Hello
I have just been looking at the application deployment statistics reports in 2012 but none of the images in the reports are loading. However if I export the report to a CSV file I can see there is data under the headings compliant , In Progress etc.
Does anyone have any ideas what would be cause this? I have attached some images of the reports.
  1. I don't recommend accessing the reports via the console. too much over heard access then directly from IE.
  2. Does it work from IE directly?
  3. If not have you re-installed the report viewer <CM12 install directory>\bin\i386\reportviewer.exe?
Yes I have also tried via IE and get the same results, even if I use another machine or view them directly from the server. Re-installing the report viewer hasn't made any difference good shout as I had forgotten about that.
