Bext
system management folder missing
Hello, I have been following the guide and I am stuck while trying to follow this guide: http://www.windows-noob.com/forums/index.php?showtopic=490
I do not have a "system management" folder in Active Directory Users and Computer/System folder. I have selected "advanced features" under view and I see every other folder that is displayed in the guide but not "system management" I have attached a screen print to show what I have described.
I'm running Windows server 2008, SCCM R2, and Windows XP
Any hints?
3 answers to this question
  anyweb said:
hi and welcome
you can create it by doing this
Thank you for the quick reply.
Unfortunately, the system management folder is nonexistent in ADSIedit as well as the CN=DFSRGlobal Settings folder.
(I'm sure I must have missed a step somewhere.) Hmmmm
if it\s missing, then create it as per the adsiedit guide, then once permissions are correct, it will populate with info
