impulse101
Pre-Provisioning Bitlocker fails because encryption not fast enough
the wait command they are referring to is to add a timer (sleep for 60 seconds) step, like this , create a run command line step called Sleep 60 seconds and type the following in the run command line step
CMD.exe /c PING n 61 127.0.0.1
please this step before the Apply Operating system step and after the Pre Provision bitlocker step.
does that help ?
Yeah, i assumed that must be where it should go, I already have a 90 second wait at that stage in the TS....
It makes no difference though, the Bitlocker pre-provision step succeeds (well i think it does, the TS doesnt bomb out), but fails at the enable bitlocker step.
Other laptops (also Lenovo) running the the same task sequence are succeeding and have been since we started using bitlocker, so I don't think the problem lies there. But this eval device we have been sent, with the same tpm settings always fails and the only real difference i think is the SSD.
Any other ideas Niall?
While waiting for a response i will try flashing the BIOS to rule it out, but I am confident thats not going to make any difference.
Thanks.
well what errors are you seeing in the enable bitlocker step ? have you tried adding a pause command to the ts directly after the pre-provision bitlocker step then open a cmd prompt and issue
manage-bde -status
and wait till it's 100% then unpause and let it continue, does it continue ok or still fail, that's what we need to know...
BitLocker Version: 2.0
Conversion Status: Used Space Only Encrypted
Percentage Encrypted: 100%
Encryption Method: AES 128
Protection Status: Protection Off
Lock Status: Unlocked
Identification Field: Unknown
Automatic Unlock: Disabled
Key Protectors: None Found
I ran the command within about 5 seconds of the wait command running, with the above - 100% encrypted, so that does not seem to be the issue (although i am confused as to why this would be an issue for anyone, surely the HDD is almost empty at this stage in a TS - isnt that the WHOLE reason why you PRE-provision?? So when the WIM is being applied, the data is already encrypted and so there is nothing to wait for?).
Well this is annoying!!!!
It is now working. No changes to the TS were made except to add the 90 second delay (just a ping), which caused a number of failures on this device, but now it runs through fine.
Could this have been an AD issue in my case, and in no way related to the issues other users are experiencing?
If there were better logs for the bitlocker steps in the TS, this would be much easier.....
