indy
Is it possible to do UEFI and PXE (Legacy) deployment on same vlan
Hey
Okay, just realized that I had to use an extra IP-Helper for the WDS/SCCM server :) - (and not the dhcp options)
But downloading the WinPE file is very slow - do anyone know why? (approx 10 times slower than legacy boot)
Mikey
Sorry, read that wrong.
Increase your TFTP speed on your DP. Change the below value to either 4096, 8192, 16384 etc.
On my environment, it couldn't go above 8192, it broke the transfer. so I've kept it at that, which takes around 20-30 seconds for a 260mb WinPE image.
Once changed. Restart WDS & retry
TYPE: REG_DWORD
Value: 16384
