P3nnyw1se Posted April 16, 2014 Report post Posted April 16, 2014 Hi I've succesfully created a task sequence that installs a windows 7 image.I've also created 25 applications, driver packages.. etc.I'm attempting to learn as much as possible about sccm 2012, and my next 'project' is I wanna be able to refresh and replace computers.Can you point me towards some good guides in the use? I thought I had seen some on this forum but now I can't find them. Just a quick question, is it possible to use the same task sequence for both new install or replace e.g. ?cause seems like it in the UDI wizard. Quote Share this post Link to post Share on other sites More sharing options...
newadmsccm Posted April 16, 2014 Report post Posted April 16, 2014 In this link there are a lot of guides I'm sure will help you: http://www.windows-noob.com/forums/index.php?/topic/4045-system-center-2012-configuration-manager-guides/ Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted April 16, 2014 Report post Posted April 16, 2014 the easiest way to do a refresh scenario is with this task sequence, you don't even have to think as it's done the hard work for you, try it and see ! don't be put off by the bitlocker stuff, you don't have to use it if you don't want to. CM12 in a Lab - The CM12 BitLocker FrontEnd HTA - video CM12 in a Lab - The CM12 BitLocker FrontEnd HTA Quote Share this post Link to post Share on other sites More sharing options...
