theblesss
OSD TS Naming Lenovo using serial number for OSDComputerName
SCCM 2012 R2 CU1, using OSD Task Sequence
I'm stuck trying to auto-name Lenovo Yoga 2 Pro machines but when I put %serialnumber% in the TS Variable for OSDComputerName, it puts in a different number than is on the bottom of the machine. I want users to easily be able to see the model number that will be the name of the PC. I can find this number by running "wmic baseboard get serialnumber" and it matches what is on the tag, but I can't figure out how to get that into the TS. If someone could provide a simple way to do this or provide any screenshots of the TS item I would be in your debt!
I have Dell Latitudes that are naming correctly using the %serialnumber% during the Post Install, after the Gather step.
Thanks,
Matt
0 answers to this question
