Malik4u
Remote Installation, SCCM 2012 R2
Hi
I have a scenario where I have a fully functional SCCM 2012 setup.
Now assume we need to setup a branch office in different city/country. Do I need to setup RDP? If yes, how I can setup remote distribution point?
I know for sure I need a dedicated IP. Do I need to have a cisco check point device as well?
Would be great if someone can refer to step by guide.
Depends on what sort of server you want to install in that new site. I assume you mean just a DP.
You'll need RDP regardless anyway.
Setup the server to have IIS installed, along with Remote Differential Compression, and Enable BITS (I do this as standard on all my DP's)
Add the site server computer account as administrator on the DP.
On your CAS / Primary Site - go into Administration > Site Configuration > Create Site System Server
Enter in all the details for your new server account, then select the Distribution Point role from the System Role Selection screen.
Wait about 20-30 minutes and it should be on its way to going live.
You can monitor the progress under Montioring > Distribution Status > Distribution Point Confuguration Status
