Support for ACT 5.5 with the ACT Connector
Microsoft released a new version of ACT, version 5.5. This version changed the database schema which prevents configuring the ACT database from the ACT Connector administrator console. If you upgrade an existing ACT installation to 5.5 which has already been configured in the ACT connector, no additional steps are required.
Using this documented workaround ACT 5.5 is supported by Microsoft with the System Center Configuration Manager 2007 ACT Connector.
Symptoms
You will see the following error when attempting to configure your ACT database:
Cannot connect to SERVERNAME.
[-2146232060] Invalid object name ‘ACT_Databases’.
An update will not be released to fix this issue at this time, but the following workaround is available:
more > http://blogs.technet.com/configurationmgr/...-connector.aspx
0 answers to this question
