11.669+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsmanager.cpp:1161">
<![LOG[_SMSTSReturnToGINA variable set to ]LOG]!><time="13:10:11.669+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsmanager.cpp:1176">
<![LOG[initializing TS Engine]LOG]!><time="13:10:11.669+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsmanager.cpp:1340">
<![LOG[Getting TaskSequenceXML from environment]LOG]!><time="13:10:11.669+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsmanager.cpp:1349">
<![LOG[Parsing task sequence . . .]LOG]!><time="13:10:11.669+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsmanager.cpp:1370">
<![LOG[Loaded TS from string]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:86">
<![LOG[Parsing task sequence to get schema version]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:106">
<![LOG[Task sequence version 3.00]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="tsmanager.cpp:1375">
<![LOG[Task sequence schema version is 3.00]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="tsmanager.cpp:1301">
<![LOG[Current supported schema version is 3.10 and 3.00]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="tsmanager.cpp:1309">
<![LOG[Processing get action table request]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:139">
<![LOG[Got root node now getting list of all child elements]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:150">
<![LOG[There are 7 first level steps or groups]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:318">
<![LOG[Processing group]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:443">
<![LOG[
Parsing group node: Install Operating System]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:366">
<![LOG[Description: ]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:370">
<![LOG[ContinueOnError: ]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:374">
<![LOG[Disable: ]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:382">
<![LOG[(__hrMethodRetVal == ((HRESULT)0L)) || (bFailIfMissing == false), HRESULT=80070002 (e:\NTS_SCCM_RELEASE\sms\common\inc\ccmxml.h,582)]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="ccmxml.h:582">
<![LOG[No condition is associated with the step.]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:670">
<![LOG[Adding begin group instruction at 0]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:393">
<![LOG[There are 0 first level steps or groups]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:318">
<![LOG[Processed all elements]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:333">
<![LOG[Adding end group instruction at 1]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:402">
<![LOG[The next instruction after group will be at 2]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:408">
<![LOG[
Parsing step node: Restart Computer]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:459">
<![LOG[Description: ]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:463">
<![LOG[ContinueOnError: true]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:467">
<![LOG[successCodeList: 0]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:475">
<![LOG[Disable: true]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:484">
<![LOG[Run in attribute: WinPEandFullOS]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:492">
<![LOG[Timeout: ]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:496">
<![LOG[DefaultVarlist found]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:579">
<![LOG[Variable name: SMSRebootMessage]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: SMSRebootTimeout]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Action command line: smsboot.exe /target:WinPE]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:522">
<![LOG[Adding instruction at 2]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:524">
<![LOG[
Parsing step node: Format and Partition Disk]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:459">
<![LOG[Disable: ]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:484">
<![LOG[Run in attribute: WinPE]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:492">
<![LOG[Variable name: OSDDiskIndex]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDDiskType]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDDiskpartBiosCompatibilityMode]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDGPTBootDisk]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDPartitionStyle]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDPartitions0AssignVolumeLetter]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDPartitions0Bootable]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDPartitions0FileSystem]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDPartitions0QuickFormat]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDPartitions0Size]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDPartitions0SizeUnits]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDPartitions0Type]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDPartitions0VolumeLetterVariable]LOG]!><time="13:10:11.685+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDPartitions0VolumeName]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Action command line: osddiskpart.exe]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:522">
<![LOG[Adding instruction at 3]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:524">
<![LOG[
Parsing step node: Apply Operating System Image]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:459">
<![LOG[Description: ]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:463">
<![LOG[ContinueOnError: true]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:467">
<![LOG[successCodeList: 0]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:475">
<![LOG[(__hrMethodRetVal == ((HRESULT)0L)) || (bFailIfMissing == false), HRESULT=80070002 (e:\NTS_SCCM_RELEASE\sms\common\inc\ccmxml.h,582)]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="ccmxml.h:582">
<![LOG[No condition is associated with the step.]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:670">
<![LOG[Disable: ]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:484">
<![LOG[Run in attribute: WinPE]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:492">
<![LOG[Timeout: ]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:496">
<![LOG[DefaultVarlist found]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:579">
<![LOG[Variable name: OSDInstallEditionIndex]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Action command line: OSDApplyOS.exe /install:SPF0000F,%OSDInstallEditionIndex% /target:C: /runfromnet:False]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:522">
<![LOG[Adding instruction at 4]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:524">
<![LOG[
Parsing step node: Apply Windows Settings]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:459">
<![LOG[Variable name: OSDLocalAdminPassword]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDComputerName]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDProductKey]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDRandomAdminPassword]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDRegisteredOrgName]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDRegisteredUserName]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDServerLicenseConnectionLimit]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDTimeZone]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Action command line: osdwinsettings.exe /config]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:522">
<![LOG[Adding instruction at 5]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:524">
<![LOG[
Parsing step node: Apply Network Settings]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:459">
<![LOG[Run in attribute: WinPEandFullOS]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:492">
<![LOG[Variable name: OSDJoinAccount]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDNetworkJoinType]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: OSDWorkgroupName]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Action command line: osdnetsettings.exe configure]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:522">
<![LOG[Adding instruction at 6]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:524">
<![LOG[
Parsing step node: Setup Windows and ConfigMgr]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:459">
<![LOG[Variable name: SMSClientInstallProperties]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Variable name: _SMSClientPackageID]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:620">
<![LOG[Action command line: OSDSetupWindows.exe]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:522">
<![LOG[Adding instruction at 7]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:524">
<![LOG[Processed all elements]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:333">
<![LOG[
Reading Global variable list]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:183">
<![LOG[Got root node now getting global var list]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:194">
<![LOG[GlobalVarlist found]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:210">
<![LOG[Variable name: OSDEnableTCPIPFiltering]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:244">
<![LOG[Variable name: OSDAdapterCount]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsxml.cpp:244">
<![LOG[starting Task Sequence Engine . . . ]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsmanager.cpp:857">
<![LOG[****************************************************************************]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="tsmanager.cpp:859">
<![LOG[set a global environment variable _SMSTSNextInstructionPointer=0]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[set a global environment variable _SMSTSInstructionTableSize=8]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[set a global environment variable SMSTSRebootRequested=]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[set a global environment variable SMSTSRebootDelay=]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[set a global environment variable SMSTSRebootMessage=]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[set a global environment variable SMSTSRebootReason=]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[set a global environment variable SMSTSRetryRequested=]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\x64\1033\TSRES.DLL']LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="util.cpp:963">
<![LOG[The task execution engine started execution]LOG]!><time="13:10:11.701+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="engine.cxx:70">
<![LOG[MP server http://SV-DCSCCM-01.spitfire.local. Ports 80,443. CRL=false.]LOG]!><time="13:10:11.716+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="utils.cpp:5300">
<![LOG[setting authenticator]LOG]!><time="13:10:11.732+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="utils.cpp:5322">
<![LOG[set authenticator in transport]LOG]!><time="13:10:11.732+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:7751">
<![LOG[sending StatusMessage]LOG]!><time="13:10:11.747+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="libsmsmessaging.cpp:4025">
<![LOG[setting message signatures.]LOG]!><time="13:10:11.763+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:1297">
<![LOG[setting the authenticator.]LOG]!><time="13:10:11.763+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:1327">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 CCM_POST /ccm_system/request]LOG]!><time="13:10:11.763+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:11.779+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:8956">
<![LOG[MP server http://SV-DCSCCM-01.spitfire.local. Ports 80,443. CRL=false.]LOG]!><time="13:10:11.779+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="utils.cpp:5300">
<![LOG[setting authenticator]LOG]!><time="13:10:11.810+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="utils.cpp:5322">
<![LOG[set authenticator in transport]LOG]!><time="13:10:11.810+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:7751">
<![LOG[sending StatusMessage]LOG]!><time="13:10:11.825+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="libsmsmessaging.cpp:4025">
<![LOG[setting message signatures.]LOG]!><time="13:10:11.825+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:1297">
<![LOG[setting the authenticator.]LOG]!><time="13:10:11.825+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:1327">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 CCM_POST /ccm_system/request]LOG]!><time="13:10:11.825+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:11.841+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:8956">
<![LOG[start executing an instruction. Instruction name: Install Operating System. Instruction pointer: 0]LOG]!><time="13:10:11.841+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="engine.cxx:117">
<![LOG[set a global environment variable _SMSTSCurrentActionName=Install Operating System]LOG]!><time="13:10:11.841+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[set a global environment variable _SMSTSNextInstructionPointer=0]LOG]!><time="13:10:11.841+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[The group (Install Operating System) has been successfully started]LOG]!><time="13:10:11.872+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="instruction.cxx:2364">
<![LOG[MP server http://SV-DCSCCM-01.spitfire.local. Ports 80,443. CRL=false.]LOG]!><time="13:10:11.872+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="utils.cpp:5300">
<![LOG[setting authenticator]LOG]!><time="13:10:11.903+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="utils.cpp:5322">
<![LOG[set authenticator in transport]LOG]!><time="13:10:11.903+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:7751">
<![LOG[sending StatusMessage]LOG]!><time="13:10:11.919+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="libsmsmessaging.cpp:4025">
<![LOG[setting message signatures.]LOG]!><time="13:10:11.919+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:1297">
<![LOG[setting the authenticator.]LOG]!><time="13:10:11.919+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:1327">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 CCM_POST /ccm_system/request]LOG]!><time="13:10:11.919+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:11.935+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:8956">
<![LOG[updated security on object C:\_SMSTaskSequence.]LOG]!><time="13:10:11.935+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="utils.cpp:1121">
<![LOG[set a global environment variable _SMSTSNextInstructionPointer=1]LOG]!><time="13:10:11.935+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[set a TS execution environment variable _SMSTSNextInstructionPointer=1]LOG]!><time="13:10:11.935+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:386">
<![LOG[set a global environment variable _SMSTSInstructionStackString=0]LOG]!><time="13:10:11.935+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[set a TS execution environment variable _SMSTSInstructionStackString=0]LOG]!><time="13:10:11.935+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:414">
<![LOG[save the current environment block]LOG]!><time="13:10:11.935+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:833">
<![LOG[successfully save execution state and environment to local hard disk]LOG]!><time="13:10:11.950+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="engine.cxx:255">
<![LOG[start executing an instruction. Instruction name: Install Operating System. Instruction pointer: 1]LOG]!><time="13:10:11.950+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="engine.cxx:117">
<![LOG[set a global environment variable _SMSTSCurrentActionName=Install Operating System]LOG]!><time="13:10:11.950+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[set a global environment variable _SMSTSNextInstructionPointer=1]LOG]!><time="13:10:11.950+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[The group (Install Operating System) has been successfully completed]LOG]!><time="13:10:11.950+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="instruction.cxx:2552">
<![LOG[MP server http://SV-DCSCCM-01.spitfire.local. Ports 80,443. CRL=false.]LOG]!><time="13:10:11.966+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="utils.cpp:5300">
<![LOG[setting authenticator]LOG]!><time="13:10:11.981+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="utils.cpp:5322">
<![LOG[set authenticator in transport]LOG]!><time="13:10:11.981+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:7751">
<![LOG[sending StatusMessage]LOG]!><time="13:10:11.997+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="libsmsmessaging.cpp:4025">
<![LOG[setting message signatures.]LOG]!><time="13:10:11.997+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:1297">
<![LOG[setting the authenticator.]LOG]!><time="13:10:11.997+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:1327">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 CCM_POST /ccm_system/request]LOG]!><time="13:10:11.997+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:12.013+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:8956">
<![LOG[updated security on object C:\_SMSTaskSequence.]LOG]!><time="13:10:12.013+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="utils.cpp:1121">
<![LOG[set a global environment variable _SMSTSNextInstructionPointer=2]LOG]!><time="13:10:12.013+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[set a TS execution environment variable _SMSTSNextInstructionPointer=2]LOG]!><time="13:10:12.013+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:386">
<![LOG[set a global environment variable _SMSTSInstructionStackString=]LOG]!><time="13:10:12.013+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[set a TS execution environment variable _SMSTSInstructionStackString=]LOG]!><time="13:10:12.013+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:414">
<![LOG[save the current environment block]LOG]!><time="13:10:12.013+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:833">
<![LOG[successfully save execution state and environment to local hard disk]LOG]!><time="13:10:12.044+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="engine.cxx:255">
<![LOG[start executing an instruction. Instruction name: Restart Computer. Instruction pointer: 2]LOG]!><time="13:10:12.044+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="engine.cxx:117">
<![LOG[set a global environment variable _SMSTSCurrentActionName=Restart Computer]LOG]!><time="13:10:12.044+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[set a global environment variable _SMSTSNextInstructionPointer=2]LOG]!><time="13:10:12.044+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[The action (Restart Computer) has been skipped because it is disabled]LOG]!><time="13:10:12.044+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="instruction.cxx:2815">
<![LOG[MP server http://SV-DCSCCM-01.spitfire.local. Ports 80,443. CRL=false.]LOG]!><time="13:10:12.044+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="utils.cpp:5300">
<![LOG[setting authenticator]LOG]!><time="13:10:12.059+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="utils.cpp:5322">
<![LOG[set authenticator in transport]LOG]!><time="13:10:12.059+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:7751">
<![LOG[sending StatusMessage]LOG]!><time="13:10:12.075+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="libsmsmessaging.cpp:4025">
<![LOG[setting message signatures.]LOG]!><time="13:10:12.091+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:1297">
<![LOG[setting the authenticator.]LOG]!><time="13:10:12.091+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:1327">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 CCM_POST /ccm_system/request]LOG]!><time="13:10:12.091+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:12.091+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:8956">
<![LOG[Clear local default environment]LOG]!><time="13:10:12.091+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:807">
<![LOG[Execution of the instruction (Restart Computer) has been skipped]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="engine.cxx:193">
<![LOG[start executing an instruction. Instruction name: Format and Partition Disk. Instruction pointer: 3]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="engine.cxx:117">
<![LOG[set a global environment variable _SMSTSCurrentActionName=Format and Partition Disk]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[set a global environment variable _SMSTSNextInstructionPointer=3]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[set a local default variable OSDDiskIndex]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:700">
<![LOG[set a local default variable OSDDiskType]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:700">
<![LOG[set a local default variable OSDDiskpartBiosCompatibilityMode]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:700">
<![LOG[set a local default variable OSDGPTBootDisk]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:700">
<![LOG[set a local default variable OSDPartitionStyle]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:700">
<![LOG[set a local default variable OSDPartitions0AssignVolumeLetter]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:700">
<![LOG[set a local default variable OSDPartitions0Bootable]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:700">
<![LOG[set a local default variable OSDPartitions0FileSystem]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:700">
<![LOG[set a local default variable OSDPartitions0QuickFormat]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:700">
<![LOG[set a local default variable OSDPartitions0Size]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:700">
<![LOG[set a local default variable OSDPartitions0SizeUnits]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:700">
<![LOG[set a local default variable OSDPartitions0Type]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:700">
<![LOG[set a local default variable OSDPartitions0VolumeLetterVariable]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:700">
<![LOG[set a local default variable OSDPartitions0VolumeName]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:700">
<![LOG[set a global environment variable _SMSTSLogPath=X:\WINDOWS\TEMP\SMSTSLog]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[Expand a string: osddiskpart.exe]LOG]!><time="13:10:12.106+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:782">
<![LOG[Expand a string: ]LOG]!><time="13:10:12.122+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:782">
<![LOG[Command line for extension .exe is "%1" %*]LOG]!><time="13:10:12.122+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="commandline.cpp:228">
<![LOG[set command line: osddiskpart.exe]LOG]!><time="13:10:12.122+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="commandline.cpp:731">
<![LOG[start executing the command line: osddiskpart.exe]LOG]!><time="13:10:12.122+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="instruction.cxx:2930">
<![LOG[!--------------------------------------------------------------------------------------------!]LOG]!><time="13:10:12.122+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="instruction.cxx:2959">
<![LOG[Expand a string: WinPE]LOG]!><time="13:10:12.122+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:782">
<![LOG[Executing command line: osddiskpart.exe]LOG]!><time="13:10:12.122+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="commandline.cpp:827">
<![LOG[==============================[ OSDDiskPart.exe ]==============================]LOG]!><time="13:10:12.153+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:1078">
<![LOG[Command line: "osddiskpart.exe"]LOG]!><time="13:10:12.153+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:1079">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\x64\1033\TSRES.DLL']LOG]!><time="13:10:12.153+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="util.cpp:963">
<![LOG[Reading partition size info for partition 0]LOG]!><time="13:10:12.309+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:461">
<![LOG[Remaining size before partition: 80023265280]LOG]!><time="13:10:12.309+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:465">
<![LOGLOG]!><time="13:10:12.309+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:478">
<![LOG[100% size specified.]LOG]!><time="13:10:12.309+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:524">
<![LOG[Remaining size after partition 0: 0]LOG]!><time="13:10:12.309+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:618">
<![LOG[set an environment variable for partitions 0-1 with drive letter]LOG]!><time="13:10:12.309+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:641">
<![LOG[Checking volume 'C:' for BitLocker]LOG]!><time="13:10:12.325+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:317">
<![LOG[Volume 'C:' is on disk '0l']LOG]!><time="13:10:12.325+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:325">
<![LOG[Volume 'C:' is fully decrypted]LOG]!><time="13:10:12.403+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:363">
<![LOG[Checking volume 'D:' for BitLocker]LOG]!><time="13:10:12.403+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:317">
<![LOG[Checking volume 'X:' for BitLocker]LOG]!><time="13:10:12.403+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:317">
<![LOG[Diskpart: select disk 0
clean
create partition PRIMARY
assign
active
rescan
]LOG]!><time="13:10:12.403+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="diskutils.cpp:2497">
<![LOG[Executing diskpart script: select disk 0
clean
assign
active
rescan
]LOG]!><time="13:10:12.403+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="diskutils.cpp:1865">
<![LOG[Command line for extension .exe is "%1" %*]LOG]!><time="13:10:12.403+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="commandline.cpp:228">
<![LOG[set command line: "X:\WINDOWS\system32\diskpart.exe" /s "X:\WINDOWS\TEMP\DiskPartScript.txt"]LOG]!><time="13:10:12.403+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="commandline.cpp:731">
<![LOG[Executing command line: "X:\WINDOWS\system32\diskpart.exe" /s "X:\WINDOWS\TEMP\DiskPartScript.txt"]LOG]!><time="13:10:12.403+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="commandline.cpp:827">
<![LOG[Process completed with exit code 0]LOG]!><time="13:10:21.114+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="commandline.cpp:1123">
<![LOG[Formatting partitions]LOG]!><time="13:10:21.145+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:906">
<![LOG[Partition: 1 PRIMARY]LOG]!><time="13:10:21.145+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:920">
<![LOG[Adding logical drive: C:]LOG]!><time="13:10:21.145+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="diskutils.cpp:1537">
<![LOG[skipping non-local logical drive: D:]LOG]!><time="13:10:21.145+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="diskutils.cpp:1543">
<![LOG[skipping non-local logical drive: X:]LOG]!><time="13:10:21.145+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="diskutils.cpp:1543">
<![LOG[Formatting drive C: with NTFS filesystem, method quick]LOG]!><time="13:10:21.160+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:993">
<![LOG[Creating instance of service loader]LOG]!><time="13:10:21.160+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:908">
<![LOG[Loading service]LOG]!><time="13:10:21.192+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:913">
<![LOG[Waiting for service to initialize]LOG]!><time="13:10:21.192+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:920">
<![LOG[Querying for software providers]LOG]!><time="13:10:21.192+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:924">
<![LOG[Found a VDS software provider]LOG]!><time="13:10:21.192+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:934">
<![LOG[Querying for IVdsSwProvider]LOG]!><time="13:10:21.192+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:938">
<![LOG[Querying for packs]LOG]!><time="13:10:21.192+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:943">
<![LOG[Found a VDS pack]LOG]!><time="13:10:21.192+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:952">
<![LOG[Querying for IVdsPack]LOG]!><time="13:10:21.192+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:956">
<![LOG[Querying for volumes]LOG]!><time="13:10:21.192+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:961">
<![LOG[Found a VDS pack]LOG]!><time="13:10:21.207+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:952">
<![LOG[Querying for IVdsPack]LOG]!><time="13:10:21.207+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:956">
<![LOG[Querying for volumes]LOG]!><time="13:10:21.207+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:961">
<![LOG[Found a VDS volume]LOG]!><time="13:10:21.207+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:970">
<![LOG[Querying for IVdsVolumeMF]LOG]!><time="13:10:21.207+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:974">
<![LOG[Querying for access paths]LOG]!><time="13:10:21.207+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:980">
<![LOG[Found a volume with access path 'C:\']LOG]!><time="13:10:21.207+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:992">
<![LOG[Querying for IVdsVolume]LOG]!><time="13:10:21.207+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:995">
<![LOG[Querying for IVdsVolumeMF]LOG]!><time="13:10:21.207+00" date="03-05-2014" component="OSDDiskPart" context="" type="0" thread="1640" file="diskvolume.cpp:1071">
<![LOG[OSDDiskPart.exe completed successfully]LOG]!><time="13:10:26.273+00" date="03-05-2014" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:1309">
<![LOG[Process completed with exit code 0]LOG]!><time="13:10:26.273+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="commandline.cpp:1123">
<![LOG[!--------------------------------------------------------------------------------------------!]LOG]!><time="13:10:26.273+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="instruction.cxx:3012">
<![LOG[successfully completed the action (Format and Partition Disk) with the exit win32 code 0]LOG]!><time="13:10:26.273+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="instruction.cxx:3038">
<![LOG[MP server http://SV-DCSCCM-01.spitfire.local. Ports 80,443. CRL=false.]LOG]!><time="13:10:26.289+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="utils.cpp:5300">
<![LOG[setting authenticator]LOG]!><time="13:10:26.320+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="utils.cpp:5322">
<![LOG[set authenticator in transport]LOG]!><time="13:10:26.336+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:7751">
<![LOG[sending StatusMessage]LOG]!><time="13:10:26.367+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="libsmsmessaging.cpp:4025">
<![LOG[setting message signatures.]LOG]!><time="13:10:26.383+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:1297">
<![LOG[setting the authenticator.]LOG]!><time="13:10:26.383+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:1327">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SV-DCSCCM-01.spitfire.local:80 CCM_POST /ccm_system/request]LOG]!><time="13:10:26.383+00" date="03-05-2014" component="TSManager" context="" type="1" thread="1552" file="libsmsmessaging.cpp:8621">
<![LOG[Request was succesful.]LOG]!><time="13:10:26.383+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="libsmsmessaging.cpp:8956">
<![LOG[set a global environment variable _SMSTSLastActionRetCode=0]LOG]!><time="13:10:26.398+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[set a global environment variable _SMSTSLastActionSucceeded=true]LOG]!><time="13:10:26.398+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:668">
<![LOG[Expand a string: %_SMSTSMDataPath%\Logs]LOG]!><time="13:10:26.398+00" date="03-05-2014" component="TSManager" context="" type="0" thread="1552" file="executionenv.cxx:782">
Cheers
Paul
Looks like your laptop drive is encrypted with bit locker. Your process might be slowed down by that.
  1. Make sure you format your drive with a 350 mb partition than the rest is for your c drive.
  2. For faster pxe speed, update your bios, change the packet size in your server registry for your WDS. ( google search for this one) It works great.
  3. You need to add a task sequence ( set task sequence Variable ) variable OSDPreserveDriveLetter False, to use the C drive.
  4. Make sure your connection to your windows iso or media is on your sccm server in your setup.
  5. In config mgr, turn on Pxe with tools. This way you can hit f8 at any time open up Log viewer and open up log file to see what is happening real time.
