I am trying to locate a guide on how to create an application within SCCM 2012 that will successfully deploy SQL Server 2012 Enterprise. Since we use a response file, I have only found success in deploying the software is through the use of a task sequence. I would prefer to use an application to deploy SQL Server 2012 due to the features.
I am having similar issues with certain Oracle products as well. It seems that deploying software (for me at least) is somewhat problematic when response files are involved using anything other than a task sequence.
If anyone has any tips or pointers, I would greatly appreciate it.
